    Error starting after upgrade
    41 Posts 5 Posters 16.3k Views 5 Watching
      sdetweil @rmcon
      @rmcon said in Error starting after upgrade:
      Cannot find module ‘digest-fetch’
      this is the prior release code
      which means you didn’t run the upgrade
      either my script or the manual upgrade
      note my script is 2 part, test and run a second time w a parameter to actually do the upgrade
        rmcon @sdetweil
        I’m a little confused regarding the two separate scripts. I thought the updates were necessary, not optional and didn’t understand why would there be a test run script if the changes need to be applied. In other words, I figured the first script that doesn’t actually apply changes was just extra effort… Is the intent to make sure the update works with the user’s specific MM configuration?
        I tried the trial run the first time and I don’t recall if I could tell there were any changes, so I tried the second script to actually make changes.
        So, I just tried running the “test” script again, the one thing I did differently is to say “No” when asked if I wanted to keep 23 files that are different than the master (last time I said “Yes”).
        Just tried starting MM again, getting the same error. Since the test run didn’t give me any better results, I went ahead and tried the script to apply changes. Same result as before.
        The current version is 2.25.0, right? I see that stated in the terminal window:
        rmco01@raspberrypi:~/MagicMirror $ npm start
        magicmirror@2.25.0 start
        [10.10.2023 19:39.57.465] [LOG] Starting MagicMirror: v2.25.0
        [10.10.2023 19:39.57.476] [LOG] Loading config …
        [10.10.2023 19:39.57.485] [DEBUG] config template file not exists, no envsubst
        [10.10.2023 19:39.57.495] [LOG] Loading module helpers …
        [10.10.2023 19:39.57.507] [LOG] No helper found for module: alert.
        [10.10.2023 19:39.57.568] [LOG] Initializing new module helper …
        [10.10.2023 19:39.57.569] [LOG] Module helper loaded: updatenotification
        [10.10.2023 19:39.57.578] [LOG] No helper found for module: clock.
        [10.10.2023 19:39.57.592] [ERROR] (node:7168) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
        Require stack:
        • /home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js
        • /home/rmco01/MagicMirror/modules/default/calendar/node_helper.js
        • /home/rmco01/MagicMirror/js/app.js
        • /home/rmco01/MagicMirror/js/electron.js
        • /home/rmco01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        (remainder truncated since it appears to be the same as previously reported)
        Is there some other step that I’m missing? When you say “run a second time w a parameter to actually do the upgrade,” the parameter you’re referring to is “apply” at the end of the link/script, correct? Or am I supposed to do something else in MM or the config file to make it take effect?
          rmcon @rmcon
          Just got a chance to work on this again. Tried doing both upgrade scripts (again) and I’m getting the same results. I reviewed the upgrade.log file but nothing is jumping out at me (full log from today’s efforts below). The only items that seem like they didn’t go as intended are a few modules that may have been partially skipped in the upgrade process (“skipped processing for…” MMM-Wallpaper, MMM-connection-status, MMM-Remote-Control, MMM-BurinIn), but I don’t think those would be related to the problems I’m experiencing when trying to start MM. I may remove those from my config.js file to see in anything changes. Other ideas?
          (Apologies for the section of large text below, I can’t figure out why it’s doing that and how to fix it)
          Upgrade started - Sun Oct 15 18:17:56 PDT 2023
          system is Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
          Check current Node installation …
          Minimum Node version: v20.8.0
          Installed Node version: v20.8.0
          No Node.js upgrade necessary.
          Check current NPM installation …
          Minimum npm version: V10.1.0
          Installed npm version: V10.1.0
          No npm upgrade necessary.
          saving custom.css
          remote name = origin
          upgrading from version 2.25.0 to 2.25.0
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is up to date with ‘origin/master’.
