    Error starting after upgrade
    41 Posts 5 Posters 15.8k Views 5 Watching
      sdetweil @wwats
      @wwats can u do
      ls -laF /usr/local/bin/node
      W 1 Reply Last reply Reply Quote 1
      • W Offline
        wwats @sdetweil
        @sdetweil no… :
        pi@raspberrypi:~ $ ls -laF /usr/local/bin/node
        ls: Zugriff auf ‘/usr/local/bin/node’ nicht möglich: Datei oder Verzeichnis nicht gefunden
          sdetweil @wwats
          @wwats ok, try this
          which node
          on my desktop returns
          /usr/local/bin/node
          and there is a file there…
          • W Offline
            wwats @sdetweil
            @sdetweil i’m very sorry but i don’t understand this and what i have exactly to do… Can you explain it in a different way?
              sdetweil @wwats
              @wwats
              type the command
              which node
              and show the output
              • W Offline
                wwats @sdetweil
                ok i understand - output is
                /usr/bin/node
                maybe is this important: i work directly on my raspberry with ssh
                  sdetweil @wwats
                  @wwats ok, lets run this
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                  • W Offline
                    wwats @sdetweil
                    Everything works :thumbs_up: :thumbs_up: ! Thank You very much - so the mirror is running again. Can I something do for You?
                      sdetweil @wwats
                      @wwats said in Error starting after upgrade:
                      no… i just like to help…
                      • W Offline
                        wwats @sdetweil
                        @sdetweil said in Error starting after upgrade:
                        thank you so much :folded_hands_light_skin_tone:
                          rmcon
                          Sam,
                          I’m having similar problems since the recent upgrade. Big disclaimer here that I’m also not the savviest with technology, but was able to get the MM up and running with 95% of what I envisioned and I’m adventurous enough to try and find solutions before asking questions.
                          I have been searching and attempting various ways to fix my issues, which I fear may have made this more complex to solve (i.e. attempted to reinstall the newest upgrades both using your script and manually, everything I found short of using the “force” option). My previous attempts have been working directly on the Pi with keyboard, currently attempting via SSH with same results so far.
                          I’m at a crossroads in my mind now and I’m hoping you can provide steering. Have I gunked this up so much that I should remove and reinstall MM (keeping copes of the previously working config.js, custom.css, and modules folders that I saved on the Pi desktop to try and make the reinstall easier) or can this be fixed? Second concern is that now I’m very hesitant to attempt future upgrades after dealing with this issue (and being far beyond my own capabilities). Any tips or tricks to avoid this in the future?
                          I tried the steps above in this thread with the following results:
                          • “n” and “nvm”, got messages that “command not found” (both in the main folder and MM folder)
                          • “sudo n prune” and “sudo n uninstall”, similar message “sudo n: command not found” (both in main and MM folders)
                          • “node -v” gave me “v20.8.0” (I have ran your script for the node update several times now)
                          • “ls-laf…” method to find the usr/bin location didn’t work (“no such file or directory”, both main and MM folders attempted), but “which node” DID work, showed “/usr/bin/node”
                          Just re-ran the script you linked above and still seeing the same results, posted below. (I used “npm start”, was using pm2 to auto start MM before the upgrade.)
                          magicmirror@2.25.0 start
                          [10.10.2023 03:10.39.346] [LOG] Starting MagicMirror: v2.25.0
                          [10.10.2023 03:10.39.359] [LOG] Loading config …
                          [10.10.2023 03:10.39.371] [DEBUG] config template file not exists, no envsubst
                          [10.10.2023 03:10.39.384] [LOG] Loading module helpers …
                          [10.10.2023 03:10.39.391] [LOG] No helper found for module: alert.
                          [10.10.2023 03:10.39.463] [LOG] Initializing new module helper …
                          [10.10.2023 03:10.39.465] [LOG] Module helper loaded: updatenotification
                          [10.10.2023 03:10.39.473] [LOG] No helper found for module: clock.
