    Error starting after upgrade
    41 Posts 5 Posters 17.4k Views 5 Watching
    • W
      wwats @sdetweil
      @sdetweil i’m very sorry but i don’t understand this and what i have exactly to do… Can you explain it in a different way?
        sdetweil @wwats
        @wwats
        type the command
        which node
        and show the output
        W 1 Reply Last reply Reply Quote 1
        • W
          wwats @sdetweil
          ok i understand - output is
          /usr/bin/node
          maybe is this important: i work directly on my raspberry with ssh
            sdetweil @wwats
            @wwats ok, lets run this
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
            • W
              wwats @sdetweil
              Everything works :thumbs_up: :thumbs_up: ! Thank You very much - so the mirror is running again. Can I something do for You?
                sdetweil @wwats
                @wwats said in Error starting after upgrade:
                no… i just like to help…
                • W
                  wwats @sdetweil
                  @sdetweil said in Error starting after upgrade:
                  thank you so much :folded_hands_light_skin_tone:
                    rmcon
                    Sam,
                    I’m having similar problems since the recent upgrade. Big disclaimer here that I’m also not the savviest with technology, but was able to get the MM up and running with 95% of what I envisioned and I’m adventurous enough to try and find solutions before asking questions.
                    I have been searching and attempting various ways to fix my issues, which I fear may have made this more complex to solve (i.e. attempted to reinstall the newest upgrades both using your script and manually, everything I found short of using the “force” option). My previous attempts have been working directly on the Pi with keyboard, currently attempting via SSH with same results so far.
                    I’m at a crossroads in my mind now and I’m hoping you can provide steering. Have I gunked this up so much that I should remove and reinstall MM (keeping copes of the previously working config.js, custom.css, and modules folders that I saved on the Pi desktop to try and make the reinstall easier) or can this be fixed? Second concern is that now I’m very hesitant to attempt future upgrades after dealing with this issue (and being far beyond my own capabilities). Any tips or tricks to avoid this in the future?
                    I tried the steps above in this thread with the following results:
                    • “n” and “nvm”, got messages that “command not found” (both in the main folder and MM folder)
                    • “sudo n prune” and “sudo n uninstall”, similar message “sudo n: command not found” (both in main and MM folders)
                    • “node -v” gave me “v20.8.0” (I have ran your script for the node update several times now)
                    • “ls-laf…” method to find the usr/bin location didn’t work (“no such file or directory”, both main and MM folders attempted), but “which node” DID work, showed “/usr/bin/node”
                    Just re-ran the script you linked above and still seeing the same results, posted below. (I used “npm start”, was using pm2 to auto start MM before the upgrade.)
                    magicmirror@2.25.0 start
                    [10.10.2023 03:10.39.346] [LOG] Starting MagicMirror: v2.25.0
                    [10.10.2023 03:10.39.359] [LOG] Loading config …
                    [10.10.2023 03:10.39.371] [DEBUG] config template file not exists, no envsubst
                    [10.10.2023 03:10.39.384] [LOG] Loading module helpers …
                    [10.10.2023 03:10.39.391] [LOG] No helper found for module: alert.
                    [10.10.2023 03:10.39.463] [LOG] Initializing new module helper …
                    [10.10.2023 03:10.39.465] [LOG] Module helper loaded: updatenotification
                    [10.10.2023 03:10.39.473] [LOG] No helper found for module: clock.
                    [10.10.2023 03:10.39.490] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                    Require stack:
                    • /home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js
                    • /home/rmco01/MagicMirror/modules/default/calendar/node_helper.js
                    • /home/rmco01/MagicMirror/js/app.js
                    • /home/rmco01/MagicMirror/js/electron.js
                    • /home/rmco01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                    • at node:internal/modules/cjs/loader:1084:15
                      at Function. (node:electron/js2c/browser_init:2:117419)
                      at Module._resolveFilename (/home/rmco01/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at node:internal/modules/cjs/loader:929:27
                      at Function._load (node:electron/js2c/asar_bundle:2:13327)
                      at Module.require (node:internal/modules/cjs/loader:1150:19)
                      at require (node:internal/modules/cjs/helpers:110:18)
                      at Object. (/home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js:9:16)
                      at Module._compile (node:internal/modules/cjs/loader:1271:14)
                      at Object…js (node:internal/modules/cjs/loader:1326:10)
                      at Module.load (node:internal/modules/cjs/loader:1126:32)
                      at node:internal/modules/cjs/loader:967:12
                      at Object. (/home/rmco01/MagicMirror/modules/default/calendar/node_helper.js:9:25)
                      (Use electron --trace-warnings ... to show where the warning was created)
                      [10.10.2023 03:10.39.492] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      [26678:1010/031040.523164:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                      MESA-LOADER: failed to retrieve device information
                    I understand that the weblink and MESA-LOADER messages are from some relegated elements which aren’t around anymore and just nuisance messages.
