    How to learn more about coding
    8 Posts 3 Posters 2.9k Views 3 Watching
    • B
      bebetter14
      I’ve recently gotten very interested in creating a Magic Mirror. Ive started with zero knowledge of coding and I’m still having to Google just about everything. Doing this project has motivated me to learn more about coding but specifically how I can use this raspberry pi. I would love to learn more about how to tweak and modify my Magic Mirror using css but I have no idea where to start. Is there a pecking order I should learn different languages. I know this isnt something I’m going to learn in say a month or two but I love finding something new to learn about and I feel like learning some programing would be a great experience. Can anyone point me in the right direction on what I should learn?
      S BKeyportB 2 Replies Last reply
        sdetweil @bebetter14
        @bebetter14 well, it depends on what you want to try to do
        make new content, a module
        make things look better/different, css
        a module’s job is to collect some data and turn it into part of an html web page. only your data.
        you can make the actual html tags or use API call to create web page document object model ( aka DOM ) elements.
        the js file that matches the module name, runs in the browser. as such it cannot directly access the system it is on. mm provides a helper construct that does not run in the browser, and can access hardware or file systems to get data.
        I have a sample module that implements the spec, and uses a helper to show how the parts fit together.
        https://github.com/sdetweil/SampleModule
        more like a hello world, put up some basic text. you can configure the text or not
        because most of the module runs in the browser, JavaScript is the chosen language. you can interface to code in other languages thru the helper.
        many modules talk to python scripts that produce output captured by the helper and sent on to the core js file for processing
        my pythonPrint modules allows calling any python module and capturing it’s output.
        https://github.com/sdetweil/MMM-PythonPrint
        css is a head scratcher a lot of the time. figuring out the cascade / inheritance rules is an incredible learning experience. add on the styling capabilities on a web page, wow!!!
        B 1 Reply Last reply
        Reply Quote 1
        • BKeyportB
          BKeyport Module Developer @bebetter14
          @bebetter14 I started out that way. What I did personally, was take a dead module that I really liked and started trying to figure out how it worked. Looked up the commands (Lots of searches for “XYZ Javascript” etc and playing on Jsfiddle.net – -Once I got that figured out, I built up my own module (MMM-Multimonth) and got help from some amazing people on here, including Sam and mmrize - major contribution was from a user who CSSified the whole thing and showed me how to do it.
          Knowledge grows as you jump in.
          Reply Quote 1
          • B
            bebetter14 @sdetweil
            @sdetweil @BKeyport Thank you both so much. These are great ideas to get started. From what both of you are saying, it sounds like I need to try and come up with an idea for a module and learn from there. Pretty much from the ground up. I really wish I learned more about this growing up. But at least now I have Chat GPT to assist.
            Also, thank you providing the links to those helpful modules. These will be great learning resources.
            BKeyportB 1 Reply Last reply
            • BKeyportB
              @bebetter14 Avoid the AI engines. They’re mostly useless, just FYI. Enjoy the process. If you end up with a releasable module, great, if not, hey, it’s a learning experience.
              • B
                bebetter14 @BKeyport
                @BKeyport Thank you for the heads up! I guess I should probably focus on trying to get the modules I have installed now to work before I start trying to make a new one.
                  @bebetter14 you can try my MMM-Config module which will present a form for editing config.js
                  it has some struggles with some modules, but there are ways to work around them
                  https://github.com/sdetweil/MMM-Config
                  • B
                    bebetter14
                    Just an update. I have been doing the https://www.theodinproject.com/dashboard “classes” and they have been fantastic. Its a great Introduction to how to use Git and Github along with using a terminal. I do all the learning in a virtual machine that runs Linux. It had a great intros to HTML and CSS. I even have my own Github account (https://github.com/inventiveillustrtions) now with my first “project”.
                    Reply Quote 1
