    PIR and config.js
    16 Posts 3 Posters 4.5k Views 4 Watching
    • N6NGN Offline
      N6NG @sdetweil
      @sdetweil Ok Sam… thanks I’ll give it a try and see how it does… will let you know…
      Dennis
      N6NGN 1 Reply Last reply Reply Quote 0
      • N6NGN Offline
        N6NG @N6NG
        @N6NG When I put the
        exec (“/usr/bin/vcgencmd display_power 0”, null);
        in the config.js I get an error. When I run npm run config:check it says that line has an Unexpected token
        Dennis
          sdetweil @N6NG
          @N6NG be careful copy/paste, the forum without code marker uses the slanted. single and double quotes. used by word processing apps
          JavaScript expects the upright versions
          • N6NGN Offline
            N6NG @sdetweil
            @sdetweil I typed it in straight from the keyboard… No copy and paste at all… Still the still the same error…
            Dennis
              sdetweil @N6NG
              @N6NG that doesn’t go on config.js, it goes in the node_helper.js to replace what it already does, if it’s different.
              • N6NGN Offline
                N6NG @sdetweil
                @sdetweil Oh… ok… thanks… I’ll do that.
                Dennis
