    Error starting after upgrade
    41 Posts 5 Posters 16.5k Views 5 Watching
      sdetweil @wwats
      @wwats
      type the command
      which node
      and show the output
      W 1 Reply Last reply Reply Quote 1
      • W Offline
        wwats @sdetweil
        ok i understand - output is
        /usr/bin/node
        maybe is this important: i work directly on my raspberry with ssh
          sdetweil @wwats
          @wwats ok, lets run this
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
          • W Offline
            wwats @sdetweil
            Everything works :thumbs_up: :thumbs_up: ! Thank You very much - so the mirror is running again. Can I something do for You?
              sdetweil @wwats
              @wwats said in Error starting after upgrade:
              no… i just like to help…
              • W Offline
                wwats @sdetweil
                @sdetweil said in Error starting after upgrade:
                thank you so much :folded_hands_light_skin_tone:
                  rmcon
                  Sam,
                  I’m having similar problems since the recent upgrade. Big disclaimer here that I’m also not the savviest with technology, but was able to get the MM up and running with 95% of what I envisioned and I’m adventurous enough to try and find solutions before asking questions.
                  I have been searching and attempting various ways to fix my issues, which I fear may have made this more complex to solve (i.e. attempted to reinstall the newest upgrades both using your script and manually, everything I found short of using the “force” option). My previous attempts have been working directly on the Pi with keyboard, currently attempting via SSH with same results so far.
                  I’m at a crossroads in my mind now and I’m hoping you can provide steering. Have I gunked this up so much that I should remove and reinstall MM (keeping copes of the previously working config.js, custom.css, and modules folders that I saved on the Pi desktop to try and make the reinstall easier) or can this be fixed? Second concern is that now I’m very hesitant to attempt future upgrades after dealing with this issue (and being far beyond my own capabilities). Any tips or tricks to avoid this in the future?
                  I tried the steps above in this thread with the following results:
                  • “n” and “nvm”, got messages that “command not found” (both in the main folder and MM folder)
                  • “sudo n prune” and “sudo n uninstall”, similar message “sudo n: command not found” (both in main and MM folders)
                  • “node -v” gave me “v20.8.0” (I have ran your script for the node update several times now)
                  • “ls-laf…” method to find the usr/bin location didn’t work (“no such file or directory”, both main and MM folders attempted), but “which node” DID work, showed “/usr/bin/node”
                  Just re-ran the script you linked above and still seeing the same results, posted below. (I used “npm start”, was using pm2 to auto start MM before the upgrade.)
                  magicmirror@2.25.0 start
                  [10.10.2023 03:10.39.346] [LOG] Starting MagicMirror: v2.25.0
                  [10.10.2023 03:10.39.359] [LOG] Loading config …
                  [10.10.2023 03:10.39.371] [DEBUG] config template file not exists, no envsubst
                  [10.10.2023 03:10.39.384] [LOG] Loading module helpers …
                  [10.10.2023 03:10.39.391] [LOG] No helper found for module: alert.
                  [10.10.2023 03:10.39.463] [LOG] Initializing new module helper …
                  [10.10.2023 03:10.39.465] [LOG] Module helper loaded: updatenotification
                  [10.10.2023 03:10.39.473] [LOG] No helper found for module: clock.
                  [10.10.2023 03:10.39.490] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                  Require stack:
                  • /home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js
                  • /home/rmco01/MagicMirror/modules/default/calendar/node_helper.js
                  • /home/rmco01/MagicMirror/js/app.js
                  • /home/rmco01/MagicMirror/js/electron.js
                  • /home/rmco01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                  • at node:internal/modules/cjs/loader:1084:15
                    at Function. (node:electron/js2c/browser_init:2:117419)
                    at Module._resolveFilename (/home/rmco01/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at node:internal/modules/cjs/loader:929:27
                    at Function._load (node:electron/js2c/asar_bundle:2:13327)
                    at Module.require (node:internal/modules/cjs/loader:1150:19)
                    at require (node:internal/modules/cjs/helpers:110:18)
                    at Object. (/home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js:9:16)
                    at Module._compile (node:internal/modules/cjs/loader:1271:14)
                    at Object…js (node:internal/modules/cjs/loader:1326:10)
                    at Module.load (node:internal/modules/cjs/loader:1126:32)
                    at node:internal/modules/cjs/loader:967:12
                    at Object. (/home/rmco01/MagicMirror/modules/default/calendar/node_helper.js:9:25)
                    (Use electron --trace-warnings ... to show where the warning was created)
                    [10.10.2023 03:10.39.492] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    [26678:1010/031040.523164:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                    MESA-LOADER: failed to retrieve device information
                  I understand that the weblink and MESA-LOADER messages are from some relegated elements which aren’t around anymore and just nuisance messages.
