    update the raspberry os needed?
    5 Posts 4 Posters 1.7k Views 4 Watching
      bdream
      Hi, maybe it’s a stupid question but I have to ask …
      I run MM for a long time now and from time to time I run updates to MM (using Sam’s Script :beaming_face_with_smiling_eyes: ). mostly all went fine.
      My question is, if there is a need to update raspberry os also? Maybe for security reason?
      cheers, bdream
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @bdream
        @bdream not unless u see some functional need
        • BKeyportB Online
          BKeyport Module Developer @bdream
          @bdream No need, I’ve been running on old OSes for a while now - mostly because I want to keep using OMXPlayer.
            bdream @BKeyport
            @BKeyport and @sdetweil
            Many thanks for your replies!
            I go and let it as it is :beaming_face_with_smiling_eyes:
            Have a great day!
            cheers, bdream
            LusbuebL 1 Reply Last reply Reply Quote 0
            • LusbuebL Offline
              Lusbueb @bdream
              @bdream last week i have updated my MM-RasPi3B+ from Stretch (9) to Buster (10) and then to Bullseye (11) and the only problem was the rotation about 90°. The command display_rotate=1 in boot/config.txt was deleted.
              I took the switch from DarkSky to OpenWeatherMap as an opportunity to do the os upgrade on all RaspPi’s (3xRPI3B+, 2x RPI4, 1xRPI400) right away because I like to be up to date with the operating systems.
