    MMM-Temperature uncaught exception...
    12 Posts 3 Posters 4.2k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @wishmaster270
      @Brown19
      I tried your script and the current version of the module in both of my setups (2.24.0 native and 2.25.0-develop container) and do not have any problems.
      As i wrote already the problem looks like there is problem during communication between the node_helper.js and the frontend (either electron or the browser of your choice).
        Brown19 @wishmaster270
        @wishmaster270 I’m running 2.24.0 and node is v18.17.0
          wishmaster270 Module Developer @Brown19
          @Brown19 Do you see any errors in the development console of the browser?
            @Brown19
            today i installed a new instance of MagicMirror 2.24.0 with both your node version 18 any my current used one (16).
            In the installation which uses electron i can reproduce the error now. But i am pretty sure this is a problem related to the combination of the version 2.24.0 and the used electron version.
            I found this thread with the same error but MMM-Tools instead in the forum of bogusnet, too.
            It might be a general MagicMirror issue and not a problem of the module.
            Maybe one of the core developers can have a look into it. I never had been that deep in the MagicMirror code and do not have much time to investigate the problem at the moment.
              sdetweil @wishmaster270
              @wishmaster270 what module is this? I’ll look at it tonight.
                wishmaster270 Module Developer @sdetweil
                @sdetweil Hi Sam, it looks like both MMM-Temperature and MMM-Tools cause the error.
                  @sdetweil @Brown19
                  i did some more investigation today and think i found a solution.
                  Although the exception looks different i think the problem is the execSync command.
                  The only way i was able to fix it is to use spawnSync.
                  But i can not say where or why the problem happens.
                  I tried different node versions (latest 16, 18, 20) and different electron versions (25.3.0, 25.3.2 and 25.4.0) with execSync.
                  I will release a new version of MMM-Temperature today which uses spawnSync instead of execSync.
                  S wishmaster270W 2 Replies Last reply Reply Quote 1
                    @wishmaster270 good catch. I think exec is foreground, spawn is background.
                      @Brown19
                      Just released the new version 0.0.8 which (hopefully) fixes the problem.
                      I integrated your script, too. But i named it sht31d.
                        @wishmaster270 Thank you so much for the help and troubleshooting! I wasn’t able to work on this the last few days and when I got back it looks fixed.
                        Thanks again.