                    My previous efforts were trying to find a solution to the “digest-fetch” module, since that appears to be the main problem that I see. I have previously attempted to fix the “envsubst” debug message using guidance in other threads, which either didn’t work, or has been undone by my repeated attempts to solve this problem.
                    Apologies for the long and rambling note, just wanted to give as much detail that may be useful. Thank you!
                      sdetweil @rmcon
                      @rmcon said in Error starting after upgrade:
                      this is the prior release code
                      which means you didn’t run the upgrade
                      either my script or the manual upgrade
                      note my script is 2 part, test and run a second time w a parameter to actually do the upgrade
                        rmcon @sdetweil
                        I’m a little confused regarding the two separate scripts. I thought the updates were necessary, not optional and didn’t understand why would there be a test run script if the changes need to be applied. In other words, I figured the first script that doesn’t actually apply changes was just extra effort… Is the intent to make sure the update works with the user’s specific MM configuration?
                        I tried the trial run the first time and I don’t recall if I could tell there were any changes, so I tried the second script to actually make changes.
                        So, I just tried running the “test” script again, the one thing I did differently is to say “No” when asked if I wanted to keep 23 files that are different than the master (last time I said “Yes”).
                        Just tried starting MM again, getting the same error. Since the test run didn’t give me any better results, I went ahead and tried the script to apply changes. Same result as before.
                        The current version is 2.25.0, right? I see that stated in the terminal window:
                        rmco01@raspberrypi:~/MagicMirror $ npm start
                        [10.10.2023 19:39.57.465] [LOG] Starting MagicMirror: v2.25.0
                        [10.10.2023 19:39.57.476] [LOG] Loading config …
                        [10.10.2023 19:39.57.485] [DEBUG] config template file not exists, no envsubst
                        [10.10.2023 19:39.57.495] [LOG] Loading module helpers …
                        [10.10.2023 19:39.57.507] [LOG] No helper found for module: alert.
                        [10.10.2023 19:39.57.568] [LOG] Initializing new module helper …
                        [10.10.2023 19:39.57.569] [LOG] Module helper loaded: updatenotification
                        [10.10.2023 19:39.57.578] [LOG] No helper found for module: clock.
                        [10.10.2023 19:39.57.592] [ERROR] (node:7168) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                        Require stack:
                        (remainder truncated since it appears to be the same as previously reported)
                        Is there some other step that I’m missing? When you say “run a second time w a parameter to actually do the upgrade,” the parameter you’re referring to is “apply” at the end of the link/script, correct? Or am I supposed to do something else in MM or the config file to make it take effect?
                          rmcon @rmcon
                          Just got a chance to work on this again. Tried doing both upgrade scripts (again) and I’m getting the same results. I reviewed the upgrade.log file but nothing is jumping out at me (full log from today’s efforts below). The only items that seem like they didn’t go as intended are a few modules that may have been partially skipped in the upgrade process (“skipped processing for…” MMM-Wallpaper, MMM-connection-status, MMM-Remote-Control, MMM-BurinIn), but I don’t think those would be related to the problems I’m experiencing when trying to start MM. I may remove those from my config.js file to see in anything changes. Other ideas?
                          (Apologies for the section of large text below, I can’t figure out why it’s doing that and how to fix it)
                          Upgrade started - Sun Oct 15 18:17:56 PDT 2023
                          system is Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                          Check current Node installation …
                          Minimum Node version: v20.8.0
                          Installed Node version: v20.8.0
                          No Node.js upgrade necessary.
                          Check current NPM installation …
                          Minimum npm version: V10.1.0
                          Installed npm version: V10.1.0
                          No npm upgrade necessary.
                          saving custom.css
                          remote name = origin
                          upgrading from version 2.25.0 to 2.25.0
                          fetching latest revisions
                          git fetch rc=0
                          current branch = master
                          On branch master
                          Your branch is up to date with ‘origin/master’.