                  My previous efforts were trying to find a solution to the “digest-fetch” module, since that appears to be the main problem that I see. I have previously attempted to fix the “envsubst” debug message using guidance in other threads, which either didn’t work, or has been undone by my repeated attempts to solve this problem.
                  Apologies for the long and rambling note, just wanted to give as much detail that may be useful. Thank you!
                    sdetweil @rmcon
                    @rmcon said in Error starting after upgrade:
                    this is the prior release code
                    which means you didn’t run the upgrade
                    either my script or the manual upgrade
                    note my script is 2 part, test and run a second time w a parameter to actually do the upgrade
                      rmcon @sdetweil
                      I’m a little confused regarding the two separate scripts. I thought the updates were necessary, not optional and didn’t understand why would there be a test run script if the changes need to be applied. In other words, I figured the first script that doesn’t actually apply changes was just extra effort… Is the intent to make sure the update works with the user’s specific MM configuration?
                      I tried the trial run the first time and I don’t recall if I could tell there were any changes, so I tried the second script to actually make changes.
                      So, I just tried running the “test” script again, the one thing I did differently is to say “No” when asked if I wanted to keep 23 files that are different than the master (last time I said “Yes”).
                      Just tried starting MM again, getting the same error. Since the test run didn’t give me any better results, I went ahead and tried the script to apply changes. Same result as before.
                      The current version is 2.25.0, right? I see that stated in the terminal window:
                      rmco01@raspberrypi:~/MagicMirror $ npm start
                      [10.10.2023 19:39.57.465] [LOG] Starting MagicMirror: v2.25.0
                      [10.10.2023 19:39.57.476] [LOG] Loading config …
                      [10.10.2023 19:39.57.485] [DEBUG] config template file not exists, no envsubst
                      [10.10.2023 19:39.57.495] [LOG] Loading module helpers …
                      [10.10.2023 19:39.57.507] [LOG] No helper found for module: alert.
                      [10.10.2023 19:39.57.568] [LOG] Initializing new module helper …
                      [10.10.2023 19:39.57.569] [LOG] Module helper loaded: updatenotification
                      [10.10.2023 19:39.57.578] [LOG] No helper found for module: clock.
                      [10.10.2023 19:39.57.592] [ERROR] (node:7168) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                      Require stack:
                      (remainder truncated since it appears to be the same as previously reported)
                      Is there some other step that I’m missing? When you say “run a second time w a parameter to actually do the upgrade,” the parameter you’re referring to is “apply” at the end of the link/script, correct? Or am I supposed to do something else in MM or the config file to make it take effect?
                        rmcon @rmcon
                        Just got a chance to work on this again. Tried doing both upgrade scripts (again) and I’m getting the same results. I reviewed the upgrade.log file but nothing is jumping out at me (full log from today’s efforts below). The only items that seem like they didn’t go as intended are a few modules that may have been partially skipped in the upgrade process (“skipped processing for…” MMM-Wallpaper, MMM-connection-status, MMM-Remote-Control, MMM-BurinIn), but I don’t think those would be related to the problems I’m experiencing when trying to start MM. I may remove those from my config.js file to see in anything changes. Other ideas?
                        (Apologies for the section of large text below, I can’t figure out why it’s doing that and how to fix it)
                        Upgrade started - Sun Oct 15 18:17:56 PDT 2023
                        system is Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                        Check current Node installation …
                        Minimum Node version: v20.8.0
                        Installed Node version: v20.8.0
                        No Node.js upgrade necessary.
                        Check current NPM installation …
                        Minimum npm version: V10.1.0
                        Installed npm version: V10.1.0
                        No npm upgrade necessary.
                        saving custom.css
                        remote name = origin
                        upgrading from version 2.25.0 to 2.25.0
                        fetching latest revisions
                        git fetch rc=0
                        current branch = master
                        On branch master
                        Your branch is up to date with ‘origin/master’.
