    npm start Problem
    16 Posts 2 Posters 6.8k Views 2 Watching
    • L
      Lockslay
      Hello everyone,
      After a few months I wanted to
      sudo npm start
      /usr/local/bin/node: 1: Syntax error: “)” unexpected
      What does this mean and how can I solve it?
        sdetweil @Lockslay
        @Lockslay NEVER use sudo
        cd ~/MagicMirror
        npm start
        • L
          Lockslay @sdetweil
          stefan@smartmirror:~ $ cd MagicMirror/
          stefan@smartmirror:~/MagicMirror $ npm start
          /usr/local/bin/node: 1: Syntax error: ")" unexpected](Link Adresse)
          Unfortunately, that doesn’t work either
            sdetweil @Lockslay
            @Lockslay can you do
            node - v
            • L
              Lockslay @sdetweil
              node - v
              -bash: /usr/local/bin/node: cannot execute binary file: Exec format error
                sdetweil @Lockslay
                @Lockslay
                when was the last update to the system or MagicMirror?
                do
                nvm
                and
                n
                see if either respond… because node is in the local folder
                • L
                  Lockslay @sdetweil
                  Hello,
                  I did an apt update && apt upgrade today.
                  Everything else did not work after a reboot.
                  n
                  and nvm
                  command not found
                    sdetweil @Lockslay
                    @Lockslay
                    little more debug
                    uname -a
                    lsb_release -a
                    file /bin/bash
                    file /usr/local/bin/node
                    • L
                      Lockslay @sdetweil
                      uname -a
                      Linux smartmirror 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                      lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Raspbian
                      Description: Raspbian GNU/Linux 11 (bullseye)
                      Release: 11
                      Codename: bullseye
                      file /bin/bash
                      /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=f12e6d40fb262ad0037b6ec43162208b76d4da71, for GNU/Linux 3.2.0, stripped
                        sdetweil @Lockslay
                        @Lockslay note I added an additional line
                        • L
                          Lockslay @sdetweil
                          /usr/local/bin/node: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=d6aa6eb3474758fb4e621dac8db78891d4f4c0ef, for GNU/Linux 3.2.0, with debug_info, not stripped, too many notes (256)
                          Sorry,
                          I hadn’t seen the message
                            sdetweil @Lockslay
                            @Lockslay yeh, something installed the 64 bit v of node on your 32 bit system.
                            let’s try this
                            sudo apt-get remove nodejs
                            then
                             node - v
                            • L
                              Lockslay @sdetweil
                              @sdetweil said in npm start Problem:
                              node - v
                              __
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man7’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man5’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man1’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/lib/utils’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/using-npm’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/configuring-npm’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/commands’ not empty so not removed
                              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/bin’ not empty so not removed
                              Processing triggers for man-db (2.9.4-2) …
                              stefan@smartmirror:~ $ node - v
                                sdetweil @Lockslay
                                @Lockslay ok, next
                                sudo rm -rf /usr/lib/node_modules/npm
                                sudo rm  /usr/local/bin/node
                                which node
                                hash -r
                                which node
                                node -v
                                • L
                                  Lockslay @sdetweil
                                  @sdetweil Thanks for your help, isn’t it better to reinstall?
                                  I just realised that the config is no longer there either
                                    sdetweil @Lockslay
                                    @Lockslay yes, probably.
                                    flash SD card
                                    boot
                                    skip updates
                                    use my script
                                    if u back up w my other script
                                    I will restore the config, css, and modules on top.of the new mm after install
