    Calendar not updating
    95 Posts 4 Posters 78.1k Views 6 Watching
      matt216 @matt216
      @sdetweil so I’ve just spun up a radicale calendar server and added a few test events, then some more - works perfectly!
      Looks like a problem with baikal integration
        sdetweil @matt216
        @matt216 no. i created an ics and ran mm against it
        [09.01.2024 10:42.53.207] [LOG]   Create new calendarfetcher for url: http://localhost:8090/modules/default/calendar/testbalkan.ics - Interval: 604800000
        [09.01.2024 10:42.53.336] [DEBUG] parsed data={"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF":{"type":"VEVENT","params":[],"created":"2024-01-09T16:16:46.000Z","end":"2024-01-10T17:00:00.000Z","dtstamp":"2024-01-09T16:16:47.000Z","start":"2024-01-10T16:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-09T16:16:46.000Z","sequence":"0","summary":"test54321","transparency":"OPAQUE","uid":"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"},"vcalendar":{"type":"VCALENDAR"}}
        [09.01.2024 10:42.53.337] [DEBUG] There are 2 calendar entries.
        [09.01.2024 10:42.53.338] [DEBUG] Processing entry...
        [09.01.2024 10:42.53.339] [DEBUG] Event:
        [09.01.2024 10:42.53.339] [DEBUG] start: Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.339] [DEBUG] end:: Wed Jan 10 2024 11:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.339] [DEBUG] duration: 3600000
        [09.01.2024 10:42.53.340] [DEBUG] title: test54321
        [09.01.2024 10:42.53.340] [DEBUG] full day event =false
        [09.01.2024 10:42.53.340] [DEBUG] initial tz=Europe/London
        [09.01.2024 10:42.53.340] [DEBUG] corrected tz=Europe/London
        [09.01.2024 10:42.53.341] [DEBUG] start date/time=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.341] [DEBUG] start offset=0
        [09.01.2024 10:42.53.341] [DEBUG] start date/time w tz =Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.342] [DEBUG] event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.342] [DEBUG] event offset=0 hour=16 event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
        [09.01.2024 10:42.53.342] [DEBUG] adjustHours=0
        [09.01.2024 10:42.53.342] [DEBUG] saving event: test54321
        [09.01.2024 10:42.53.342] [DEBUG] Processing entry...
        [09.01.2024 10:42.53.342] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://localhost:8090/modules/default/calendar/testbalkan.ics.
          @matt216 can u send me the curl ics from the baikal server where the events don’t show??
          (if you are willing)
          rename to .txt
            matt216 @sdetweil
            @sdetweil this is from the curl’d ics file, showing one of the events that will not display on the mirror display:
            BEGIN:VEVENT
            CREATED:20240109T161646Z
            DTEND;TZID=Europe/London:20240110T170000
            DTSTAMP:20240109T161647Z
            DTSTART;TZID=Europe/London:20240110T160000
            LAST-MODIFIED:20240109T161646Z
            SEQUENCE:0
            SUMMARY:test54321
            TRANSP:OPAQUE
            UID:156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF
            URL;VALUE=URI:
            X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
            X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
            END:VEVENT
            I’d be happy to send over the contents of the ics file before events start, if that would be helpful? Far too much personal family info to send the whole thing, Im afraid (again, no offence intended)!
              sdetweil @matt216
              @matt216 I used that event in an ICS and it displays just fine.
              so I think this is not the events but some communications problem.
              the fact that you have it working with another local hosting server tells me it’s something other than the data
                matt216
                Initial testing with the apache version of the baikal container looks promising (I’m currently having problems with the nginx version). Will continue testing along these lines…
                  matt216 @matt216
                  OK interesting. I created a brand new calendar server. Empty. Added one event to it and configured the mirror calendar module to use this server. It shows the one single event ok. I added a second new event to the calendar and this also shows on the mirror. Seems to work as expected - new events are showing!
                  Then I import my whole famlly calendar and run the same test. I now have 5 family events showing on the calendar. But if I add a new event that should show within my 5 events, it does not show. :(
                  Debug logs >somefile.txt show the mirror is picking up the new event from the ics file, it’s just not showing on the display.
                    matt216
                    @sdetweil I wonder if I could run a nightly cron job to purge the calendar module or something similar…? Not sure how the calendar fetcher works.
                    It still feels like the calendar will load an ics link ok the first time, but is not displaying events created since that first load.
                    Nightly purge and re-connect would be acceptable, I think. Any advice there?
                      sdetweil @matt216
                      @matt216 there is no way to programmatically trigger a calendar refresh. you have to restart mm
                      but you could do this w pm2
                      pm2 restart MagicMirror
                      (or it’s number)
                      in the current state does the broadcasting message indicate a change in number of events?
                        matt216 @sdetweil
                        @sdetweil yes, the broadcasting event number increases by 1 when I add my new event, but the event does not show on the display.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 7 / 10
