    MMM-Temperature uncaught exception...
    12 Posts 3 Posters 2.7k Views 3 Watching
      Brown19 @wishmaster270
      @wishmaster270 I’m running 2.24.0 and node is v18.17.0
      • wishmaster270W Offline
        wishmaster270 Module Developer @Brown19
        @Brown19 Do you see any errors in the development console of the browser?
          wishmaster270 Module Developer @wishmaster270
          @Brown19
          today i installed a new instance of MagicMirror 2.24.0 with both your node version 18 any my current used one (16).
          In the installation which uses electron i can reproduce the error now. But i am pretty sure this is a problem related to the combination of the version 2.24.0 and the used electron version.
          I found this thread with the same error but MMM-Tools instead in the forum of bogusnet, too.
          It might be a general MagicMirror issue and not a problem of the module.
          Maybe one of the core developers can have a look into it. I never had been that deep in the MagicMirror code and do not have much time to investigate the problem at the moment.
            sdetweil @wishmaster270
            @wishmaster270 what module is this? I’ll look at it tonight.
              wishmaster270 Module Developer @sdetweil
              @sdetweil Hi Sam, it looks like both MMM-Temperature and MMM-Tools cause the error.
                @sdetweil @Brown19
                i did some more investigation today and think i found a solution.
                Although the exception looks different i think the problem is the execSync command.
                The only way i was able to fix it is to use spawnSync.
                But i can not say where or why the problem happens.
                I tried different node versions (latest 16, 18, 20) and different electron versions (25.3.0, 25.3.2 and 25.4.0) with execSync.
                I will release a new version of MMM-Temperature today which uses spawnSync instead of execSync.
                S wishmaster270W 2 Replies Last reply Reply Quote 1
                  @wishmaster270 good catch. I think exec is foreground, spawn is background.
                    @Brown19
                    Just released the new version 0.0.8 which (hopefully) fixes the problem.
                    I integrated your script, too. But i named it sht31d.
                      @wishmaster270 Thank you so much for the help and troubleshooting! I wasn’t able to work on this the last few days and when I got back it looks fixed.
                      Thanks again.