                          [10.10.2023 03:10.39.490] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                          Require stack:
                          • /home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js
                          • /home/rmco01/MagicMirror/modules/default/calendar/node_helper.js
                          • /home/rmco01/MagicMirror/js/app.js
                          • /home/rmco01/MagicMirror/js/electron.js
                          • /home/rmco01/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                          • at node:internal/modules/cjs/loader:1084:15
                            at Function. (node:electron/js2c/browser_init:2:117419)
                            at Module._resolveFilename (/home/rmco01/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at node:internal/modules/cjs/loader:929:27
                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:110:18)
                            at Object. (/home/rmco01/MagicMirror/modules/default/calendar/calendarfetcher.js:9:16)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object…js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                            at node:internal/modules/cjs/loader:967:12
                            at Object. (/home/rmco01/MagicMirror/modules/default/calendar/node_helper.js:9:25)
                            (Use electron --trace-warnings ... to show where the warning was created)
                            [10.10.2023 03:10.39.492] [ERROR] (node:26678) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                            [26678:1010/031040.523164:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                            MESA-LOADER: failed to retrieve device information
                          I understand that the weblink and MESA-LOADER messages are from some relegated elements which aren’t around anymore and just nuisance messages.
                          My previous efforts were trying to find a solution to the “digest-fetch” module, since that appears to be the main problem that I see. I have previously attempted to fix the “envsubst” debug message using guidance in other threads, which either didn’t work, or has been undone by my repeated attempts to solve this problem.
                          Apologies for the long and rambling note, just wanted to give as much detail that may be useful. Thank you!
                            sdetweil @rmcon
                            @rmcon said in Error starting after upgrade:
                            this is the prior release code
                            which means you didn’t run the upgrade
                            either my script or the manual upgrade
                            note my script is 2 part, test and run a second time w a parameter to actually do the upgrade
                              rmcon @sdetweil
                              I’m a little confused regarding the two separate scripts. I thought the updates were necessary, not optional and didn’t understand why would there be a test run script if the changes need to be applied. In other words, I figured the first script that doesn’t actually apply changes was just extra effort… Is the intent to make sure the update works with the user’s specific MM configuration?
                              I tried the trial run the first time and I don’t recall if I could tell there were any changes, so I tried the second script to actually make changes.
                              So, I just tried running the “test” script again, the one thing I did differently is to say “No” when asked if I wanted to keep 23 files that are different than the master (last time I said “Yes”).
                              Just tried starting MM again, getting the same error. Since the test run didn’t give me any better results, I went ahead and tried the script to apply changes. Same result as before.
                              The current version is 2.25.0, right? I see that stated in the terminal window:
                              rmco01@raspberrypi:~/MagicMirror $ npm start
                              [10.10.2023 19:39.57.465] [LOG] Starting MagicMirror: v2.25.0
                              [10.10.2023 19:39.57.476] [LOG] Loading config …
                              [10.10.2023 19:39.57.485] [DEBUG] config template file not exists, no envsubst
                              [10.10.2023 19:39.57.495] [LOG] Loading module helpers …
                              [10.10.2023 19:39.57.507] [LOG] No helper found for module: alert.
                              [10.10.2023 19:39.57.568] [LOG] Initializing new module helper …
                              [10.10.2023 19:39.57.569] [LOG] Module helper loaded: updatenotification
                              [10.10.2023 19:39.57.578] [LOG] No helper found for module: clock.
                              [10.10.2023 19:39.57.592] [ERROR] (node:7168) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘digest-fetch’
                              Require stack:
                              (remainder truncated since it appears to be the same as previously reported)
                              Is there some other step that I’m missing? When you say “run a second time w a parameter to actually do the upgrade,” the parameter you’re referring to is “apply” at the end of the link/script, correct? Or am I supposed to do something else in MM or the config file to make it take effect?
                                rmcon @rmcon
                                Just got a chance to work on this again. Tried doing both upgrade scripts (again) and I’m getting the same results. I reviewed the upgrade.log file but nothing is jumping out at me (full log from today’s efforts below). The only items that seem like they didn’t go as intended are a few modules that may have been partially skipped in the upgrade process (“skipped processing for…” MMM-Wallpaper, MMM-connection-status, MMM-Remote-Control, MMM-BurinIn), but I don’t think those would be related to the problems I’m experiencing when trying to start MM. I may remove those from my config.js file to see in anything changes. Other ideas?
