    Displaying Video by pressing button
    10 Posts 3 Posters 2.2k Views 2 Watching
      DIYfirsttime
      Hello Builders,
      Long time ago I installed my first Magic Mirror and it was working wonderful after days and days of configuration.
      Now I have installed the newest Version v.2.23.0.
      Now I am stuck with a request as it looks like that both modules are not supported anymore.
      I was looking for a module that would allow me to play a specific video by pressing a GPIO button.
      Like the modules I used on my old Magic Mirror. MMM-Button and MMM-Podcast2.
      Is someone already working on something like this?
        robiv8
        Hallo,
        i have Installed Buttons, Navigate, Podcast2, MplayerRadio, Dreambox etc.
        The “Tagesschau 100sec.” works, watching TV from the reciever also works. All at the touch of a button. :-)
        I have also installed OMX player and it works great.
        Robi
        Thanks to all the help in between from sdetweil everything is running ;-)
          sdetweil @DIYfirsttime
          @DIYfirsttime mmm-buttons still works, just the update process is broken
          use my fork
          https://github.com/sdetweil/MMM-Buttons
          anything that uses gpio needs to have the binary match the electron version, and so needs a rebuild as part of the install.
          his old way doesn’t work anymore.
            DIYfirsttime @sdetweil
            @sdetweil Thank you for explaining to me how to get MMM-Buttons working.
            To keep this Post still as an request I would like to know if there is a “fix” for MMM-Podcast2 or is someone working or wants to work on a module like this.
            That I can use my physical button to play and stop a Video.
              @DIYfirsttime omxplayer, used by podcast module, no longer works on later raspios versions. not a MagicMirror problem.
              someone would have to find another solution and fix module, if possible.
                robiv8
                Hallo,
                Robi
                  sdetweil @robiv8
                  @robiv8 cool… what pi are you using?
                    robiv8 @sdetweil
                    Raspberry Pi 4 Model B Rev 1.1 4GB
                      sdetweil @robiv8
                      @robiv8 thx
                      can u tell me which OS are are running?
                      lsb_release -a
                      will show it
                        robiv8 @sdetweil
                        pi@InfoTerminal:~ $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Raspbian
                        Description: Raspbian GNU/Linux 10 (buster)
                        Release: 10
                        Codename: buster
                        pi@InfoTerminal:~ $ uname -r
                        5.10.103-v7l+
                          sdetweil @robiv8
                          @robiv8 said in Displaying Video by pressing button:
                          Codename: buster
                          thats why omxplayer still works…
                          doesn’t on bullseye
