    MMM-DHT-Sensor stopped working
    20 Posts 4 Posters 5.9k Views 4 Watching
      Dracarys
      Hi all,
      i have this module installed:
      https://github.com/ryck/MMM-DHT-Sensor/
      it worked fine for several years now.
      However i had to update/upgrade my Raspi 3 because other modules stopped working and now this module does not work anymore.
      I tried to reinsall the module and bcm2835 but it didnt help.
      Since i can readout the DHT with a python script i assume the sensor is still working. I also didnt change the (working) config so i guess the pin should be fine (GPIO6). I dont know what to do now. Does someone have a similar problem?
      Thanks and cheers!
      S ankonaskiff17A 2 Replies Last reply Reply Quote 0
        sdetweil @Dracarys
        @Dracarys did you redo this step in the module install
        https://github.com/ryck/MMM-DHT-Sensor/#bcm2835
          Dracarys
          Yes i also tried that.
          • ankonaskiff17A Offline
            ankonaskiff17 @Dracarys
            @Dracarys What is Update/Upgrade?
            Just sudo apt update the then sudo apt full-upgrade or something different? Seems odd that other modules stopped working, you updated Pi OS, I assume and now DHT sensor quits.
            What is status of the other modules that were broken that prompted an update.
            S D 2 Replies Last reply Reply Quote 0
              sdetweil @ankonaskiff17
              @ankonaskiff17 just run my script for upgrade…
              ankonaskiff17A 1 Reply Last reply Reply Quote 0
                ankonaskiff17 @sdetweil
                @sdetweil I was mainly curious to understand how it broke.
                I look at these MM’s as these totally encapsulated hardware/module systems where say you built one two years ago, used whatever rendition of Pi+MM+modules were out at the time. You plugged it in and off to the races.
                IF you leave it alone, don’t update Pi, don’t update MM, it should run forever (technically) until something in the hardware breaks.
                So I’m always intrigued as a learning thing for me is just to understand what were the circumstances around “It has run for years and It just quit working”
                  @ankonaskiff17 ok. I understand your approach
                    @sdetweil Now if I had a magic wand I could wave and this ALT issue would go up in a puff of smoke that would be nice too.
                      @ankonaskiff17 never ever tried it. the official keystroke is alt and spacebar
                        @sdetweil This is where ALT comes from. First one I built I did on my own with no guidance and I expect it is why you have seen other people saying ALT doesn’t work anymore. I can only work off the documentation. Documents said hit ALT key, I hit ALT key and it works.
                          @ankonaskiff17 cool. never read that part of the doc.
                          also says you can’t install over ssh, but it’s the ONLY way I install mm., ever
                            ankonaskiff17
                            I can build my digital picture frame without going though a bunch of gyrations and that was my goal so I’m content. 3 - 4 days ago that looked grim.
                            Now to look into your comment about a server for all my pictures and see what that requires.
                            Stuff I’m likely ignorant of at this moment I’m sure.
                              @ankonaskiff17 i had a spare machine, installed linux 10 years ago… have a 5tb external drive with the pics and and a lot of other stuff…
                              share via samba (windows file sharing)
                              and mount that on the pi (line in /etc/fstab)
                              ends up in /media/{username}/…configed_name
                              then u can link (ln) to map in to a folder some other place with a new name…
                                Dracarys @ankonaskiff17
                                @ankonaskiff17 Yes sudo apt-get update and sudo apt-get upgrade. Other modules work again just the DHT wont work :(
                                  Dracarys
                                  Fixed it. Updating the magic mirror itself did the trick.
                                  ankonaskiff17A J 3 Replies Last reply Reply Quote 0
                                    @Dracarys As in updating to 2.24.0?
                                    Those are the best kind.
                                      @Dracarys I want to dig in to sensor projects myself. I looked at that DHT sensor and I think it is using SPI so maybe other sensors using same interface might be amenable to using module as a building block.
                                        Jonae @Dracarys
                                        @Dracarys mine is still broken, updated MM to version 2.24.0 and still not working. Any solution?
                                          ankonaskiff17 @Jonae
                                          @Jonae How many wires on sensor? 3 or 4? There are some DHT sensors with 4, some with 3.
                                          If it is 4, and/or you know it is I2C ,try running ```sudo i2cdetect -y 1’‘’ .
                                          Should spit you out an address 38.
                                          If not I have a 3 wire sensor I can hook up and run through setup. My 3 wire sensor and DHT supposed to be about twins.
                                            Jonae @ankonaskiff17
                                            @ankonaskiff17
                                            I have a 4 wire sensor, eunning sudo i2cdetect -y 1 i am getting an error thet could not open file. Anny sugestions?
