    [MMM-OpenWeatherMapForecast] ** ERROR ** null
    3 Posts 2 Posters 1.0k Views 2 Watching
    • C
      Chazzer
      [15.10.2023 13:51.43.569] [INFO] Checking git for module: MMM-OpenWeatherMapForecast
      [15.10.2023 13:51.43.609] [LOG] [MMM-OpenWeatherMapForecast] 15-Oct-23 13:51 ** ERROR ** null
      Can someone tell me why I get the error null?
      I use a Pi 3b and latest MM2 version. ( MagicMirror: v2.25.0)
      The default weather app function
      Open weather Map "loaded cc5859ce-fbda-4dbd-8396-3c5884cc5466-Bild 15.10.23 um 13.57.jpg
      I install it from here:
      https://github.com/MarcLandis/MMM-OpenWeatherMapForecast
      config
      module: “MMM-OpenWeatherMapForecast”,
      header: “Open Weather Map”,
      position: “top_right”,
      classes: “default everyone”,
      disabled: false,
      apikey: “4xxxxSecret”,
      latitude: “51.003610”,
      longitude: “6.889070”,
      iconset: “4c”,
      concise: false,
      forecastLayout: “table”
      • J
        JeanMichelC
        I have the same issue and I spent some time debugging it. It turns out that the API call reference the onecall API which is not free. It requires a subscription https://openweathermap.org/api/one-call-3#error401
        The call is using 2.5 but the documentation online only reference 3.0
        https://api.openweathermap.org/data/3.0/onecall?lat={lat}&lon={lon}&exclude={part}&appid={API key}
        I tried changing the API call to use hte free one but the layout is probably diffrent and therefore fails.
        I think this module won’t work unless you have the OneCall subscription.
        C 1 Reply Last reply
        • C
          Chazzer @JeanMichelC
          As you described, the solution was to upgrade the subscription to the One Call API 3.0. Subsequently, I created a new API key and configured it in the config.js file for the module. Thank you for the suggestion.
          Now, I just need to align everything to the right.
