    Booting up the Mirrow for the first time
    3 Posts 2 Posters 473 Views 2 Watching
    • N Offline
      neastman
      I have followed the quick start guide to the get Magic Mirror up a running with the Raspberry Pi 4 however when I type npm run start I get the following messages are the magic mirror does not display: 6697de15-8dab-429d-b112-9ef5ed6cbd66-image.png
      Does anyone know a fix for this?
        sdetweil @neastman
        @neastman You must start with a full version of the OS that has the graphical desktop.
        MagicMirror uses a browser to display and all browsers display only in graphics mode
        if you had used my automated script it would have aborted warning you of text mode
          sdetweil @neastman
          @neastman you CAN run text mode server
          npm run server
          and access the server from another system with a browser
          (provided you enable outside system access in the MM config.js )
          address, and ipWhitelist by default only allow apps INSIDE the same system to access mm
          (the MM design is for a self contained mirror on the wall of course)