                          (use “git add/rm …” to update what will be committed)
                          (use “git restore …” to discard changes in working directory)
                          modified: modules/default/alert/templates/alert.njk
                          modified: modules/default/alert/templates/notification.njk
                          modified: modules/default/calendar/calendar.js
                          modified: modules/default/calendar/calendarfetcher.js
                          modified: modules/default/calendar/calendarfetcherutils.js
                          modified: modules/default/compliments/compliments.js
                          modified: modules/default/helloworld/helloworld.njk
                          modified: modules/default/newsfeed/fullarticle.njk
                          modified: modules/default/newsfeed/newsfeed.njk
                          modified: modules/default/newsfeed/newsfeedfetcher.js
                          modified: modules/default/newsfeed/oldconfig.njk
                          modified: modules/default/updatenotification/node_helper.js
                          modified: modules/default/updatenotification/updatenotification.njk
                          modified: modules/default/weather/current.njk
                          modified: modules/default/weather/forecast.njk
                          modified: modules/default/weather/hourly.njk
                          modified: modules/default/weather/providers/openweathermap.js
                          deleted: modules/default/weather/providers/overrideWrapper.js
                          modified: modules/default/weather/providers/weathergov.js
                          modified: modules/default/weather/providers/yr.js
                          modified: modules/default/weather/weather.js
                          modified: modules/default/weather/weatherprovider.js
                          modified: package-lock.json
                          modified: package.json
                          Untracked files:
                          (use “git add …” to include in what will be committed)
                          core
                          css/save_custom.css
                          no changes added to commit (use “git add” and/or “git commit -a”)
                          there are 23 local files that are different than the master repo
                          package-lock.json
                          package.json
                          save/restore files selection = n
                          restoring modules/default/alert/templates/alert.njk from repo
                          skipping restore for modules/default/alert/templates/alert.njk, doing test run
                          restoring modules/default/alert/templates/notification.njk from repo
                          skipping restore for modules/default/alert/templates/notification.njk, doing test run
                          restoring modules/default/calendar/calendar.js from repo
                          skipping restore for modules/default/calendar/calendar.js, doing test run
                          restoring modules/default/calendar/calendarfetcher.js from repo
                          skipping restore for modules/default/calendar/calendarfetcher.js, doing test run
                          restoring modules/default/calendar/calendarfetcherutils.js from repo
                          skipping restore for modules/default/calendar/calendarfetcherutils.js, doing test run
                          restoring modules/default/compliments/compliments.js from repo
                          skipping restore for modules/default/compliments/compliments.js, doing test run
                          restoring modules/default/helloworld/helloworld.njk from repo
                          skipping restore for modules/default/helloworld/helloworld.njk, doing test run
                          restoring modules/default/newsfeed/fullarticle.njk from repo
                          skipping restore for modules/default/newsfeed/fullarticle.njk, doing test run
                          restoring modules/default/newsfeed/newsfeed.njk from repo
                          skipping restore for modules/default/newsfeed/newsfeed.njk, doing test run
                          restoring modules/default/newsfeed/newsfeedfetcher.js from repo
                          skipping restore for modules/default/newsfeed/newsfeedfetcher.js, doing test run
                          restoring modules/default/newsfeed/oldconfig.njk from repo
                          skipping restore for modules/default/newsfeed/oldconfig.njk, doing test run
                          restoring modules/default/updatenotification/node_helper.js from repo
                          skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                          restoring modules/default/updatenotification/updatenotification.njk from repo
                          skipping restore for modules/default/updatenotification/updatenotification.njk, doing test run
                          restoring modules/default/weather/current.njk from repo
                          skipping restore for modules/default/weather/current.njk, doing test run
                          restoring modules/default/weather/forecast.njk from repo
                          skipping restore for modules/default/weather/forecast.njk, doing test run
                          restoring modules/default/weather/hourly.njk from repo
                          skipping restore for modules/default/weather/hourly.njk, doing test run
                          restoring modules/default/weather/providers/openweathermap.js from repo
                          skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                          restoring modules/default/weather/providers/weathergov.js from repo
                          skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                          restoring modules/default/weather/providers/yr.js from repo
                          skipping restore for modules/default/weather/providers/yr.js, doing test run
                          restoring modules/default/weather/weather.js from repo
                          skipping restore for modules/default/weather/weather.js, doing test run
                          restoring modules/default/weather/weatherprovider.js from repo
                          skipping restore for modules/default/weather/weatherprovider.js, doing test run
                          restoring package-lock.json from repo
                          skipping restore for package-lock.json, doing test run
                          restoring package.json from repo
                          skipping restore for package.json, doing test run
                          test merge result rc=‘’ , if empty, no conflicts
                          skipping merge, only test run
                          downloading dumpactivemodules script
                          **processing dependency changes for active modules with package.json files
                          processing for module MMM-Wallpaper please wait
                          skipped processing for MMM-Wallpaper, doing test run
                          processing complete for module MMM-Wallpaper
                          processing for module MMM-connection-status please wait
                          skipped processing for MMM-connection-status, doing test run
                          processing complete for module MMM-connection-status
                          processing for module MMM-Remote-Control please wait
                          skipped processing for MMM-Remote-Control, doing test run
                          processing complete for module MMM-Remote-Control
                          processing for module MMM-BurnIn please wait
                          skipped processing for MMM-BurnIn, doing test run
                          processing complete for module MMM-BurnIn**
                          restoring custom.css
                          removing git alias
                          Upgrade ended - Sun Oct 15 18:18:11 PDT 2023
                          Upgrade started - Sun Oct 15 18:19:04 PDT 2023
                          user requested to apply changes
                          doing test run = false
                          saving custom.css
                          local version 2.25.0 already same as master 2.25.0
                          removing git alias
                          Upgrade ended - Sun Oct 15 18:19:08 PDT 2023
                            sdetweil @rmcon
                            Codename: bullseye
                            this is the test run.