                                (Apologies for the section of large text below, I can’t figure out why it’s doing that and how to fix it)
                                Upgrade started - Sun Oct 15 18:17:56 PDT 2023
                                system is Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                Check current Node installation …
                                Minimum Node version: v20.8.0
                                Installed Node version: v20.8.0
                                No Node.js upgrade necessary.
                                Check current NPM installation …
                                Minimum npm version: V10.1.0
                                Installed npm version: V10.1.0
                                No npm upgrade necessary.
                                saving custom.css
                                remote name = origin
                                upgrading from version 2.25.0 to 2.25.0
                                fetching latest revisions
                                git fetch rc=0
                                current branch = master
                                On branch master
                                Your branch is up to date with ‘origin/master’.
                                (use “git add/rm …” to update what will be committed)
                                (use “git restore …” to discard changes in working directory)
                                modified: modules/default/alert/templates/alert.njk
                                modified: modules/default/alert/templates/notification.njk
                                modified: modules/default/calendar/calendar.js
                                modified: modules/default/calendar/calendarfetcher.js
                                modified: modules/default/calendar/calendarfetcherutils.js
                                modified: modules/default/compliments/compliments.js
                                modified: modules/default/helloworld/helloworld.njk
                                modified: modules/default/newsfeed/fullarticle.njk
                                modified: modules/default/newsfeed/newsfeed.njk
                                modified: modules/default/newsfeed/newsfeedfetcher.js
                                modified: modules/default/newsfeed/oldconfig.njk
                                modified: modules/default/updatenotification/node_helper.js
                                modified: modules/default/updatenotification/updatenotification.njk
                                modified: modules/default/weather/current.njk
                                modified: modules/default/weather/forecast.njk
                                modified: modules/default/weather/hourly.njk
                                modified: modules/default/weather/providers/openweathermap.js
                                deleted: modules/default/weather/providers/overrideWrapper.js
                                modified: modules/default/weather/providers/weathergov.js
                                modified: modules/default/weather/providers/yr.js
                                modified: modules/default/weather/weather.js
                                modified: modules/default/weather/weatherprovider.js
                                modified: package-lock.json
                                modified: package.json
                                Untracked files:
                                (use “git add …” to include in what will be committed)
                                core
                                css/save_custom.css
                                no changes added to commit (use “git add” and/or “git commit -a”)
                                there are 23 local files that are different than the master repo
                                package-lock.json
                                package.json
                                save/restore files selection = n
                                restoring modules/default/alert/templates/alert.njk from repo
                                skipping restore for modules/default/alert/templates/alert.njk, doing test run
                                restoring modules/default/alert/templates/notification.njk from repo
                                skipping restore for modules/default/alert/templates/notification.njk, doing test run
                                restoring modules/default/calendar/calendar.js from repo
                                skipping restore for modules/default/calendar/calendar.js, doing test run
                                restoring modules/default/calendar/calendarfetcher.js from repo
                                skipping restore for modules/default/calendar/calendarfetcher.js, doing test run
                                restoring modules/default/calendar/calendarfetcherutils.js from repo
                                skipping restore for modules/default/calendar/calendarfetcherutils.js, doing test run
                                restoring modules/default/compliments/compliments.js from repo
                                skipping restore for modules/default/compliments/compliments.js, doing test run
                                restoring modules/default/helloworld/helloworld.njk from repo
                                skipping restore for modules/default/helloworld/helloworld.njk, doing test run
                                restoring modules/default/newsfeed/fullarticle.njk from repo
                                skipping restore for modules/default/newsfeed/fullarticle.njk, doing test run
                                restoring modules/default/newsfeed/newsfeed.njk from repo
                                skipping restore for modules/default/newsfeed/newsfeed.njk, doing test run
                                restoring modules/default/newsfeed/newsfeedfetcher.js from repo
                                skipping restore for modules/default/newsfeed/newsfeedfetcher.js, doing test run
                                restoring modules/default/newsfeed/oldconfig.njk from repo
                                skipping restore for modules/default/newsfeed/oldconfig.njk, doing test run
                                restoring modules/default/updatenotification/node_helper.js from repo
                                skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                                restoring modules/default/updatenotification/updatenotification.njk from repo
