    MMM-futar - how to add modules multiple time?
    24 Posts 3 Posters 8.0k Views 3 Watching
    • 0 Offline
      0livia @sdetweil
      @sdetweil sorry i do not understand you
      0 1 Reply Last reply Reply Quote 0
      • 0 Offline
        0livia @0livia
        @0livia the mirror actually works with only one item
        https://imgur.com/a/j1iYnaN
        , as soon as i edit the config js
                    module: "MMM-Futar",
                    header: 'Közvágóhíd -> Ráckeve',
                        stopId: 'BKK_009628',  // Közvágóhíd
                        routeId: 'BKK_H6,
                    header: 'Ráckeve -> Közvágóhíd',
                        stopId: 'BKK_007947',  // Ráckeve
                        routeId: 'BKK_H6',
        it stop working
          sdetweil @0livia
          @0livia said in MMM-futar - how to add modules multiple time?:
                      routeId: 'BKK_H6',
          that is missing the } of the module:
          so the following stuff becomes part of the last futar module block
          remove this from config.js
                  minutesAfter: 50,
                  hideStopTimesInNextMinutes: 0,
                  updateInterval: 60000, // 1 minute in milliseconds
                  showHead: true, // true | false
                  showSymbolInHead: true, // true | false
                  showSymbolInStopTime: false, // true | false
                  showRouteNameInStopTime: false, // true | false
                  maxNumberOfItems: 3,
                  align: 'left', // 'left' | 'right'
                  fade: true,
                  fadePoint: 0.25,
                  coloredSymbolInHead: true, // true | false
                  coloredTextInHead: true, // true | false
                  coloredSymbolInStopTime: true, // true | false
                  coloredRouteNameInStopTime: true, // true | false
                  symbolColors: {
                    tram: '#ffcf42', // yellow-ish
                    bus: '#1a9fed', // blue-ish
                    subway: '#b3090c', // red-ish
                    trolleybus: '#931517', // dark red-ish
                    rail: '#5cbc82', // green-ish
                    ferry: '#1a52ed' // dark-blue-ish
          • 0 Offline
            0livia @sdetweil
            @sdetweil when removed the bit you suggested it is working now.
            The thing is what i do not understand that it worked before removing the section from the config.js just only with one single item. Anyway thank you for your help guys!
