    PIR and config.js
    16 Posts 3 Posters 5.9k Views 4 Watching
    • N6NGN Offline
      N6NG
      I saw the thread about running the script below to see if the screen would react to the vcgencmd.
      /usr/bin/vcgencmd display_power 0; echo “Display should now be off”; sleep 20; /usr/bin/vcgencmd display_power 1; echo “And now it should be on again”
      I did so and the screen did as advertised… My problem is I’m not sure how to incorporate this into the config.js to make my PIR work properly.
      		module: "MMM-PIR-Sensor-Lite",
      			sensorPin: 2, // GPIO pin
      		        commandType:  "vcgencmd",
      Can one of you smart people give me some ideas?
      Thanks all…
      Dennis
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @N6NG
        @N6NG those commands should be what the pir module execute.
        examine the node_helper.js
          shall_ @N6NG
          @N6NG I have just spent the evening getting my MM working with this module. What do you want this module to do? turn the screen off 20 seconds after motion is detected?
          I am using the latest version of Desbian so i had to used the default xrandr command. but I seem to have got it working fine. I was also having issues with GPIO pin 2 so I changed it to pin 22.
          If it helps, I can share my config file for this module.
          N6NGN 2 Replies Last reply Reply Quote 1
          • N6NGN Offline
            N6NG @shall_
            @shall_ Yes… I would like to look at it… If you would like not to post it to public, you can send it to my protected email
            wg7dgxytg@relay.firefox.com
            Dennis
            • N6NGN Offline
              N6NG @shall_
              @shall_ Although it might help others if you don’t mind posting it here…
              Dennis
              • N6NGN Offline
                N6NG
                I never saw an example of what the config.js would look like to have the vcgencmd be used to turn the screen on and off. Would someone post a part of a config.js with this in use so I can get a look at how it would be used? I would appreciate it.
                Thanks all
                Dennis
                  sdetweil @N6NG
                  @N6NG edit the node_hekper.js and see what it does. change as u see fit
                  N6NGN 1 Reply Last reply Reply Quote 0
                  • N6NGN Offline
                    N6NG @sdetweil
                    @sdetweil Use the whole node_helper.js except as I modify it? The only thing I would modify would be the sensor pin number… All else would stay the same?
                    • N6NGN Offline
                      N6NG @N6NG
                      @N6NG Do I modify it where it is or do I copy it into the config.js ? If I modify it where it is and change the sensor pin what would I put in the config.js?
                        sdetweil @N6NG
                        @N6NG said in PIR and config.js:
                        all you are doing is changing the vcgencmd string
                        exec(“…”)
                        then everything else is normal in config.js
                        pin and commandType (I didn’t look at the module doc)
                        • N6NGN Offline
                          N6NG @sdetweil
                          @sdetweil Ok Sam… thanks I’ll give it a try and see how it does… will let you know…
                          Dennis
                          • N6NGN Offline
                            N6NG @N6NG
                            @N6NG When I put the
                            exec (“/usr/bin/vcgencmd display_power 0”, null);
                            in the config.js I get an error. When I run npm run config:check it says that line has an Unexpected token
                            Dennis
                              sdetweil @N6NG
                              @N6NG be careful copy/paste, the forum without code marker uses the slanted. single and double quotes. used by word processing apps
                              JavaScript expects the upright versions
                              • N6NGN Offline
                                N6NG @sdetweil
                                @sdetweil I typed it in straight from the keyboard… No copy and paste at all… Still the still the same error…
                                Dennis
                                  sdetweil @N6NG
                                  @N6NG that doesn’t go on config.js, it goes in the node_helper.js to replace what it already does, if it’s different.
                                  • N6NGN Offline
                                    N6NG @sdetweil
                                    @sdetweil Oh… ok… thanks… I’ll do that.
                                    Dennis
