    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 20.7k Views 4 Watching
    • T Offline
      trividar
      did someone find any solution for my problem? i tried to delete the PIR-Modul and reinstall… but I have the same problem;o( THX
      • T Offline
        trividar
        So i tried to fix my problem with the PIR sensor. Now I have an other problem. Do someone knew what i do wrong? Now the PIR shut down HDMI if they detect a motion and I don’t have a chance to turn on just with a reboot of the pi.
        youtube
        Sorry for the bad quality!
        • BangeeB Offline
          Bangee Module Developer
          I’ve reinstalled mm2 on a new SD Card and copied all my modules up en it.
          Now I’ve got this error message with MMM-PIR-Module:
          mm-0 App threw an error during load
          mm-0 Error: Module version mismatch. Expected 49, got 48.
          mm-0     at Error (native)
          mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
          mm-0     at Object.Module._extensions..node (module.js:568:18)
          mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
          mm-0     at Module.load (module.js:458:32)
          mm-0     at tryModuleLoad (module.js:417:12)
          mm-0     at Function.Module._load (module.js:409:3)
          mm-0     at Module.require (module.js:468:17)
          mm-0     at require (internal/module.js:20:19)
          mm-0     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/lib/exports.js:1:97)
          mm-0 Whoops! There was an uncaught exception...
          mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          mm-0 Launching application.
          Any ideas?
          • C Offline
            Chiggo
            Not sure, but isn’t there a wiring mismatch in the picture of your post?
            Think you mixed up brown and orange.
            Orange (VCC), coming from PIR-Sensor, should go to PIN2 and brown (GND), coming from PIR, should go to PIN6.
            To your last post:
            I would prefer to add the modules from github, not copy.
            Are the libraries and drivers for wiring-pi already installed?
            • BangeeB Offline
              WiringPi should be installed. I’ve tested this using this command: gipo readall
              The module is now installed using git. not copied.
              I’ve tried to rebuild… and also to rebulid electron.
              npm install --save-dev electron-rebuild
              • paviroP Offline
                paviro
                Module mismatch should be resolved now :)
                We're all stories in the end. Just make it a good one, eh?
                – The Doctor
                • 3 / 3
