Solved Error starting after upgrade
Just got a chance to work on this again. Tried doing both upgrade scripts (again) and I’m getting the same results. I reviewed the upgrade.log file but nothing is jumping out at me (full log from today’s efforts below). The only items that seem like they didn’t go as intended are a few modules that may have been partially skipped in the upgrade process (“skipped processing for…” MMM-Wallpaper, MMM-connection-status, MMM-Remote-Control, MMM-BurinIn), but I don’t think those would be related to the problems I’m experiencing when trying to start MM. I may remove those from my config.js file to see in anything changes. Other ideas?
(Apologies for the section of large text below, I can’t figure out why it’s doing that and how to fix it)
Upgrade started - Sun Oct 15 18:17:56 PDT 2023
system is Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
doing test run = true, NO updates will be applied!
[96mCheck current Node installation …[0m
[0mNode currently installed. Checking version number.
[0mMinimum Node version: [1mv20.8.0[0m
[0mInstalled Node version: [1mv20.8.0[0m
[92mNo Node.js upgrade necessary.[0m
[96mCheck current NPM installation …[0m
[0mNPM currently installed. Checking version number.
[0mMinimum npm version: [1mV10.1.0[0m
[0mInstalled npm version: [1mV10.1.0[0m
[92mNo npm upgrade necessary.[0msaving custom.css
remote name = origin
upgrading from version 2.25.0 to 2.25.0
fetching latest revisions
git fetch rc=0
current branch = master
On branch master
Your branch is up to date with ‘origin/master’.Changes not staged for commit:
(use “git add/rm …” to update what will be committed)
(use “git restore …” to discard changes in working directory)
modified: modules/default/alert/templates/alert.njk
modified: modules/default/alert/templates/notification.njk
modified: modules/default/calendar/calendar.js
modified: modules/default/calendar/calendarfetcher.js
modified: modules/default/calendar/calendarfetcherutils.js
modified: modules/default/compliments/compliments.js
modified: modules/default/helloworld/helloworld.njk
modified: modules/default/newsfeed/fullarticle.njk
modified: modules/default/newsfeed/newsfeed.njk
modified: modules/default/newsfeed/newsfeedfetcher.js
modified: modules/default/newsfeed/oldconfig.njk
modified: modules/default/updatenotification/node_helper.js
modified: modules/default/updatenotification/updatenotification.njk
modified: modules/default/weather/current.njk
modified: modules/default/weather/forecast.njk
modified: modules/default/weather/hourly.njk
modified: modules/default/weather/providers/openweathermap.js
deleted: modules/default/weather/providers/overrideWrapper.js
modified: modules/default/weather/providers/weathergov.js
modified: modules/default/weather/providers/yr.js
modified: modules/default/weather/weather.js
modified: modules/default/weather/weatherprovider.js
modified: package-lock.json
modified: package.jsonUntracked files:
(use “git add …” to include in what will be committed)
core
css/save_custom.cssno changes added to commit (use “git add” and/or “git commit -a”)
there are 23 local files that are different than the master repomodules/default/alert/templates/alert.njk
package-lock.json
package.jsonsave/restore files selection = n
restoring modules/default/alert/templates/alert.njk from repo
skipping restore for modules/default/alert/templates/alert.njk, doing test run
restoring modules/default/alert/templates/notification.njk from repo
skipping restore for modules/default/alert/templates/notification.njk, doing test run
restoring modules/default/calendar/calendar.js from repo
skipping restore for modules/default/calendar/calendar.js, doing test run
restoring modules/default/calendar/calendarfetcher.js from repo
skipping restore for modules/default/calendar/calendarfetcher.js, doing test run
restoring modules/default/calendar/calendarfetcherutils.js from repo
skipping restore for modules/default/calendar/calendarfetcherutils.js, doing test run
restoring modules/default/compliments/compliments.js from repo
skipping restore for modules/default/compliments/compliments.js, doing test run
restoring modules/default/helloworld/helloworld.njk from repo
skipping restore for modules/default/helloworld/helloworld.njk, doing test run
restoring modules/default/newsfeed/fullarticle.njk from repo
skipping restore for modules/default/newsfeed/fullarticle.njk, doing test run
restoring modules/default/newsfeed/newsfeed.njk from repo
skipping restore for modules/default/newsfeed/newsfeed.njk, doing test run
restoring modules/default/newsfeed/newsfeedfetcher.js from repo
skipping restore for modules/default/newsfeed/newsfeedfetcher.js, doing test run
restoring modules/default/newsfeed/oldconfig.njk from repo
skipping restore for modules/default/newsfeed/oldconfig.njk, doing test run
restoring modules/default/updatenotification/node_helper.js from repo
skipping restore for modules/default/updatenotification/node_helper.js, doing test run
restoring modules/default/updatenotification/updatenotification.njk from repo
skipping restore for modules/default/updatenotification/updatenotification.njk, doing test run
restoring modules/default/weather/current.njk from repo
skipping restore for modules/default/weather/current.njk, doing test run
restoring modules/default/weather/forecast.njk from repo
skipping restore for modules/default/weather/forecast.njk, doing test run
restoring modules/default/weather/hourly.njk from repo
skipping restore for modules/default/weather/hourly.njk, doing test run
restoring modules/default/weather/providers/openweathermap.js from repo
skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
restoring modules/default/weather/providers/weathergov.js from repo
skipping restore for modules/default/weather/providers/weathergov.js, doing test run
restoring modules/default/weather/providers/yr.js from repo
skipping restore for modules/default/weather/providers/yr.js, doing test run
restoring modules/default/weather/weather.js from repo
skipping restore for modules/default/weather/weather.js, doing test run
restoring modules/default/weather/weatherprovider.js from repo
skipping restore for modules/default/weather/weatherprovider.js, doing test run
restoring package-lock.json from repo
skipping restore for package-lock.json, doing test run
restoring package.json from repo
skipping restore for package.json, doing test run
test merge result rc=‘’ , if empty, no conflicts
skipping merge, only test run
Checking for modules with removed libraries
downloading dumpactivemodules script**processing dependency changes for active modules with package.json files
processing for module MMM-Wallpaper please waitskipped processing for MMM-Wallpaper, doing test run
processing complete for module MMM-Wallpaper
processing for module MMM-connection-status please waitskipped processing for MMM-connection-status, doing test run
processing complete for module MMM-connection-status
processing for module MMM-Remote-Control please waitskipped processing for MMM-Remote-Control, doing test run
processing complete for module MMM-Remote-Control
processing for module MMM-BurnIn please waitskipped processing for MMM-BurnIn, doing test run
processing complete for module MMM-BurnIn**
restoring custom.css
removing git alias
Upgrade ended - Sun Oct 15 18:18:11 PDT 2023Upgrade started - Sun Oct 15 18:19:04 PDT 2023
user requested to apply changes
doing test run = false
local version 2.25.0 already same as master 2.25.0
removing git alias
Upgrade ended - Sun Oct 15 18:19:08 PDT 2023 -
@rmcon said in Error starting after upgrade:
Codename: bullseye
doing test run = true, NO updates will be applied!this is the test run.