          (use “git add/rm …” to update what will be committed)
          (use “git restore …” to discard changes in working directory)
          modified: modules/default/alert/templates/alert.njk
          modified: modules/default/alert/templates/notification.njk
          modified: modules/default/calendar/calendar.js
          modified: modules/default/calendar/calendarfetcher.js
          modified: modules/default/calendar/calendarfetcherutils.js
          modified: modules/default/compliments/compliments.js
          modified: modules/default/helloworld/helloworld.njk
          modified: modules/default/newsfeed/fullarticle.njk
          modified: modules/default/newsfeed/newsfeed.njk
          modified: modules/default/newsfeed/newsfeedfetcher.js
          modified: modules/default/newsfeed/oldconfig.njk
          modified: modules/default/updatenotification/node_helper.js
          modified: modules/default/updatenotification/updatenotification.njk
          modified: modules/default/weather/current.njk
          modified: modules/default/weather/forecast.njk
          modified: modules/default/weather/hourly.njk
          modified: modules/default/weather/providers/openweathermap.js
          deleted: modules/default/weather/providers/overrideWrapper.js
          modified: modules/default/weather/providers/weathergov.js
          modified: modules/default/weather/providers/yr.js
          modified: modules/default/weather/weather.js
          modified: modules/default/weather/weatherprovider.js
          modified: package-lock.json
          modified: package.json
          Untracked files:
          (use “git add …” to include in what will be committed)
          core
          css/save_custom.css
          no changes added to commit (use “git add” and/or “git commit -a”)
          there are 23 local files that are different than the master repo
          package-lock.json
          package.json
          save/restore files selection = n
          restoring modules/default/alert/templates/alert.njk from repo
          skipping restore for modules/default/alert/templates/alert.njk, doing test run
          restoring modules/default/alert/templates/notification.njk from repo
          skipping restore for modules/default/alert/templates/notification.njk, doing test run
          restoring modules/default/calendar/calendar.js from repo
          skipping restore for modules/default/calendar/calendar.js, doing test run
          restoring modules/default/calendar/calendarfetcher.js from repo
          skipping restore for modules/default/calendar/calendarfetcher.js, doing test run
          restoring modules/default/calendar/calendarfetcherutils.js from repo
          skipping restore for modules/default/calendar/calendarfetcherutils.js, doing test run
          restoring modules/default/compliments/compliments.js from repo
          skipping restore for modules/default/compliments/compliments.js, doing test run
          restoring modules/default/helloworld/helloworld.njk from repo
          skipping restore for modules/default/helloworld/helloworld.njk, doing test run
          restoring modules/default/newsfeed/fullarticle.njk from repo
          skipping restore for modules/default/newsfeed/fullarticle.njk, doing test run
          restoring modules/default/newsfeed/newsfeed.njk from repo
          skipping restore for modules/default/newsfeed/newsfeed.njk, doing test run
          restoring modules/default/newsfeed/newsfeedfetcher.js from repo
          skipping restore for modules/default/newsfeed/newsfeedfetcher.js, doing test run
          restoring modules/default/newsfeed/oldconfig.njk from repo
          skipping restore for modules/default/newsfeed/oldconfig.njk, doing test run
          restoring modules/default/updatenotification/node_helper.js from repo
          skipping restore for modules/default/updatenotification/node_helper.js, doing test run
          restoring modules/default/updatenotification/updatenotification.njk from repo
          skipping restore for modules/default/updatenotification/updatenotification.njk, doing test run
          restoring modules/default/weather/current.njk from repo
          skipping restore for modules/default/weather/current.njk, doing test run
          restoring modules/default/weather/forecast.njk from repo
          skipping restore for modules/default/weather/forecast.njk, doing test run
          restoring modules/default/weather/hourly.njk from repo
          skipping restore for modules/default/weather/hourly.njk, doing test run
          restoring modules/default/weather/providers/openweathermap.js from repo
          skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
          restoring modules/default/weather/providers/weathergov.js from repo
          skipping restore for modules/default/weather/providers/weathergov.js, doing test run
          restoring modules/default/weather/providers/yr.js from repo
          skipping restore for modules/default/weather/providers/yr.js, doing test run
          restoring modules/default/weather/weather.js from repo
          skipping restore for modules/default/weather/weather.js, doing test run
          restoring modules/default/weather/weatherprovider.js from repo
          skipping restore for modules/default/weather/weatherprovider.js, doing test run
          restoring package-lock.json from repo
          skipping restore for package-lock.json, doing test run
          restoring package.json from repo
          skipping restore for package.json, doing test run
          test merge result rc=‘’ , if empty, no conflicts
          skipping merge, only test run
          downloading dumpactivemodules script
          **processing dependency changes for active modules with package.json files
          processing for module MMM-Wallpaper please wait
          skipped processing for MMM-Wallpaper, doing test run
          processing complete for module MMM-Wallpaper
          processing for module MMM-connection-status please wait
          skipped processing for MMM-connection-status, doing test run
          processing complete for module MMM-connection-status
          processing for module MMM-Remote-Control please wait
          skipped processing for MMM-Remote-Control, doing test run
          processing complete for module MMM-Remote-Control
          processing for module MMM-BurnIn please wait
          skipped processing for MMM-BurnIn, doing test run
          processing complete for module MMM-BurnIn**
          restoring custom.css
          removing git alias
          Upgrade ended - Sun Oct 15 18:18:11 PDT 2023
          Upgrade started - Sun Oct 15 18:19:04 PDT 2023
          user requested to apply changes
          doing test run = false
          saving custom.css
          local version 2.25.0 already same as master 2.25.0
          removing git alias
          Upgrade ended - Sun Oct 15 18:19:08 PDT 2023
            sdetweil @rmcon
            Codename: bullseye
            this is the test run.
