    MMM-Temperature uncaught exception...
    12 Posts 3 Posters 3.5k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @Brown19
      @Brown19 Do you see any errors in the development console of the browser?
        wishmaster270 Module Developer @wishmaster270
        @Brown19
        today i installed a new instance of MagicMirror 2.24.0 with both your node version 18 any my current used one (16).
        In the installation which uses electron i can reproduce the error now. But i am pretty sure this is a problem related to the combination of the version 2.24.0 and the used electron version.
        I found this thread with the same error but MMM-Tools instead in the forum of bogusnet, too.
        It might be a general MagicMirror issue and not a problem of the module.
        Maybe one of the core developers can have a look into it. I never had been that deep in the MagicMirror code and do not have much time to investigate the problem at the moment.
          sdetweil @wishmaster270
          @wishmaster270 what module is this? I’ll look at it tonight.
            wishmaster270 Module Developer @sdetweil
            @sdetweil Hi Sam, it looks like both MMM-Temperature and MMM-Tools cause the error.
              @sdetweil @Brown19
              i did some more investigation today and think i found a solution.
              Although the exception looks different i think the problem is the execSync command.
              The only way i was able to fix it is to use spawnSync.
              But i can not say where or why the problem happens.
              I tried different node versions (latest 16, 18, 20) and different electron versions (25.3.0, 25.3.2 and 25.4.0) with execSync.
              I will release a new version of MMM-Temperature today which uses spawnSync instead of execSync.
              S wishmaster270W 2 Replies Last reply Reply Quote 1
                @wishmaster270 good catch. I think exec is foreground, spawn is background.
                  @Brown19
                  Just released the new version 0.0.8 which (hopefully) fixes the problem.
                  I integrated your script, too. But i named it sht31d.
                    Brown19 @wishmaster270
                    @wishmaster270 Thank you so much for the help and troubleshooting! I wasn’t able to work on this the last few days and when I got back it looks fixed.
                    Thanks again.
