    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 21.0k Views 4 Watching
    • MichMichM Offline
      MichMich
      It somehow probably starts multiple instances. Disable the auto start and try to get it working manually first.
      • T Offline
        trividar
        how can I do that?
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich @trividar
          @trividar pm2 stop mm
          check if it’s running pm2 list
          No instances should be running at that point. then start the MM using npm start from your MagicMirror folder from a terminal running on your PI (so not via SSH)
          • paviroP Offline
            paviro
            Moved this part of the topic into a new thread since it has nothing to do with the module.
            We're all stories in the end. Just make it a good one, eh?
            – The Doctor
            • T Offline
              trividar
              If i stop with pm2 stop mm and start my MM with npm start from terminal everything works fine, but without the PIR sensor. If i connect the sensor to my pi i get the blackscreen.
              • MichMichM Offline
                MichMich @paviro
                @paviro See the replay in the other topic. It seems it has something to do with the module.
                • paviroP Offline
                  paviro
                  Strange no idea what could case that. Will check back…
                  – The Doctor
                  • T Offline
                    trividar
                    Thank you both for your help!
                    How can I disable completely the MM autostart?
                    • T Offline
                      trividar
                      and just to be 100% sure if its so right? 0_1465119368006_22c286dc-79a4-4cdc-a708-a9a20a6325ed.jpg
                      • paviroP Offline
                        paviro
                        Looks fine. The thing that I don’t understand is how connection this could lead to a seconds start of a MM instance…
                        – The Doctor
                        • 2 / 3
