    MMM-NewsAPI after MM2.25.0 update
    6 Posts 3 Posters 1.7k Views 3 Watching
    • K Offline
      kicifans
      Hello everyone!
      Anyone else having problems with this module after updating?
      I get this error when starting up MagicMirror:
      [ERROR] (node:2571) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fetch’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-NewsAPI/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      • at node:internal/modules/cjs/loader:1084:15
        at Function. (node:electron/js2c/browser_init:2:117419)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at node:internal/modules/cjs/loader:929:27
        at Function._load (node:electron/js2c/asar_bundle:2:13327)
        at Module.require (node:internal/modules/cjs/loader:1150:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-NewsAPI/node_helper.js:4:13)
        at Module._compile (node:internal/modules/cjs/loader:1271:14)
        at Object…js (node:internal/modules/cjs/loader:1326:10)
        at Module.load (node:internal/modules/cjs/loader:1126:32)
        at node:internal/modules/cjs/loader:967:12
        at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
      Maybe module is working fine for others after update?
      Any ideas or help would be appreciated!
      Thanks in advance.
        sdetweil @kicifans
        @kicifans said in MMM-NewsAPI after MM2.25.0 update:
        yes, we removed node-fetch in this release, and here is another module that didn’t document using it…
        see general purpose recovery steps here
        K mumblebajM 2 Replies Last reply Reply Quote 1
        • K Offline
          kicifans @sdetweil
          @sdetweil Thank you! This solved the issue!
            sdetweil @kicifans
            @kicifans awesome… thanks for the feedback…
            • mumblebajM Offline
              mumblebaj Module Developer @sdetweil
              @sdetweil Thanks for the assist with this one Sam but my module does list the dependencies on Github. Check it out.
              https://github.com/mumblebaj/MMM-NewsAPI
                sdetweil @mumblebaj
                @mumblebaj all I can say is the ‘manual fix’ worked…
                don’t know why