            upgrade is a two.part process
            everyone puts lots of energy into building their mirrors.
            last thing my script needs to do is screw it up.
            so test run let’s you get an idea if there are any issues you need to fix BEFORE making any changes
            the second run (with the apply parameter)
            actually DOES the update.
            however, I will NOT upgrade a system already upgraded by default
            IF you need to force the upgrade process over the same version, then change the parm apply to force
              rmcon @sdetweil
              I did the test upgrade then followed it with the apply parameter.
              At this point, I think my only option is to try the force option. Worst case scenario, if I can’t revive the current version, I’ll try to remove MM and start fresh. I think I’ve got the important bits saved somewhere else to make the job a little easier.
              I really do appreciate your help with this, as it is not my forte.
                sdetweil @rmcon
                @rmcon show me the rest of the upgrade.log
                  sdetweil @rmcon
                  @rmcon you can use my backup/restore scripts
                  https://github.com/sdetweil/MagicMirror-backup-restore
                    rmcon @sdetweil
                    It was in the previous post, about 2/3 of the way down, just below the obnoxiously large text.
                    saving custom.css
                    removing git alias
                    Also, I appreciate the backup and restore info, will look into that before I move ahead.
                      sdetweil @rmcon
                      yes you have to use force instead of apply
                        rmcon @sdetweil
                        Force update complete. MM still not working properly, but it’s something different, which I’ll call progress.
                        [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                        (Full text below)
                        I see some answers for ‘node-fetch’ in topic #18055, but I’m not sure if that fix will work on this problem. I’m still digging around, but not seeing this exact problem so far. Thanks.
                        [15.10.2023 20:57.06.757] [LOG] Starting MagicMirror: v2.25.0
                        [15.10.2023 20:57.06.798] [LOG] Loading config …
                        [15.10.2023 20:57.06.803] [DEBUG] config template file not exists, no envsubst
                        [15.10.2023 20:57.06.851] [LOG] Loading module helpers …
                        [15.10.2023 20:57.06.884] [LOG] No helper found for module: alert.
                        [15.10.2023 20:57.07.124] [LOG] Initializing new module helper …
                        [15.10.2023 20:57.07.126] [LOG] Module helper loaded: updatenotification
                        [15.10.2023 20:57.07.145] [LOG] No helper found for module: clock.
                        [15.10.2023 20:57.08.647] [LOG] Initializing new module helper …
                        [15.10.2023 20:57.08.648] [LOG] Module helper loaded: calendar
                        [15.10.2023 20:57.08.650] [LOG] No helper found for module: MMM-MonthlyCalendar.
                        [15.10.2023 20:57.08.651] [LOG] No helper found for module: weather.
                        [15.10.2023 20:57.11.743] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                        Require stack:
                        • /home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                        • at node:internal/modules/cjs/loader:1084:15
                          at Function. (node:electron/js2c/browser_init:2:117419)
                          at Module._resolveFilename (/home/rmco01/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at node:internal/modules/cjs/loader:929:27
                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                          at require (node:internal/modules/cjs/helpers:110:18)
                          at Object. (/home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                          at Object…js (node:internal/modules/cjs/loader:1326:10)
                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                          at node:internal/modules/cjs/loader:967:12
                          at loadModule (/home/rmco01/MagicMirror/js/app.js:180:19)
                        (removed remainder, same spam messages as previous)
                          sdetweil @rmcon
                          Require stack:
                          yes we removed some libs as fetch is built-in in node 18 up.
                          that module has a fix
                          go to the MMM-Wallpaper folder (check spelling)
                          git pull
                          to update
                          then restart mm
                            rmcon @sdetweil
                            We’re up and running! Thank you so much for your patience. I have learned a lot from this go round and I’m hoping that the next update will go much smoother. I still don’t fully understand how to check the test run for compatibility with my configuration before applying the changes, but I have a little time to get smarter before the next update. Have a great rest of your week.
                              sdetweil @rmcon
                              @rmcon great that you got it working
                              on the test run, mostly currently it’s looking for mm files you might have changed for some reason, and conflict w the new release.
                              most of the other issues I handle, upgrade node, npm and pm2 if needed.
                              and in this release on pi0, increase swap space and increase the node heap space.
                              • 2 / 3