upgrade is a two.part process
everyone puts lots of energy into building their mirrors.
last thing my script needs to do is screw it up.
so test run let’s you get an idea if there are any issues you need to fix BEFORE making any changesthe second run (with the apply parameter)
actually DOES the update.however, I will NOT upgrade a system already upgraded by default
IF you need to force the upgrade process over the same version, then change the parm apply to force
I did the test upgrade then followed it with the apply parameter.@rmcon said in Error starting after upgrade:
doing test run = falseAt this point, I think my only option is to try the force option. Worst case scenario, if I can’t revive the current version, I’ll try to remove MM and start fresh. I think I’ve got the important bits saved somewhere else to make the job a little easier.
I really do appreciate your help with this, as it is not my forte.
@rmcon show me the rest of the upgrade.log
@rmcon you can use my backup/restore scripts
It was in the previous post, about 2/3 of the way down, just below the obnoxiously large text.@rmcon said in Error starting after upgrade:
saving custom.css
removing git alias
Upgrade ended - Sun Oct 15 18:19:08 PDT 2023Also, I appreciate the backup and restore info, will look into that before I move ahead.
yes you have to use force instead of apply
Force update complete. MM still not working properly, but it’s something different, which I’ll call progress.
[ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
(Full text below)I see some answers for ‘node-fetch’ in topic #18055, but I’m not sure if that fix will work on this problem. I’m still digging around, but not seeing this exact problem so far. Thanks.
magicmirror@2.25.0 start
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[15.10.2023 20:57.06.757] [LOG] Starting MagicMirror: v2.25.0
[15.10.2023 20:57.06.798] [LOG] Loading config …
[15.10.2023 20:57.06.803] [DEBUG] config template file not exists, no envsubst
[15.10.2023 20:57.06.851] [LOG] Loading module helpers …
[15.10.2023 20:57.06.884] [LOG] No helper found for module: alert.
[15.10.2023 20:57.07.124] [LOG] Initializing new module helper …
[15.10.2023 20:57.07.126] [LOG] Module helper loaded: updatenotification
[15.10.2023 20:57.07.145] [LOG] No helper found for module: clock.
[15.10.2023 20:57.08.647] [LOG] Initializing new module helper …
[15.10.2023 20:57.08.648] [LOG] Module helper loaded: calendar
[15.10.2023 20:57.08.650] [LOG] No helper found for module: MMM-MonthlyCalendar.
[15.10.2023 20:57.08.651] [LOG] No helper found for module: weather.
[15.10.2023 20:57.11.743] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
Require stack:- /home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js
- /home/rmco01/MagicMirror/js/app.js
- /home/rmco01/MagicMirror/js/electron.js
- /home/rmco01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
- at node:internal/modules/cjs/loader:1084:15
at Function. (node:electron/js2c/browser_init:2:117419)
at Module._resolveFilename (/home/rmco01/MagicMirror/node_modules/module-alias/index.js:49:29)
at node:internal/modules/cjs/loader:929:27
at Function._load (node:electron/js2c/asar_bundle:2:13327)
at Module.require (node:internal/modules/cjs/loader:1150:19)
at require (node:internal/modules/cjs/helpers:110:18)
at Object. (/home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
at Module._compile (node:internal/modules/cjs/loader:1271:14)
at Object…js (node:internal/modules/cjs/loader:1326:10)
at Module.load (node:internal/modules/cjs/loader:1126:32)
at node:internal/modules/cjs/loader:967:12
at loadModule (/home/rmco01/MagicMirror/js/app.js:180:19)
(removed remainder, same spam messages as previous)
Require stack:/home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js
yes we removed some libs as fetch is built-in in node 18 up.
that module has a fix
go to the MMM-Wallpaper folder (check spelling)
git pull
to updatethen restart mm
We’re up and running! Thank you so much for your patience. I have learned a lot from this go round and I’m hoping that the next update will go much smoother. I still don’t fully understand how to check the test run for compatibility with my configuration before applying the changes, but I have a little time to get smarter before the next update. Have a great rest of your week.