                            upgrade is a two.part process
                            everyone puts lots of energy into building their mirrors.
                            last thing my script needs to do is screw it up.
                            so test run let’s you get an idea if there are any issues you need to fix BEFORE making any changes
                            the second run (with the apply parameter)
                            actually DOES the update.
                            however, I will NOT upgrade a system already upgraded by default
                            IF you need to force the upgrade process over the same version, then change the parm apply to force
                              rmcon @sdetweil
                              I did the test upgrade then followed it with the apply parameter.
                              At this point, I think my only option is to try the force option. Worst case scenario, if I can’t revive the current version, I’ll try to remove MM and start fresh. I think I’ve got the important bits saved somewhere else to make the job a little easier.
                              I really do appreciate your help with this, as it is not my forte.
                                sdetweil @rmcon
                                @rmcon show me the rest of the upgrade.log
                                  sdetweil @rmcon
                                  @rmcon you can use my backup/restore scripts
                                  https://github.com/sdetweil/MagicMirror-backup-restore
                                    rmcon @sdetweil
                                    It was in the previous post, about 2/3 of the way down, just below the obnoxiously large text.
                                    saving custom.css
                                    removing git alias
                                    Also, I appreciate the backup and restore info, will look into that before I move ahead.
                                      sdetweil @rmcon
                                      yes you have to use force instead of apply
                                        rmcon @sdetweil
                                        Force update complete. MM still not working properly, but it’s something different, which I’ll call progress.
                                        [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                                        (Full text below)
                                        I see some answers for ‘node-fetch’ in topic #18055, but I’m not sure if that fix will work on this problem. I’m still digging around, but not seeing this exact problem so far. Thanks.
                                        [15.10.2023 20:57.06.757] [LOG] Starting MagicMirror: v2.25.0
                                        [15.10.2023 20:57.06.798] [LOG] Loading config …
                                        [15.10.2023 20:57.06.803] [DEBUG] config template file not exists, no envsubst
                                        [15.10.2023 20:57.06.851] [LOG] Loading module helpers …
                                        [15.10.2023 20:57.06.884] [LOG] No helper found for module: alert.
                                        [15.10.2023 20:57.07.124] [LOG] Initializing new module helper …
                                        [15.10.2023 20:57.07.126] [LOG] Module helper loaded: updatenotification
                                        [15.10.2023 20:57.07.145] [LOG] No helper found for module: clock.
                                        [15.10.2023 20:57.08.647] [LOG] Initializing new module helper …
                                        [15.10.2023 20:57.08.648] [LOG] Module helper loaded: calendar
                                        [15.10.2023 20:57.08.650] [LOG] No helper found for module: MMM-MonthlyCalendar.
                                        [15.10.2023 20:57.08.651] [LOG] No helper found for module: weather.
                                        [15.10.2023 20:57.11.743] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                                        Require stack:
                                        • /home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                                          at Object. (/home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                                          at loadModule (/home/rmco01/MagicMirror/js/app.js:180:19)
                                        (removed remainder, same spam messages as previous)
                                          sdetweil @rmcon
                                          Require stack:
                                          yes we removed some libs as fetch is built-in in node 18 up.
                                          that module has a fix
                                          go to the MMM-Wallpaper folder (check spelling)
                                          git pull
                                          to update
                                          then restart mm
                                            rmcon @sdetweil
                                            We’re up and running! Thank you so much for your patience. I have learned a lot from this go round and I’m hoping that the next update will go much smoother. I still don’t fully understand how to check the test run for compatibility with my configuration before applying the changes, but I have a little time to get smarter before the next update. Have a great rest of your week.
                                            • 2 / 3
