    Calendar not updating
    95 Posts 4 Posters 78.1k Views 6 Watching
      matt216 @sdetweil
      @sdetweil Thanks. Done. No change :(
      Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
        sdetweil @matt216
        @matt216 I have not had others with no updates, but others w missing events
        • N Offline
          nechry
          I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
            sdetweil @nechry
            @nechry thanks for the feedback
              mspk
              @sdetweil said in Calendar not updating:
              Hi, I’m pretty new here, so sorry if I mess something up. I think I have the same problem. Installed MM yesterday (so pretty vanilla setup), the only module I added is the MMM-CalendarExt3.
              I configured everything as it should be (I hope at least), but for some reason, my calendars are not beeing updated and one is not beeing show at all… I don’t know what to do anymore, maybe you guys have an idea.
              Here is my error: ```
              0|MagicMirror | [09.01.2024 12:28.43.248] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/[MyCalendarNameHere]/basic.ics
              TypeError: fetch failed
              0|MagicMirror | at Object.fetch (node:internal/deps/undici/undici:11576:11) {
              0|MagicMirror | cause: Error: write EPIPE
              0|MagicMirror | at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
              0|MagicMirror | at handleWriteReq (node:internal/stream_base_commons:58:21)
              0|MagicMirror | at writeGeneric (node:internal/stream_base_commons:149:15)
              0|MagicMirror | at TLSSocket._writeGeneric (node:net:931:11)
              0|MagicMirror | at TLSSocket._write (node:net:943:8)
              0|MagicMirror | at writeOrBuffer (node:internal/streams/writable:392:12)
              0|MagicMirror | at _write (node:internal/streams/writable:333:10)
              0|MagicMirror | at TLSSocket.write (node:internal/streams/writable:337:10)
              0|MagicMirror | at write (node:internal/deps/undici/undici:10124:18)
              0|MagicMirror | at _resume (node:internal/deps/undici/undici:10037:33)
              0|MagicMirror | at resume (node:internal/deps/undici/undici:9938:7)
              0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:9286:11)
              0|MagicMirror | at Client.Intercept (node:internal/deps/undici/undici:9017:20)
              0|MagicMirror | at Client.dispatch (node:internal/deps/undici/undici:7772:44)
              0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:7991:32)
              0|MagicMirror | at Pool.dispatch (node:internal/deps/undici/undici:7772:44) {
              0|MagicMirror | errno: -32,
              0|MagicMirror | code: ‘EPIPE’,
              0|MagicMirror | syscall: ‘write’
              0|MagicMirror | }
              0|MagicMirror | }
              Thanks!
                sdetweil @mspk
                @mspk I think you have the wrong calendar url , you need the ical format url, not the embed url
                mine is like
                https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-fhkjsadfhsdflk'sdfk/basic.ics
                M M 2 Replies Last reply Reply Quote 0
                  mspk @sdetweil
                  mine is like
                  You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
                    matt216 @sdetweil
                    @sdetweil I think you are potentially right. For baikal I have followed such advice as here: https://forum.magicmirror.builders/topic/434/caldav/4?_=1704811423495 where it was advised just adding ?export to the end of the cal URL to generate the ics file, but it is not an actual ics link.
                    I shall work along those lines…
                      sdetweil @matt216
                      @matt216 i test others problems by building an ics FILE and using the url
                      http://localhost:mirror_port/modules/default/calendar/????.ics
                      so it doesn’t have to be ON a ‘server’… just has to be an ICS format file.
                      linking to google, the url returns that data when the calendar does a get request
                      same as for the local file. BUT we depend on the data changing…
                      the cal module does not know that ‘this’ fetch was or was not different than the last fetch.
                      we don’t keep a diff… we just get the current data and present it.
                      if it didn’t change then nothing changes
                        matt216 @sdetweil
                        @sdetweil Trying this.
                        Steps:
                        1. add new test event scheduled tomorrow
                        2. verify event on another device, proving calendar server sync
                        3. curl .ics file from server, find test event
                        4. set calendar module as described in your post above
                        Result:
                        calendar loads successfully, but still does not show new event.
                        Event as shown in ics file:
                        BEGIN:VEVENT
                        CREATED:20240109T161646Z
                        DTEND;TZID=Europe/London:20240110T170000
                        DTSTAMP:20240109T161647Z
                        DTSTART;TZID=Europe/London:20240110T160000
                        LAST-MODIFIED:20240109T161646Z
                        SEQUENCE:0
                        SUMMARY:test54321
                        TRANSP:OPAQUE
                        UID:156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF
                        URL;VALUE=URI:
                        X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                        X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                        END:VEVENT
                        I think MagicMirror does not like the baikal server - no events created since I migrated from iCloud to self-hosted baikal are showing. Can you see anything unusual in the ics event above @sdetweil ?
                        M S 2 Replies Last reply Reply Quote 0
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 6 / 10
