    Getting warning in development view in my module MMM-RadioDe + Error Message + other questions
    2 Posts 2 Posters 1.6k Views 2 Watching
      Steff
      Hi all, since @Disturbx (Forum Link MMM-RadioDe) wrote that “my” MMM-RadioDe module does not operate on his mirror but in browser view, I started some more debugging by starting the MMM with npm start dev and I can see some warnings/ error messages I do not understand:
      pascalprecht.translate.$translateSanitization: No sanitization strategy has been configured. This can have serious security implications. See http://angular-translate.github.io/docs/#/guide/19_security for details.
      VM108 vendor.js:9 Error: Blocked a frame with origin "http://www.radio.de" from accessing a cross-origin frame.
          at Error (native)
          at http://www.radio.de/inc/microsite/js/app.js:2:5158
          at http://www.radio.de/inc/microsite/js/vendor.js:9:25272
          at o (http://www.radio.de/inc/microsite/js/vendor.js:8:4062)
          at http://www.radio.de/inc/microsite/js/vendor.js:8:6140(anonymous function) @ VM108 vendor.js:9(anonymous function) @ VM108 vendor.js:8(anonymous function) @ VM108 vendor.js:9o @ VM108 vendor.js:8(anonymous function) @ VM108 vendor.js:8
      playlog:1 GET https://api.radio.de/info/v2/user/playlog?status=Trying%20to%20connect...&s…9h5&reconnect=0&waittime=0&apikey=df04ff67dd3339a6fc19c9b8be164d5b5245ae93 403 (Forbidden)
      playlog:1 GET https://api.radio.de/info/v2/user/playlog?status=Stream%20started%20to%20pl…&reconnect=0&waittime=1002&apikey=df04ff67dd3339a6fc19c9b8be164d5b5245ae93 403 (Forbidden)
      playlog:1 GET https://api.radio.de/info/v2/user/playlog?status=Heartbeat&station=antennek…reconnect=0&waittime=60751&apikey=df04ff67dd3339a6fc19c9b8be164d5b5245ae93 403 (Forbidden)
      playlog:1 GET https://api.radio.de/info/v2/user/playlog?status=Heartbeat&station=antennek…econnect=0&waittime=120991&apikey=df04ff67dd3339a6fc19c9b8be164d5b5245ae93 403 (Forbidden)
      playlog:1 GET https://api.radio.de/info/v2/user/playlog?status=Heartbeat&station=antennek…econnect=0&waittime=180995&apikey=df04ff67dd3339a6fc19c9b8be164d5b5245ae93 403 (Forbidden)
      I do not understand the warning translateSanitization. Did anyone of encounter a similar warning in his module development and could point me in the correct direction ?
      From the other error messages I do get the impression, that my invocation of the web radio player tries to open a frame, but I am not sure… Any hints appreciated.
      Furthermore I thought about to start the webradio player only once after all modules are started:
      Set a variable this.all_started to after ALL_MODULES_STARTED and start radio only once this is successful. Do you think this would be a good way ?
          notificationReceived: function (notification, payload, sender) {
            if(notification === "ALL_MODULES_STARTED"){
              this.all_started = true;
              Log.info("Received notification ALL_MODULES_STARTED setting all_started to  : " + this.all_started);
            }else if(notification === "RADIO_STATION"){
              Log.info("Received RADIO_STATION" + payload.title + "   "+ payload.type);
              this.config.station = payload.title;
              this.updateDom(300);
          getDom: function() {
            if (this.display && this.all_started) {
              var script = document.createElement("div");
              script.innerHTML = "<div></div>
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Steff
        @Steff the translate module which reports an issue is an angular module of pascal precht, but it works even though you didn’t specify a sanitization strategy.
        Your problem are the requests which get an 403 forbidden http status
