    Add data from another Pi
    9 Posts 3 Posters 4.3k Views 3 Watching
      Richard238
      I have another Pi, in an out-building, collecting data and serving it up via Apache/MySQL/PHP.
      How can I get this data integrated in to MM2?
      Thank you.
      • Y Offline
        yawns Moderator
        If you use Apache and PHP you could create a php script which delivers JSON (or XML) data based on the query and is called by the other raspberry. I would avoid saving data into a text file on the Apache PI and having the MM² PI opening this text file. That could cause trouble when the file is in use (data is currently being written into the file).
          Richard238 @yawns
          @yawns said in Add data from another Pi:
          …you could create a php script which delivers JSON (or XML) data…
          Beyond my capabilities, I’ll keep looking though. Thank you.
          • Y Offline
            yawns Moderator
            Okay, one step back …
            Your data is stored in your mysql database, right? How is this data stored there? Did you program a script? Or are you using a script/system from the internet? Maybe there already is some kind of a backend you could use?
              Richard238
              Yes, correct
              It’s a couple of temperature sensors which are written to the MySQL DB via a .py script.
              • I Offline
                izanbard
                @Richard238
                I can help modify the scrip that servers up the data for viewing and instead of returning HTML it could easily return JSON. That would be step one. To help I would need to see your php files and know what url you are using to access the PHP page. either PM them to me, or point me at a repo.
                Step two would be writing a MM module that gets the JSON and displays it right. I may be able help here too.
                • I Offline
                  izanbard @izanbard
                  @izanbard Of course if you already have a webpage with exactly the right stuff on it, then you could use the iframe module.
                  • I Offline
                    izanbard
                    Have emailed you with some instructions, but check:
                    [card:izanbard/MMM-MyTemps]
                    for the full source
                      Richard238
                      Thanks for all your work on this, it’s working great!
