BirdNET-PI-chart on MM2
I’m interested this and have just set it up on another pi. I am very interested in getting on my mm!
Shall I wait for the module or how did you get it via Smart Web Display?
I’m a beginner.
@lmhmm - The key difference will be, IMHO, which data you want to display. If you want to display the chart from the first post from your own BirdNET-Pi installation, then go with the smart web display. My module will display everyone’s BirdNET hits around you, not just your own.
@thgmirror can probably walk you through setting up the smart web display.
Okay, version 0.1.0 is ready. I think. Give it a go and let me know if you encounter any problems.
@bhepler 404 when I try the link
@lmhmm
Currently, I’m using an RPI4 with BirdNET-Pi outside in the garden and an RPI3b as MM2. Both are in the same WIFI-net. Best is to use the standard-installation of BirdNET-Pi and to use the recommended names.- install MMM-EasyPix at MM2
- add MMM-EasyPix to your config.js with birdnet.png as the name of the picture
- add the following code to a file called
makedownloadbirdnet.py at the root-folder of MM2
sudo nano makedownloadbirdnet.py
#!/usr/bin/python # coding:utf-8 # import os import urllib.request import datetime current_date = datetime.date.today() url = "http://birdnetpi.local/Charts/Combo-" + str(current_date) + ".png" nix = "/home/pi/MagicMirror/modules/keinbild.png" out = "/home/pi/MagicMirror/modules/MMM-EasyPix/pix/birdnet.png" # Prüfen, ob es bereits eine Datei out im Verzeichnis gibt if os.path.exists(out): # alte Datei löschen os.remove(out) # Herunterladen der Datei try: urllib.request.urlretrieve(url, out) except: os.system(f'cp "{nix}" "{out}"')- Create a small picture with a hint, that a chart is not available, name it keinbild.png and store it in the modules-folder at MM2.
- Create a cronjob at MM2:
* * * * sudo python3 makedownloadbirdnet.py -
@thgmirror Blimey that’s a comprehensive answer!
I’ll have to go my homework. I appreciate your comprehensive reply.
Many thanks,
Lorraine
@thgmirror - Sorry about that. Somehow, the repository was marked private. I’ve fixed it and it should work for you now.
@bhepler hello, I’ve successfully installed your module MMM-BirdNET and set the map to terrain and my Co ordinates etc.
So while I get up a nice map, there don’t seem to be any stations or dots showing at all. Just a map.
Also there’s no activity, just a map shows and nothing else.
Can you advise?
Lorraine
@lmhmm - Absolutely. Let’s get you fixed up. Could you please post the relevant portion of your
config.js? I want to try it on my test system and see if I can duplicate your problem. -
@bhepler Hello Brian,
Please see the map and config. I have updated the module also and my mirror is up to date 2.24
Lorraine
Err not sure how to add the pictures?
@bheplerOkay here we go:
Config:
module: "MMM-BirdNET position:
"top_center
lat: 54.6633, lon: -3.3680, updateInterval: 3600000, popInterval:
30000,
dataUrl: “https://birdnet. cornell.edu/map/requeststats/” mapMode:
“terrain”
markercolor: “Light Blue” markerDistance: 300, //width:
“100px”
//height:
“100px”
zoomLevel: 7, //mapurl:
null, -
Hi just wondered if you’d worked out why I’ve got no stations or feed just a map?
Thanks,
Lorraine
@lmhmm Your config looks weird. You missing a bunch of commas.
Also, I think you may be getting the following error in the Developers Console (ctrl+shift+i). You can filter on MMM-BirdNET and see if you see the below error.
@lmhmm Also, check the dataUrl that you have. I changed it to the one in the module Github and then it worked fine.
@lmhmm - My apologies for the delay in responding. I’ve been out of the country for the past couple of weeks. I’ll get to your issue this weekend.
Hmm. It appears that the BirdNET website is down at the present time. There’s not much I can do about that. Which is weird, as it was definitely working yesterday and earlier today.
As soon as it comes up, I’ll troubleshoot the config that @lmhmm posted.
So maybe I’ve got the wrong url? Can you advise the correct one? I thought I’d copied it direct? The code is my phone’s interpretation from a picture. There are no config errors as my mirror runs okays. It seems it’s maybe the url.
Please advise,
Thank you, I really appreciate your help,
Lorraine
@lmhmm - The good news is that BirdNET appears to be back up. The better news is that if you do not include the
dataUrlparameter, the default value should just make it work without issue. For example, here is my config that I am currently using for testing:{ module: "MMM-BirdNET", position: "bottom_left", config: { popInterval: 15 * 1000, popDelay: 2 * 1000, markerColor: 'IndianRed', } },I looked at the config snippet you posted and the immediate thing I noticed is that you do not appear to have a comma after the URL you specified for the
dataUrlparameter. If that is the case, then all sorts of weird things could happen.I suggest that you copy & paste the
config.jssnippet I included above into yourconfig.jsand work from there. The lat & lon parameters you included in your post look good. You should be able to include those without issue. You’re pretty close to having it work the way you want. We should be able to get you up & running with little hassle. -
T thgmirror referenced this topic on
After installing the latest version and removing the data url it now works! I just need to limit it to the area I particularly want rather than all Britain.
Many thanks, it’s a joy,
Lorraine
