    Error starting after upgrade
    41 Posts 5 Posters 12.9k Views 5 Watching
    • W Offline
      wwats @sdetweil
      No, unfortunately not. i see:
        sdetweil @wwats
        @wwats ok, do
        d
        to delete it
        then node -v
        W 1 Reply Last reply Reply Quote 1
        • W Offline
          wwats @sdetweil
          @sdetweil ok i did. I still have version 16.13.1 :-(
          Am I perhaps in the wrong directory?
          I have to run the script in the lowest directory directly at pi@raspberrypi:~ $, right?
            sdetweil @wwats
            @wwats try this from the n info
            Remove the installed Node.js (does not affect the cached versions). This can be useful to revert to the system version of node (if in a different location)
            sudo n prune
            sudo n uninstall
            • W Offline
              wwats @sdetweil
              @sdetweil ok this was sucessfull… and what do I have to do now? reinstall? How?
              Thank you very much and sorry, I’m not an IT specialist…
                sdetweil @wwats
                @wwats and what does
                node -v
                show now?
                • W Offline
                  wwats @sdetweil
                  pi@raspberrypi:~ $ node -v
                  -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                    sdetweil @wwats
                    @wwats can u do
                    ls -laF /usr/local/bin/node
                    • W Offline
                      wwats @sdetweil
                      @sdetweil no… :
                      pi@raspberrypi:~ $ ls -laF /usr/local/bin/node
                      ls: Zugriff auf ‘/usr/local/bin/node’ nicht möglich: Datei oder Verzeichnis nicht gefunden
                        sdetweil @wwats
                        @wwats ok, try this
                        which node
                        on my desktop returns
                        /usr/local/bin/node
                        and there is a file there…
                        • 2 / 5