                                skipping restore for modules/default/updatenotification/updatenotification.njk, doing test run
                                restoring modules/default/weather/current.njk from repo
                                skipping restore for modules/default/weather/current.njk, doing test run
                                restoring modules/default/weather/forecast.njk from repo
                                skipping restore for modules/default/weather/forecast.njk, doing test run
                                restoring modules/default/weather/hourly.njk from repo
                                skipping restore for modules/default/weather/hourly.njk, doing test run
                                restoring modules/default/weather/providers/openweathermap.js from repo
                                skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                                restoring modules/default/weather/providers/weathergov.js from repo
                                skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                                restoring modules/default/weather/providers/yr.js from repo
                                skipping restore for modules/default/weather/providers/yr.js, doing test run
                                restoring modules/default/weather/weather.js from repo
                                skipping restore for modules/default/weather/weather.js, doing test run
                                restoring modules/default/weather/weatherprovider.js from repo
                                skipping restore for modules/default/weather/weatherprovider.js, doing test run
                                restoring package-lock.json from repo
                                skipping restore for package-lock.json, doing test run
                                restoring package.json from repo
                                skipping restore for package.json, doing test run
                                test merge result rc=‘’ , if empty, no conflicts
                                skipping merge, only test run
                                downloading dumpactivemodules script
                                **processing dependency changes for active modules with package.json files
                                processing for module MMM-Wallpaper please wait
                                skipped processing for MMM-Wallpaper, doing test run
                                processing complete for module MMM-Wallpaper
                                processing for module MMM-connection-status please wait
                                skipped processing for MMM-connection-status, doing test run
                                processing complete for module MMM-connection-status
                                processing for module MMM-Remote-Control please wait
                                skipped processing for MMM-Remote-Control, doing test run
                                processing complete for module MMM-Remote-Control
                                processing for module MMM-BurnIn please wait
                                skipped processing for MMM-BurnIn, doing test run
                                processing complete for module MMM-BurnIn**
                                restoring custom.css
                                removing git alias
                                Upgrade ended - Sun Oct 15 18:18:11 PDT 2023
                                Upgrade started - Sun Oct 15 18:19:04 PDT 2023
                                user requested to apply changes
                                doing test run = false
                                saving custom.css
                                local version 2.25.0 already same as master 2.25.0
                                removing git alias
                                Upgrade ended - Sun Oct 15 18:19:08 PDT 2023
                                  sdetweil @rmcon
                                  Codename: bullseye
                                  this is the test run.
                                  upgrade is a two.part process
                                  everyone puts lots of energy into building their mirrors.
                                  last thing my script needs to do is screw it up.
                                  so test run let’s you get an idea if there are any issues you need to fix BEFORE making any changes
                                  the second run (with the apply parameter)
                                  actually DOES the update.
                                  however, I will NOT upgrade a system already upgraded by default
                                  IF you need to force the upgrade process over the same version, then change the parm apply to force
                                    rmcon @sdetweil
                                    I did the test upgrade then followed it with the apply parameter.
                                    At this point, I think my only option is to try the force option. Worst case scenario, if I can’t revive the current version, I’ll try to remove MM and start fresh. I think I’ve got the important bits saved somewhere else to make the job a little easier.
                                    I really do appreciate your help with this, as it is not my forte.
                                      sdetweil @rmcon
                                      @rmcon show me the rest of the upgrade.log
                                        sdetweil @rmcon
                                        @rmcon you can use my backup/restore scripts
                                        https://github.com/sdetweil/MagicMirror-backup-restore
                                          rmcon @sdetweil
                                          It was in the previous post, about 2/3 of the way down, just below the obnoxiously large text.
                                          saving custom.css
                                          removing git alias
                                          Also, I appreciate the backup and restore info, will look into that before I move ahead.
                                            sdetweil @rmcon
                                            yes you have to use force instead of apply
                                            • 2 / 3
