    How to use Yr as a weather provider
    12 Posts 3 Posters 2.2k Views 4 Watching
      MajorC Project Sponsor
      I would like to use the new v2.22.0 feature of Yr as weather provider.
      I changed
      weatherProvider: "yr",
      I think I need a new apiKey. What about the location and locatioID?
      Any advise are appreciated.
      Thank you
      • karsten13K Offline
        karsten13 @MajorC
        @MajorC
        see https://github.com/MichMich/MagicMirror-Documentation/pull/134/files
        will hopefully soon merged into official documentation (there are merge conflicts …)
        karsten13K 1 Reply Last reply Reply Quote 1
          karsten13 @karsten13
          as follow up: That was merged today so you find it now in the offical documentation https://docs.magicmirror.builders/modules/weather.html#yr-options
            MajorC Project Sponsor @karsten13
            @karsten13
            My config looks like this:
            			module: "weather",
            				showHeader: true,
            				type: "current",
            				lat: "52.5544",
            				lon: "13.4635",
            				roundTemp: true,
            But the mirror only says “loading…” all the time.
            Any ideas how to deal with that? I use MM v2.24.0
              sdetweil @MajorC
              @MajorC said in How to use Yr as a weather provider:
                		type: "current",
                		lat: "52.5544",
                		lon: "13.4635",
              numbers and true/false do not use quotes…
              open the developers window, ctrl-shift-i on the MM page,
              select the console tab and put,
              wea
              in the filter field to see only messages from the weather module
                MajorC Project Sponsor @sdetweil
                @sdetweil you are absolute right. But still:
                yr.js:311 Could not load weather data. SyntaxError: Unexpected non-whitespace character after JSON at position 4 (line 1 column 5)
                    at JSON.parse (<anonymous>)
                    at performWebRequest (utils.js:27:29)
                (anonymous) @ yr.js:311
                Promise.catch (async)
                getStellarDataFromYr @ yr.js:310
                getStellarDataFromYrOrCache @ yr.js:268
                (anonymous) @ yr.js:231
                getStellarData @ yr.js:213
                getCurrentWeather @ yr.js:47
                fetchCurrentWeather @ yr.js:35
                (anonymous) @ weather.js:190
                setTimeout (async)
                scheduleUpdate @ weather.js:187
                start @ weather.js:99
                startModules @ loader.js:25
                loadNextModule @ loader.js:218
                await in loadNextModule (async)
                loadNextModule @ loader.js:211
                loadModules @ loader.js:221
                init @ main.js:471
                await in init (async)
                (anonymous) @ main.js:593
                yr.js:285 Error: SyntaxError: Unexpected non-whitespace character after JSON at position 4 (line 1 column 5)
                    at yr.js:312:11
                (anonymous) @ yr.js:285
                getStellarDataFromYrOrCache @ yr.js:284
                setTimeout (async)
                init @ main.js:471
                yr.js:41 Unable to get stellar data from Yr.
                (anonymous) @ yr.js:41
                fetchCurrentWeather @ yr.js:40
                setTimeout (async)
                init @ main.js:471
                yr.js:42 Uncaught (in promise) Error: Unable to get stellar data from Yr.
                    at yr.js:42:11
                with config:
                			module: "weather",
                				showHeader: true,
                				type: "current",
                				lat: 52.5544,
                				lon: 13.4635,
                				//roundTemp: true
                ![alt text](c76fa3d6-3ee0-4a86-af34-ab263cea8040-image.png image url)
                  sdetweil @MajorC
                  @MajorC the api returned data the module did not expect and did not handle the error…
                  the exact cause of the error is unknown as the code did not report it…
                  i have seen quite a lot of sloppy api programming lately…
                  the rules are pretty clear
                  rc=200 means all good
                  other errors 300/400/500 families provide specific info
                  but a lot of apis return 200 even for error cases and THEN the code has to decode the TEXT of the ‘good’ data message…
                  sloppy, lazy…
                  because the error calls out an ‘unexpected non-whitepace’ (a colon maybe) , I suspect this api is one of these
                    @sdetweil so I have to use an other weather provider? I really like Yr. They are very precise for Europe.
                      sdetweil @MajorC
                      @MajorC not what I said… its broken as you are using it, but I don’t know why. I am not the provider author… you can post an issue to the MM github page…
                        karsten13 @sdetweil
                        see https://github.com/MichMich/MagicMirror/issues/3189
                        yr has changed api, the fix comes with next release on Oct.
