    BirdNET-PI-chart on MM2
    Scheduled Pinned Locked Moved Education
    35 Posts 5 Posters 14.5k Views 5 Watching
    • L Offline
      lmhmm @thgmirror
      @thgmirror Blimey that’s a comprehensive answer!
      I’ll have to go my homework. I appreciate your comprehensive reply.
      Many thanks,
      Lorraine
      • bheplerB Offline
        bhepler Module Developer @thgmirror
        @thgmirror - Sorry about that. Somehow, the repository was marked private. I’ve fixed it and it should work for you now.
        • L Offline
          lmhmm @bhepler
          @bhepler hello, I’ve successfully installed your module MMM-BirdNET and set the map to terrain and my Co ordinates etc.
          So while I get up a nice map, there don’t seem to be any stations or dots showing at all. Just a map.
          Also there’s no activity, just a map shows and nothing else.
          Can you advise?
          Lorraine
          • bheplerB Offline
            bhepler Module Developer @lmhmm
            @lmhmm - Absolutely. Let’s get you fixed up. Could you please post the relevant portion of your config.js? I want to try it on my test system and see if I can duplicate your problem.
            L 3 Replies Last reply Reply Quote 0
            • L Offline
              lmhmm @bhepler
              @bhepler Hello Brian,
              Please see the map and config. I have updated the module also and my mirror is up to date 2.24
              Lorraine
              Err not sure how to add the pictures?
              • L Offline
                lmhmm @bhepler
                @bheplerOkay here we go:
                Config:
                module: "MMM-BirdNET position:
                "top_center
                lat: 54.6633, lon: -3.3680, updateInterval: 3600000, popInterval:
                30000,
                dataUrl: “https://birdnet. cornell.edu/map/requeststats/” mapMode:
                “terrain”
                markercolor: “Light Blue” markerDistance: 300, //width:
                “100px”
                //height:
                “100px”
                zoomLevel: 7, //mapurl:
                null,
                • L Offline
                  lmhmm @bhepler
                  @bhepler
                  I hope that means the photo is up too!
                  Lorraine
                  L bheplerB 2 Replies Last reply Reply Quote 0
                  • L Offline
                    lmhmm @lmhmm
                    @lmhmm
                    Hi just wondered if you’d worked out why I’ve got no stations or feed just a map?
                    Thanks,
                    Lorraine
                    mumblebajM 2 Replies Last reply Reply Quote 0
                    • mumblebajM Offline
                      mumblebaj Module Developer @lmhmm
                      @lmhmm Your config looks weird. You missing a bunch of commas.
                      Also, I think you may be getting the following error in the Developers Console (ctrl+shift+i). You can filter on MMM-BirdNET and see if you see the below error.
                        @lmhmm Also, check the dataUrl that you have. I changed it to the one in the module Github and then it worked fine.
                        • 3 / 4
