    Compliments font size
    5 Posts 2 Posters 3.4k Views 2 Watching
    • T
      TomOMaley
      Re: Compliments font size
      Hi, obviosly your solution helped everybody besides me. I did the following in the custom.css.sample::root {
      –color-text: #999;
      –color-text-dimmed: #666;
      –color-text-bright: #fff;
      –color-background: black;
      –font-primary: “Roboto Condensed”;
      –font-secondary: “Roboto”;
      –font-size: 20px;
      –font-size-small: 0.75rem;
      –gap-body-top: 60px;
      –gap-body-right: 60px;
      –gap-body-bottom: 60px;
      –gap-body-left: 60px;
      –gap-modules: 30px;
      .compliments .xlarge {
      font-size: 15px;
      There is no modifikation on the font size.
        sdetweil @TomOMaley
        @TomOMaley you can use the compliments config parameter
        ‘classes’
        to force not using mm provided classes. then you can do whatever in custom.css
              module:'compliments',
               config:{
                      classes:'foo',
        custom.css
        .compliments .foo {
              font-size:25px; // or whatever
        T 1 Reply Last reply
        • T
          TomOMaley @sdetweil
          @sdetweil Thank you for your quick reply. Just to avoid misunderstandings. In /home/usr/MagicMirror/css I do not have a “custom.css” file but there are a “main.css” and a “custom.css.sample”. Which one has to be modified?
            sdetweil @TomOMaley
            @TomOMaley if you do not have a custom.css file, then create one
            you can copy the sample or create an empty file and add your settings there
            to create an empty file do
            touch ~/MagicMirror/css/custom.css
            we don’t create one as its optional.
            we don’t ship one cause it would cause us to overwrite one if u had one
            my install script creates an empty one for you, as, like you, many don’t know what to do
            see
            • T
              TomOMaley @sdetweil
              @sdetweil Thank you so much. It works!
