    BirdNET-PI-chart on MM2
    Scheduled Pinned Locked Moved Education
    35 Posts 5 Posters 22.5k Views 5 Watching
      bhepler Module Developer @thgmirror
      @thgmirror - Sorry about that. Somehow, the repository was marked private. I’ve fixed it and it should work for you now.
      L 1 Reply Last reply
      • L
        lmhmm @bhepler
        @bhepler hello, I’ve successfully installed your module MMM-BirdNET and set the map to terrain and my Co ordinates etc.
        So while I get up a nice map, there don’t seem to be any stations or dots showing at all. Just a map.
        Also there’s no activity, just a map shows and nothing else.
        Can you advise?
        Lorraine
        B 1 Reply Last reply
          bhepler Module Developer @lmhmm
          @lmhmm - Absolutely. Let’s get you fixed up. Could you please post the relevant portion of your config.js? I want to try it on my test system and see if I can duplicate your problem.
          L 3 Replies Last reply
          • L
            lmhmm @bhepler
            @bhepler Hello Brian,
            Please see the map and config. I have updated the module also and my mirror is up to date 2.24
            Lorraine
            Err not sure how to add the pictures?
            • L
              lmhmm @bhepler
              @bheplerOkay here we go:
              Config:
              module: "MMM-BirdNET position:
              "top_center
              lat: 54.6633, lon: -3.3680, updateInterval: 3600000, popInterval:
              30000,
              dataUrl: “https://birdnet. cornell.edu/map/requeststats/” mapMode:
              “terrain”
              markercolor: “Light Blue” markerDistance: 300, //width:
              “100px”
              //height:
              “100px”
              zoomLevel: 7, //mapurl:
              null,
              • L
                lmhmm @bhepler
                @bhepler
                I hope that means the photo is up too!
                Lorraine
                L B 2 Replies Last reply
                • L
                  lmhmm @lmhmm
                  @lmhmm
                  Hi just wondered if you’d worked out why I’ve got no stations or feed just a map?
                  Thanks,
                  Lorraine
                  mumblebajM 2 Replies Last reply
                  • mumblebajM
                    mumblebaj Module Developer @lmhmm
                    @lmhmm Your config looks weird. You missing a bunch of commas.
                    Also, I think you may be getting the following error in the Developers Console (ctrl+shift+i). You can filter on MMM-BirdNET and see if you see the below error.
                    • mumblebajM
                      @lmhmm Also, check the dataUrl that you have. I changed it to the one in the module Github and then it worked fine.
                        @lmhmm - My apologies for the delay in responding. I’ve been out of the country for the past couple of weeks. I’ll get to your issue this weekend.
                          Hmm. It appears that the BirdNET website is down at the present time. There’s not much I can do about that. Which is weird, as it was definitely working yesterday and earlier today.
                          As soon as it comes up, I’ll troubleshoot the config that @lmhmm posted.
                          • L
                            lmhmm @bhepler
                            @bhepler
                            So maybe I’ve got the wrong url? Can you advise the correct one? I thought I’d copied it direct? The code is my phone’s interpretation from a picture. There are no config errors as my mirror runs okays. It seems it’s maybe the url.
                            Please advise,
                            Thank you, I really appreciate your help,
                            Lorraine
                              @lmhmm - The good news is that BirdNET appears to be back up. The better news is that if you do not include the dataUrl parameter, the default value should just make it work without issue. For example, here is my config that I am currently using for testing:
                              	module: "MMM-BirdNET",
                              	position: "bottom_left",
                              		popInterval: 15 * 1000,
                              		popDelay: 2 * 1000,
                              		markerColor: 'IndianRed',
                              I looked at the config snippet you posted and the immediate thing I noticed is that you do not appear to have a comma after the URL you specified for the dataUrl parameter. If that is the case, then all sorts of weird things could happen.
                              I suggest that you copy & paste the config.js snippet I included above into your config.js and work from there. The lat & lon parameters you included in your post look good. You should be able to include those without issue. You’re pretty close to having it work the way you want. We should be able to get you up & running with little hassle.
                              • thgmirrorT thgmirror referenced this topic on
                              • L
                                lmhmm @bhepler
                                After installing the latest version and removing the data url it now works! I just need to limit it to the area I particularly want rather than all Britain.
                                Many thanks, it’s a joy,
                                Lorraine
