    MMM-InternetMonitor
    18 Posts 4 Posters 7.7k Views 4 Watching
      sdetweil @Richtw
      @Richtw said in MMM-InternetMonitor:
      binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node
      looks like not built for arm and electron 22…
      so, you could try this
      create a file in the module home folder
      cd ~/MagicMirror/modules/internet-monitor
      touch buildit
      then nano buildit, and paste this into the editor
      #!/bin/bash
      if [ ! -f ../../node_modules/.bin/electron-rebuild ]; then
      	cd ../..
      	npm install electron-rebuild >/dev/null 2>&1
      	cd -
      fi
      ctrl-o to save, ctrl-x to exit
      chmod +x buildit
      then ./buildit
      • bheplerB Offline
        bhepler Module Developer @Richtw
        @Richtw - Yeah, that error usually means that there is an error in your config.js file.
        Couple suggestions:
        1. Try this out in the MagicMirror folder: npm run config:check. It will let you know if there are any errors in your config.js file.
        2. Post the relevant section of your config.js file in this thread. Be sure to use the markdown features of the forum for readability.
        [Dammit, I am about this close to just deleting my repository. It’s not my module and I’m sick of fixing it.]
          Richtw @bhepler
          @bhepler
          thanks everyone for all the suggestions. Still stuck:
          For the suggestion - @Richtw the error is about 20 lines closer to the top - Here’s the top
          richard@raspberrypi:~/MagicMirror/config $ npm start
          magicmirror@2.22.0 start
          DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
          [24.01.2023 17:51.15.999] [LOG] Starting MagicMirror: v2.22.0
          [24.01.2023 17:51.16.006] [LOG] Loading config …
          [24.01.2023 17:51.16.014] [LOG] Loading module helpers …
          [24.01.2023 17:51.16.017] [LOG] No helper found for module: alert.
          [24.01.2023 17:51.16.053] [LOG] Initializing new module helper …
          [24.01.2023 17:51.16.054] [LOG] Module helper loaded: updatenotification
          [24.01.2023 17:51.16.056] [LOG] No helper found for module: clock.
          [24.01.2023 17:51.16.534] [LOG] Initializing new module helper …
          [24.01.2023 17:51.16.535] [LOG] Module helper loaded: calendar
          [24.01.2023 17:51.17.618] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/richard/MagicMirror/modules/internet-monitor/node_modules/lzma-native/binding-v4.0.6-electron-v22.0-linux-arm64/lzma_native.node’
          For the suggestion - npm run config:check. I ran it and it did not find anything
          Your configuration file doesn’t contain syntax errors :)
          Here’s my config file
                                  module: 'internet-monitor',
                                  position: 'upper_third',
                                  header: 'Internet Monitor',
                                  config:{
                                          type: '',
                                          maxTime: 20000,
                                          updateInterval: 30000,
                                          verbose: false,
                                          displayStrength: true,
                                          displaySpeed: true,
                                          strengthIconSize: 80,
                                          maxGuageScale: 1000,
          I tried that buildit script but it kicked back with:
          ./buildit: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
          Running with sudo gave same result
            sdetweil @Richtw
            @Richtw can you show results of
            ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
              Richtw @sdetweil
              @sdetweil said in MMM-InternetMonitor:
              thanks for the reply!
              richard@raspberrypi:~/MagicMirror $ ls ~/MagicMirror/node_modules/.bin/electron-rebuild -laF
              lrwxrwxrwx 1 richard richard 34 Jan 24 17:57 /home/richard/MagicMirror/node_modules/.bin/electron-rebuild -> ../electron-rebuild/lib/src/cli.js
                sdetweil @Richtw
                @Richtw weird.
                edit the buildit script we wrote and add
                -b
                at end of the last line, w a space before it. see if we can find where it is have permissions error
                  Richtw @sdetweil
                  @sdetweil Here’s the script I’m running
                  !/bin/bash
                          cd ../..
                          cd -
                  fi
                  ../../node_modules/.bin/electron-rebuild -b
                  Here’s the result
                  richard@raspberrypi:~/MagicMirror/modules/internet-monitor $ sudo ./buildit
                  ./buildit: line 8: ../../node_modules/.bin/electron-rebuild: Permission denied
                    sdetweil @Richtw
                    @Richtw sorry. I do not understand the problem jetey, and cannot reproduce it on my own
