    MMM-SystemMonitor
    24 Posts 7 Posters 7.5k Views 6 Watching
      btastic
      Hello,
      I wanted something to display my current system stats to monitor my magic mirror hardware.
      There is a module called MMM-SystemStats, but it seemed buggy and was seemingly not maintained anymore. So I decided to make my own.
      https://github.com/btastic/MMM-SystemMonitor
      Feel free to discuss, ask questions or add suggestions for further development.
      Best regards
      Ben
      BKeyportB L M 3 Replies Last reply Reply Quote 5
      • BKeyportB Offline
        BKeyport Module Developer @btastic
        @btastic Nice. If I hadn’t already done some stupid pi tricks to get that info into a notification so I can display it with MMM-Valuesbynotification…
        • L Offline
          lxne Project Sponsor @btastic
          @btastic MMM-Tools does that, too.
          alt text
          B 1 Reply Last reply Reply Quote 2
            btastic @lxne
            @lxne Ah bummer I didn’t know about it. Thats mostly what I had envisioned.
              MMRIZE
              MMM-Tools is archived. (with some complex history)
              I rarely support that module. It became too far during on my absence from what it was, and I made at the first time. Anyway, I have left it as it currently is.
              If you want to be a successor, always welcome.
              • BKeyportB Offline
                BKeyport Module Developer @MMRIZE
                @btastic to double down on what @MMRIZE said - taking over someone else’s archived module is an exceptional way to learn how to do things. I Would highly encourage it, as the author has directly said he’s okay with it. I did that with a module myself. Taught me so much about javascript working out bugs in an existing module and adding my own flair (and I really should get back on it for one bit…)
                  btastic @BKeyport
                  @BKeyport I will probably take a thing or two, but I think the code can be written a bit better by todays standards. The project is almost 6 years old and was probably refactored a few times. No offense towards @MMRIZE - thats probably one reason he does not want to develop it further without rewriting it.
                    MMRIZE @btastic
                    @btastic You are right. Cheer up for your work!
                    I wish a new module which can be more flexible and modular with modern techniques, and especially, not dedicated to RPI(recently I never work with it), but I have not enough time and interest to do so…
                      btastic @MMRIZE
                      @MMRIZE Thank you.
                      I want to make it OS independant too, but that will be a bit harder I think. I don’t have that much time either. But will work on it in the foreseeable future.
                        Richard238
                        Installed, added to config.js
                                    module: 'MMM-SystemMonitor',
                                    position: 'bottom_right',
                                        updateInterval: 60000,
                                        cpuThermalZone: 0,
                                        units: config.units,
                        MM fails to load.
                        Comment those lines out, MM is OK. What have I missed?
                          sdetweil @Richard238
                          @Richard238 what is the end of the last prior module
                            Richard238 @sdetweil
                            It’s the currently misbehaving weather forecast:
                            			module: 'weather',
                            			position: 'top_right',
                            			header: 'Weather Forecast for: ',
                            				type: 'forecast',
                            				locationID: '11111111',  //ID from https://www.openweathermap.org
                            				apiKey: 'aaaa444444444444444444'
                                        //module: 'MMM-SystemMonitor',
                                        //position: 'bottom_right',
                                        //config: {
                                            //updateInterval: 60000,
                              @Richard238 what is the error?
                              npm run config:check
                                @sdetweil said in MMM-SystemMonitor:
                                pi@mmv2:~ $ npm run config:check
                                npm error code ENOENT
                                npm error syscall open
                                npm error path /home/pi/package.json
                                npm error errno -2
                                npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/pi/package.json'
                                npm error enoent This is related to npm not being able to find a file.
                                npm error enoent
                                npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-02-02T19_09_35_627Z-debug-0.log
                                pi@mmv2:~ $
                                  @Richard238 in the MagicMirror folder
                                    [2025-02-02 21:35:32.330] [INFO]  Checking modules structure configuration ...
                                    [2025-02-02 21:35:32.511] [ERROR] Cannot read properties of undefined (reading 'units')
                                    Module says:
                                    And also tried with
                                    units: metric,
                                    Which failed with:
                                    [ERROR] metric is not defined
                                    config.js towards the beginning says:
                                    units: 'metric',
                                      @Richard238 to the right of :
                                      Numbers and true/false do not need quotes
                                      Any thing that has a letter needs quotes
                                        I don’t understand, sorry?
                                          @Richard238 in config.js all properties are
                                          The value, to the right of the colon (:)
                                          If a number or tr/false
                                          Does not need quotes
                                          If it contains a letter or symbol
                                          It needs quotes
                                          units : metric
                                          To the right is metric
                                          It has letters, so needs quotes
                                            That’s fixed it.
                                            Module in config.js
                                            units: 'config.units'
                                            config.js before modules
                                            was
                                            units: 'metric',
                                            Changed it to
                                            units: "metric",
                                            Quite how Free Memory can be 128% I’ve no idea, that’s for another day.
                                            For now, it’s working. Thank you!
