    MMM-Temperature uncaught exception...
    12 Posts 3 Posters 4.1k Views 3 Watching
      Brown19
      I wrote a script to use the SHT31-D temperature and humidity sensor from adafruit. The script works in that it correctly displays the temp and humidity. The log file however shows the following:
      [02.08.2023 19:53.15.002] [LOG] MMM-Temperature: Updating sensor values
      [02.08.2023 19:53.15.002] [LOG] MMM-Temperature Calling: /home/mpi-admin/MagicMirror/modules/MMM-Temperature/scripts/sht31
      [02.08.2023 19:53.15.338] [LOG] {“temperature_c”:24.78637369344625,“humidity”:42.03402761882963,“temperature_f”:76.61547264820325,“error”:false}
      [02.08.2023 19:53.15.339] [LOG] MMM-Temperature: New Values of sensor with id 0 (Indoor): {“temperature_c”:“24.8”,“humidity”:“42.0”,“temperature_f”:“76.6”,“error”:false,“temperature”:“76.6”}
      [02.08.2023 19:53.15.339] [LOG] Sending temp update: [{“temperature_c”:“24.8”,“humidity”:“42.0”,“temperature_f”:“76.6”,“error”:false,“temperature”:“76.6”}]
      [02.08.2023 19:53.15.346] [ERROR] Whoops! There was an uncaught exception…
      [02.08.2023 19:53.15.362] [ERROR] Error: write EFAULT
      at afterWriteDispatched (node:internal/stream_base_commons:160:15)
      at writeGeneric (node:internal/stream_base_commons:151:3)
      at Socket._writeGeneric (node:net:930:11)
      at Socket._write (node:net:942:8)
      at writeOrBuffer (node:internal/streams/writable:392:12)
      at _write (node:internal/streams/writable:333:10)
      at Writable.write (node:internal/streams/writable:337:10)
      at execSync (node:child_process:981:20)
      at node:electron/js2c/asar_bundle:2:12711
      at Class.updateSensorValues (/home/mpi-admin/MagicMirror/modules/MMM-Temperature/node_helper.js:65:24)
      at Class.socketNotificationReceived (/home/mpi-admin/MagicMirror/modules/MMM-Temperature/node_helper.js:165:12)
      at Socket. (/home/mpi-admin/MagicMirror/js/node_helper.js:104:11)
      at Socket.emit (node:events:513:28)
      at Socket.emitUntyped (/home/mpi-admin/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
      at /home/mpi-admin/MagicMirror/node_modules/socket.io/dist/socket.js:703:39
      at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
      errno: -14,
      code: ‘EFAULT’,
      syscall: ‘write’
      This is my script:
      #!/usr/bin/env python3
      #Install Dependencies:
      #  cd ~
      #  sudo pip3 install --upgrade adafruit-python-shell
      #  wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/raspi-blinka.py
      #  sudo python3 raspi-blinka.py
      #  sudo pip3 install adafruit-circuitpython-sht31d
      import board
      import adafruit_sht31d
      import json
      i2c = board.I2C()
      h = adafruit_sht31d.SHT31D(i2c)
      result = {}
      try:
          result["temperature_c"] = h.temperature
          result["humidity"] = h.relative_humidity
          result["temperature_f"] = (result["temperature_c"]*1.8) + 32
          result["error"] = False
      except:
          result["temperature_c"] = 0.0
          result["humidity"] = 0.0
          result["error"] = True
      print(json.dumps(result))
      Any help would be appreciate. Python is not my native language.
      • wishmaster270W Offline
        wishmaster270 Module Developer @Brown19
        @Brown19 Hi,
        your python script looks good to me and also the output of node_helper till the moment it tries to send the data to the frontend.
        Can you provide your MagicMirror and nodejs version information to me, please?
          wishmaster270 Module Developer @wishmaster270
          @Brown19
          I tried your script and the current version of the module in both of my setups (2.24.0 native and 2.25.0-develop container) and do not have any problems.
          As i wrote already the problem looks like there is problem during communication between the node_helper.js and the frontend (either electron or the browser of your choice).
            Brown19 @wishmaster270
            @wishmaster270 I’m running 2.24.0 and node is v18.17.0
              @Brown19 Do you see any errors in the development console of the browser?
                @Brown19
                today i installed a new instance of MagicMirror 2.24.0 with both your node version 18 any my current used one (16).
                In the installation which uses electron i can reproduce the error now. But i am pretty sure this is a problem related to the combination of the version 2.24.0 and the used electron version.
                I found this thread with the same error but MMM-Tools instead in the forum of bogusnet, too.
                It might be a general MagicMirror issue and not a problem of the module.
                Maybe one of the core developers can have a look into it. I never had been that deep in the MagicMirror code and do not have much time to investigate the problem at the moment.
                  sdetweil @wishmaster270
                  @wishmaster270 what module is this? I’ll look at it tonight.
                    wishmaster270 Module Developer @sdetweil
                    @sdetweil Hi Sam, it looks like both MMM-Temperature and MMM-Tools cause the error.
                      @sdetweil @Brown19
                      i did some more investigation today and think i found a solution.
                      Although the exception looks different i think the problem is the execSync command.
                      The only way i was able to fix it is to use spawnSync.
                      But i can not say where or why the problem happens.
                      I tried different node versions (latest 16, 18, 20) and different electron versions (25.3.0, 25.3.2 and 25.4.0) with execSync.
                      I will release a new version of MMM-Temperature today which uses spawnSync instead of execSync.
                      S wishmaster270W 2 Replies Last reply Reply Quote 1
                        @wishmaster270 good catch. I think exec is foreground, spawn is background.
                          @Brown19
                          Just released the new version 0.0.8 which (hopefully) fixes the problem.
                          I integrated your script, too. But i named it sht31d.
                            @wishmaster270 Thank you so much for the help and troubleshooting! I wasn’t able to work on this the last few days and when I got back it looks fixed.
                            Thanks again.