                        (use “git add/rm …” to update what will be committed)
                        (use “git restore …” to discard changes in working directory)
                        modified: modules/default/alert/templates/alert.njk
                        modified: modules/default/alert/templates/notification.njk
                        modified: modules/default/calendar/calendar.js
                        modified: modules/default/calendar/calendarfetcher.js
                        modified: modules/default/calendar/calendarfetcherutils.js
                        modified: modules/default/compliments/compliments.js
                        modified: modules/default/helloworld/helloworld.njk
                        modified: modules/default/newsfeed/fullarticle.njk
                        modified: modules/default/newsfeed/newsfeed.njk
                        modified: modules/default/newsfeed/newsfeedfetcher.js
                        modified: modules/default/newsfeed/oldconfig.njk
                        modified: modules/default/updatenotification/node_helper.js
                        modified: modules/default/updatenotification/updatenotification.njk
                        modified: modules/default/weather/current.njk
                        modified: modules/default/weather/forecast.njk
                        modified: modules/default/weather/hourly.njk
                        modified: modules/default/weather/providers/openweathermap.js
                        deleted: modules/default/weather/providers/overrideWrapper.js
                        modified: modules/default/weather/providers/weathergov.js
                        modified: modules/default/weather/providers/yr.js
                        modified: modules/default/weather/weather.js
                        modified: modules/default/weather/weatherprovider.js
                        modified: package-lock.json
                        modified: package.json
                        Untracked files:
                        (use “git add …” to include in what will be committed)
                        core
                        css/save_custom.css
                        no changes added to commit (use “git add” and/or “git commit -a”)
                        there are 23 local files that are different than the master repo
                        package-lock.json
                        package.json
                        save/restore files selection = n
                        restoring modules/default/alert/templates/alert.njk from repo
                        skipping restore for modules/default/alert/templates/alert.njk, doing test run
                        restoring modules/default/alert/templates/notification.njk from repo
                        skipping restore for modules/default/alert/templates/notification.njk, doing test run
                        restoring modules/default/calendar/calendar.js from repo
                        skipping restore for modules/default/calendar/calendar.js, doing test run
                        restoring modules/default/calendar/calendarfetcher.js from repo
                        skipping restore for modules/default/calendar/calendarfetcher.js, doing test run
                        restoring modules/default/calendar/calendarfetcherutils.js from repo
                        skipping restore for modules/default/calendar/calendarfetcherutils.js, doing test run
                        restoring modules/default/compliments/compliments.js from repo
                        skipping restore for modules/default/compliments/compliments.js, doing test run
                        restoring modules/default/helloworld/helloworld.njk from repo
                        skipping restore for modules/default/helloworld/helloworld.njk, doing test run
                        restoring modules/default/newsfeed/fullarticle.njk from repo
                        skipping restore for modules/default/newsfeed/fullarticle.njk, doing test run
                        restoring modules/default/newsfeed/newsfeed.njk from repo
                        skipping restore for modules/default/newsfeed/newsfeed.njk, doing test run
                        restoring modules/default/newsfeed/newsfeedfetcher.js from repo
                        skipping restore for modules/default/newsfeed/newsfeedfetcher.js, doing test run
                        restoring modules/default/newsfeed/oldconfig.njk from repo
                        skipping restore for modules/default/newsfeed/oldconfig.njk, doing test run
                        restoring modules/default/updatenotification/node_helper.js from repo
                        skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                        restoring modules/default/updatenotification/updatenotification.njk from repo
                        skipping restore for modules/default/updatenotification/updatenotification.njk, doing test run
                        restoring modules/default/weather/current.njk from repo
                        skipping restore for modules/default/weather/current.njk, doing test run
                        restoring modules/default/weather/forecast.njk from repo
                        skipping restore for modules/default/weather/forecast.njk, doing test run
                        restoring modules/default/weather/hourly.njk from repo
                        skipping restore for modules/default/weather/hourly.njk, doing test run
                        restoring modules/default/weather/providers/openweathermap.js from repo
                        skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                        restoring modules/default/weather/providers/weathergov.js from repo
                        skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                        restoring modules/default/weather/providers/yr.js from repo
                        skipping restore for modules/default/weather/providers/yr.js, doing test run
                        restoring modules/default/weather/weather.js from repo
                        skipping restore for modules/default/weather/weather.js, doing test run
                        restoring modules/default/weather/weatherprovider.js from repo
                        skipping restore for modules/default/weather/weatherprovider.js, doing test run
                        restoring package-lock.json from repo
                        skipping restore for package-lock.json, doing test run
                        restoring package.json from repo
                        skipping restore for package.json, doing test run
                        test merge result rc=‘’ , if empty, no conflicts
                        skipping merge, only test run
                        downloading dumpactivemodules script
                        **processing dependency changes for active modules with package.json files
                        processing for module MMM-Wallpaper please wait
                        skipped processing for MMM-Wallpaper, doing test run
                        processing complete for module MMM-Wallpaper
                        processing for module MMM-connection-status please wait
                        skipped processing for MMM-connection-status, doing test run
                        processing complete for module MMM-connection-status
                        processing for module MMM-Remote-Control please wait
                        skipped processing for MMM-Remote-Control, doing test run
                        processing complete for module MMM-Remote-Control
                        processing for module MMM-BurnIn please wait
                        skipped processing for MMM-BurnIn, doing test run
                        processing complete for module MMM-BurnIn**
                        restoring custom.css
                        removing git alias
                        Upgrade ended - Sun Oct 15 18:18:11 PDT 2023
                        Upgrade started - Sun Oct 15 18:19:04 PDT 2023
                        user requested to apply changes
                        doing test run = false
                        saving custom.css
                        local version 2.25.0 already same as master 2.25.0
                        removing git alias
                        Upgrade ended - Sun Oct 15 18:19:08 PDT 2023
                          sdetweil @rmcon
                          Codename: bullseye
                          this is the test run.
