    MMM-TelegramBot End of Life
    7 Posts 4 Posters 2.2k Views 3 Watching
      Rags
      What happened here?? I had an issue with MMM-Telegrambot module today and i had to reinstall it. It is not working now, it says it is “End Of Life” and it no longer works. I get a prompt in Telegram app that “you are not allowed to command me Ask to my Admin”. The display region on the MM page displays the title of the Module and no messages are displayed. Has this module been killed??
      I recently also installed MMM-Openai and was really excited to use it with TelegramBot. Even this is not working now.
      Please someone explain what happened.
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @Rags
        @Rags https://github.com/bugsounet/EXT-TelegramBot
          Rags @swvalenti
          This post is deleted!
            just uninstall, disable or delete MMM-TelegramBot
            install `EXT-TelegramBot and compare each configuration (old and new configuration) and replace all needed values on the new plugin
            create new config from wiki (EXT-TeklegramBot)
            delete, disable or delete old config (MMM-TelegramBot)
              Rags @swvalenti
              @swvalenti said in MMM-TelegramBot End of Life:
              Thaaanks !!
              I must have missed this migration and update.
              Well i reinstalled it as EXT-TelegramBot and reconfigured it in the config.js. Had to set telecast as true. So it works now. I am having an issue with MMM-Openai as the commands of this module are not executing. It says sorry that command is not registered. It was working ok with MMM-TelegramBot. Again seems to be a minor issue , need to check whats missing. Any pointers will help.
                MMRIZE
                I regain the ownership of that module.
                Anyway, it will be archived as it is so that you can use again.
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB Offline
                  bugsounet Banned @MMRIZE
                  After recoding, main code of EXT-TelegramBot
                  This one is now locked to my own use and exclusively to EXT Plugins
                  And in reverse, you can’t use any EXT-TelegramBot commands in MMM-TelegramBot
                  I confirm, i send back MMM-TelegramBot to @MMRIZE
