    struggle with MMM-Remote-Control and MMM-Buttons
    11 Posts 4 Posters 5.8k Views 4 Watching
      matyldatait
      Hi there.
      Beginner here. I’m finding it a very steep learning curve. I just want a pushbutton (GPIO) to hide/show a module. I thought it would be simple.
      Trawling the forums led me to believe that I can use MMM-Buttons and MMM-Remote-Control. I dont need remote-control through a web interface,but it seemed like the module would still be useful for handling notifications.
      Sorry if this is a bit idiotic - like I said - steep learning curve
      So far I have installed both modules and have this is my config.js:
          module: 'MMM-Remote-Control',
          // uncomment the following line to show the URL of the remote control on the mirror
          position: 'bottom_left',
          // you can hide this module afterwards from the remote control itself
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              //customMenu: "custom_menu.example.json", // Optional, See "Custom Menu Items" below
              // apiKey: "", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
          module: 'MMM-Buttons', //using GPIO numbers
              buttons: [
                      pin: 25,
                      longPress: {
                          notification: "REMOTE_ACTION",
                          payload: {action: "HIDE", module: "compliments"}
                      shortPress: {
                          payload: {action: "SHOW", module: "compliments"}
                      pin: 7,
                      longPress: {
                          payload: {action: "MONITOROFF"}
                      shortPress: {
                          payload: {action: "MONITORON"}
                      pin: 24,
                      longPress: {
                          title: "Power off",
                          message: "Keep pressed for 3 seconds to shut down",
                          imageFA: "power-off",
                          payload: {action: "SHUTDOWN"}
                      shortPress: undefined
        sdetweil @matyldatait
        @matyldatait do the buttons trigger outside using MagicMirror?
        there are python scripts one could use to test
          matyldatait @sdetweil
          @sdetweil good idea as a first step debugging. This scrip suggested doing it with button connected between a GPIO pin and ground:
          http://razzpisampler.oreilly.com/ch07.html
          …and yes - that works
            @matyldatait and is the vpuo.pin numbering the same between the test tool you used and theagic mirror module? there are two different numbering schemes
              @sdetweil having established that the button is working as connected on pin18,I simplified the button module usage in my config to this:
                  module: 'MMM-Buttons', //use GPIO numbers
                      buttons: [
                              pin: 18,
                              shortPress: {message: "button pressed"}
              Still nothing. No message in my terminal or on mirror screen.
                matyldatait
                So, figured I could try reinstalling MMM-Buttons. I get this output on attempting to install. Gibberish tome :(
                matylda@raspberrypi:~/MagicMirror $ cd MMM-Buttons/
                matylda@raspberrypi:~/MagicMirror/MMM-Buttons $ npm install
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm WARN deprecated electron-rebuild@1.11.0: Please use @electron/rebuild moving forward. There is no API change, just a package name change
                Magic-Mirror-Module-Buttons@1.0.0 postinstall
                node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
                An unhandled error occurred inside electron-rebuild
                Unable to find electron’s version number, either install it or specify an explicit version
                Error: Unable to find electron’s version number, either install it or specify an explicit version
                at /home/matylda/MagicMirror/MMM-Buttons/node_modules/electron-rebuild/lib/src/cli.js:87:19
                at Generator.next ()
                at fulfilled (/home/matylda/MagicMirror/MMM-Buttons/node_modules/electron-rebuild/lib/src/cli.js:6:58)
                npm ERR! code 255
                npm ERR! path /home/matylda/MagicMirror/MMM-Buttons
                npm ERR! command failed
                npm ERR! command sh -c – node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
                npm ERR! /home/matylda/.npm/_logs/2023-02-16T04_32_03_500Z-debug-0.log
                  @sdetweil yes it is - I also tried both numbering schemes to be sure
                    @matyldatait install problem, yes
                    use my fork which contains a fix for that
                    https://github.com/sdetweil/MMM-Buttons
                      @sdetweil thanks very much Sam - I will try that
                        Divis
                        Did you ever get this one figured out? I am having one hell of an issue trying to get the monitors to turn off. Pin 24 shuts the system down fine. I can change the payload to brightness instead and it works perfectly. But it seems that there’s a disconnect between the MMM-Buttons and the MMM-Remote-Control customCommand section through either running the command alone or in a script. When I run the script or command in terminal through SSH they work fine, but when envoked from MMM it’s ignored or goes no where.
                        			//https://github.com/Jopyth/MMM-Remote-Control
                        			disabled: false,
                        			//position: 'bottom_left', // Required to show URL/QR code on mirror
                        				customCommand: {
                        					//monitorOnCommand: '/home/pi/MagicMirror/config/mm-dispOn.sh',
                        					//monitorOffCommand: '/home/pi/MagicMirror/config/mm-dispOff.sh',
                        				    monitorStatusCommand: 'wlr-randr | grep -q "Enabled: yes" && echo "true" || echo "false"',
                        					monitorOnCommand: 'wlr-randr --output HDMI-A-1 --on',
                        					monitorOffCommand: 'wlr-randr --output HDMI-A-1 --off',
                        				secureEndpoints: false, // Optional, See API/README.md
                        				// customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                        				// classes: {}, // Optional, See "Custom Classes" below
                        				showModuleApiMenu: false, // Optional, disable the Module Controls menu
                        				// showNotificationMenu: false, // Optional, disable the Notification menu
                        				// QR Code options (new!)
                        				// showQRCode: true, // Optional, display QR code for easy mobile access (default: true)
                        				// qrCodeSize: 150, // Optional, size of QR code in pixels (default: 150)
                        				// qrCodePosition: "below" // Optional:
                        				//   "below" - Show URL above, QR code below (default)
                        				//   "above" - Show QR code above, URL below
                        				//   "replace" - Show only QR code, no URL text
                        			module: "MMM-Buttons",
                        			//https://github.com/KristjanESPERANTO/MMM-Buttons
                        			disabled: false,
                        			position: "bottom_right",
                        			buttons: [
                        				pin: 25,
                        				activeLow: true,
                        				longPress: [
                        					title: "Monitor off",
                        					message: "Keep pressed for 3 seconds to switch the monitor down",
                        					imageFA: "display",
                        					payload: {action: "monitorOffCommand"},
                        					//payload: { action: "BRIGHTNESS", value: 10 }
                        				shortPress: [
                        					title: "Monitor on",
                        					message: "Short press for monitor on",
                        					imageFA: "display",
                        					payload: {action: "monitorOnCommand"},
                        					//payload: { action: "BRIGHTNESS", value: 100 }
                        				pin: 24,
                        				activeLow: true,
                        				longPress: [
                        					title: "Power off",
                        					payload: {action: "SHUTDOWN"},
                        • KristjanESPERANTOK Offline
                          KristjanESPERANTO Module Developer @Divis
                          @Divis Looks like an action-name mismatch.
                          MMM-Buttons should send REMOTE_ACTION values such as MONITORON and MONITOROFF.
                          monitorOnCommand and monitorOffCommand are config keys in MMM-Remote-Control, not REMOTE_ACTION values.
                          So in MMM-Buttons, try:
                          • action: MONITORON
                          • action: MONITOROFF