                          upgrade is a two.part process
                          everyone puts lots of energy into building their mirrors.
                          last thing my script needs to do is screw it up.
                          so test run let’s you get an idea if there are any issues you need to fix BEFORE making any changes
                          the second run (with the apply parameter)
                          actually DOES the update.
                          however, I will NOT upgrade a system already upgraded by default
                          IF you need to force the upgrade process over the same version, then change the parm apply to force
                            rmcon @sdetweil
                            I did the test upgrade then followed it with the apply parameter.
                            At this point, I think my only option is to try the force option. Worst case scenario, if I can’t revive the current version, I’ll try to remove MM and start fresh. I think I’ve got the important bits saved somewhere else to make the job a little easier.
                            I really do appreciate your help with this, as it is not my forte.
                              sdetweil @rmcon
                              @rmcon show me the rest of the upgrade.log
                                sdetweil @rmcon
                                @rmcon you can use my backup/restore scripts
                                https://github.com/sdetweil/MagicMirror-backup-restore
                                  rmcon @sdetweil
                                  It was in the previous post, about 2/3 of the way down, just below the obnoxiously large text.
                                  saving custom.css
                                  removing git alias
                                  Also, I appreciate the backup and restore info, will look into that before I move ahead.
                                    sdetweil @rmcon
                                    yes you have to use force instead of apply
                                      rmcon @sdetweil
                                      Force update complete. MM still not working properly, but it’s something different, which I’ll call progress.
                                      [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                                      (Full text below)
                                      I see some answers for ‘node-fetch’ in topic #18055, but I’m not sure if that fix will work on this problem. I’m still digging around, but not seeing this exact problem so far. Thanks.
                                      [15.10.2023 20:57.06.757] [LOG] Starting MagicMirror: v2.25.0
                                      [15.10.2023 20:57.06.798] [LOG] Loading config …
                                      [15.10.2023 20:57.06.803] [DEBUG] config template file not exists, no envsubst
                                      [15.10.2023 20:57.06.851] [LOG] Loading module helpers …
                                      [15.10.2023 20:57.06.884] [LOG] No helper found for module: alert.
                                      [15.10.2023 20:57.07.124] [LOG] Initializing new module helper …
                                      [15.10.2023 20:57.07.126] [LOG] Module helper loaded: updatenotification
                                      [15.10.2023 20:57.07.145] [LOG] No helper found for module: clock.
                                      [15.10.2023 20:57.08.647] [LOG] Initializing new module helper …
                                      [15.10.2023 20:57.08.648] [LOG] Module helper loaded: calendar
                                      [15.10.2023 20:57.08.650] [LOG] No helper found for module: MMM-MonthlyCalendar.
                                      [15.10.2023 20:57.08.651] [LOG] No helper found for module: weather.
                                      [15.10.2023 20:57.11.743] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch’
                                      Require stack:
                                      • /home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                                        at Object. (/home/rmco01/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                                        at loadModule (/home/rmco01/MagicMirror/js/app.js:180:19)
                                      (removed remainder, same spam messages as previous)
                                        sdetweil @rmcon
                                        Require stack:
                                        yes we removed some libs as fetch is built-in in node 18 up.
                                        that module has a fix
                                        go to the MMM-Wallpaper folder (check spelling)
                                        git pull
                                        to update
                                        then restart mm
                                          rmcon @sdetweil
                                          We’re up and running! Thank you so much for your patience. I have learned a lot from this go round and I’m hoping that the next update will go much smoother. I still don’t fully understand how to check the test run for compatibility with my configuration before applying the changes, but I have a little time to get smarter before the next update. Have a great rest of your week.
                                            sdetweil @rmcon
                                            @rmcon great that you got it working
                                            on the test run, mostly currently it’s looking for mm files you might have changed for some reason, and conflict w the new release.
                                            most of the other issues I handle, upgrade node, npm and pm2 if needed.
                                            and in this release on pi0, increase swap space and increase the node heap space.
                                            • 2 / 3
