    sendSocketNotification() does not arrive at module
    2 Posts 2 Posters 476 Views 2 Watching
      mjlee
      I’m very new to MM (2 days in…).
      I have successfully got a module I’ve written working. It scrapes a local transit website for real-time train departure info and displays in the mirror.
      My second module, however, is having problems. The node_helper is getting socket notifications from the module, but when it calls sendSocketNotification(), nothing is received at the module. I tried used the original (working) module as a template, making it almost an exact copy of the working module, but that didn’t help.
      I’ve stipped it back to almost nothing, and still no luck. Here’s the node_helper and module file in question:
      node_helper.js:
      const NodeHelper = require('node_helper');
        start: function() {
          console.log("Starting node helper: " + this.name);
          var self = this;
          console.log("Notification: " + notification + " Payload: " + JSON.stringify(payload));
          if (notification === "GET_DATA") {
            self.sendSocketNotification("GOT_DATA", "1234566789");
      and MMM-MYTEST.js:
      Module.register("MMM-MYTEST", {
        // Default configs
        defaults: {
          intervalSecs: 10,
        start: function () {
          Log.info(this.config);
          Log.log('Starting module: ' + this.name);
          self = this;
          self.getData();
          setInterval(function() {
            self.getData();
          }, self.config.intervalSecs * 1000);
        getData: function () {
          Log.info(this.name + ': Getting data');
          this.sendSocketNotification("GET_DATA", {
            config: this.config,
        getStyles: function () {
          return [
            this.file('styles.css'),
          if (notification === "GOT_DATA") {
            Log.info('socketNotificationReceived: GOT_DATA');
            this.updateDom();
        // Override the DOM generator
        getDom: function () {
          let wrapper = document.createElement('div');
          return wrapper;
      And snipped log output while running (I added some debug outout to NodeHelper.socketNotificationReceived() to make sure it was being called):
      [27.02.2023 14:10.56.820] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
      [27.02.2023 14:10.56.821] [INFO]  in MMM-MYTEST sendSocketNotification GOT_DATA
      [27.02.2023 14:11.06.819] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
      [27.02.2023 14:11.06.820] [INFO]  in MMM-MYTEST sendSocketNotification GOT_DATA
      [27.02.2023 14:11.16.827] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
      [27.02.2023 14:11.16.829] [INFO]  in MMM-MYTEST sendSocketNotification GOT_DATA
      So I can see that NodeHelp.socketNotificationRecieved() is being called, but my module never gets the notification. I’ve run out of debug ideas. Any assistance would be greatly appreciated.
      m
        bhepler Module Developer @mjlee
        @mjlee - I copied your code and I’m not getting the same results.
        From the browser console:
        socketNotificationReceived: GOT_DATA    MMM-MYTEST.js:20
        MMM-MYTEST: Getting data                MMM-MYTEST.js:34
        And from the terminal console:
        Ready to go! Please point your browser to: http://localhost:8080
        [28.02.2023 20:52.46.170] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
        [28.02.2023 20:52.46.207] [INFO]  Checking git for module: MMM-MYTEST
        [28.02.2023 20:52.46.207] [INFO]  Checking git for module: default
        [28.02.2023 20:52.56.164] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
        [28.02.2023 20:53.06.156] [LOG]   Notification: GET_DATA Payload: {"config":{"intervalSecs":10}}
        Perhaps the issue is that you’re looking at the wrong console log? The MYTEST.js log will write to the browser’s console rather than the terminal.
