    Modifying the Config File
    101 Posts 7 Posters 174.0k Views 7 Watching
      jimb
      Sam, as a last resort (operating from 2 computers) I attemped to take a picture with my phone and copy that here. No luck. I hear you about working from my PC on the pi, but beyond my experience level. I could try and copy to another place or system?
        sdetweil @jimb
        @jimb posting your pic is the third icon from the right above the message editor
          jimb
          Co
          Sam, I get an error when trying to copy the file. Does it need to have a particular extension?
            sdetweil @jimb
            @jimb copy what file?
              jimb
              Phone picture of the Config.js file. The picture has a jpg extension.
                sdetweil @jimb
                @jimb never any trouble, 3rd icon from the right
                  jimb
                  Sam, I don’t know why the picture is not copied, I suspect it is over-sized. Dev yield
                  The first 12 s the following error message:
                  Failed to load resource: the api.openweatherapp.0…c6acaacfb123ce212:1 server responded with a status of 401 (unauthorized)
                  (twice)
                  Could not locate data …TypeError: Cannot read openweathermap.is 43 properties of undefined (reading ‘humidity’)
                  …then as time increases and it tries to update the screen more specific error messages occur
                  Thye first 12 characters of my api id are truncated in the first error message text above
                    sdetweil @jimb
                    @jimb yes I have had to upload to my PC, then edit the.pic smaller sometimes. technology is so cool sometimes
                    • F Offline
                      fulviolcabrera @jimb
                      @jimb once you download it search for your location. For example, city. It with show your locationID or long or lat. Etc
                        jimb
                        Guys,
                        It’s obvious that I am not specifying the correct item or leaving something out. It’s difficult because noe of the examples I’ve see "lay out’ the complete line of the config only some parts. I’ve played with different items changing them aroud and I get different reports from running in dev of either “401 no authorized” to “404 not found” on the string sent to weathermap. I am using the following-
                        apiVersion: “3.0”
                        locationID: “4699066”
                        apiKey: “xxx” a 32 digit hexadecimal received after registering.
                        I am not using the Lat or Lon at this time
                          sdetweil @jimb
                          @jimb weather is a pain in the rear. the providers are mess, openweather is the worst
                          I believe if you have the new API version you must set the endpoint:“/onecall”
                          AND then you MUST USE lat/lon
                            jimb
                            A lillte ray of sunshine… It 'apears" to be talking with operweather now since the MM display shows-
                            UNDEFINED
                            (wind symbol) 0 north INVALID DATE
                            NaN (degrees)
                            Feels like 32.0 degrees
                            WEATHER FORECAST UNDEFINED
                            I’m still getting 401 Unauthorized failed to load resource file. And getting other Cannot Read errors from openweather when using DEV option while running MM
                              sdetweil @jimb
                              @jimb can you post the complete module definition
                              xxx out the apikey field
                                jimb
                                Sam, here tis. I just noticed the string symbol ($) and the brackets ({}) in the apiKey. I found that in the instructions in MM. I didn’t try the config without them…
                                module: “weather”,
                                units: “imperial”,
                                windUnits: “imperial”,
                                tenpUnits: “imperial”,
                                position: 'top right",
                                apiVersion: “3.0”,
                                weatherProvider: “openweather”,
                                weatherEndpoint: “/onecall”,
                                lat: “33.50872”,
                                lon: “-96.612213”,
                                type: “current”,
                                locationID: 4699066",
                                apiKey: “${xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx}”,
                                module: “weather”,
                                units: “imperial”,
                                apiVersion: “3.0”,
                                lat: “33.50872”,
                                lon:" -96.612213",
                                type: “current”,
                                  sdetweil @jimb
                                  @jimb I don’t understand that comment about $[] as the sample looks like this
                                  please take those characters off, it should just be the text provided by openweather, in quotes
                                    jimb
                                    Sam, this was from one source (above that you pasted). Mo config with the weather data is above that and includes the items I mentioned. BTW, I keyed it separately as I am unable to paste from the Rasberry Pi to my windows PC.
                                      sdetweil @jimb
                                      @jimb on the pi desktop, menu top left
                                      preferences, pi preferences.
                                      interfaces, check ssh on. ok,
                                      change host name, just look at it, should be raspberrypi
                                      then save/exit, reboot
                                      on your PC do
                                      ssh pi@raspberrypi
                                      if the userid you created on the pi is pi.
                                      use the password you set when you booted the first time
                                      now you have a terminal on the pi from your PC, and you can copy/paste in both directions…
                                        jimb
                                        Sam, I remember the name I gave to the Pi, but unfortunately not the password. Is there a way to find it?
                                          sdetweil @jimb
                                          @jimb np, but you should be able to change it from the preferences without knowing it
                                            jimb
                                            Sam, I know the name assigned to the rasberry. I now know the password as I have changed it. SSH is not resolving the hostname. So, what is the proper way to populate the following-
                                            ssh {what goes here}@{what goes here}
                                            Example: ssh {{hostname} @ {password} ???
                                            • 6
                                            • 2 / 6
