    Calendar not updating
    95 Posts 4 Posters 73.2k Views 6 Watching
      sdetweil @matt216
      @matt216 can u show me the cal config again… as far as I can tell, the ONLY reason its not displayed is that the count (maximumEntries) clips off the total number of events
      actually there are more conditions… in calendar.js
      but they are all configurable
      			for (const e in calendar) {
      				const event = JSON.parse(JSON.stringify(calendar[e])); // clone object
      				if (this.config.hidePrivate && event.class === "PRIVATE") {
      					// do not add the current event, skip it
      					continue;
      				if (limitNumberOfEntries) { (//called with true)
      					if (event.endDate < maxPastDaysCompare) {
      						continue;
      					if (this.config.hideOngoing && event.startDate < now) {
      						continue;
      					if (this.config.hideDuplicates && this.listContainsEvent(events, event)) {
      						continue;
      					if (--remainingEntries < 0) {
      						break;
      and after filtering them out , apply the number of days limit and max entries limit
      		// Limit the number of days displayed
      		// If limitDays is set > 0, limit display to that number of days
      		if (this.config.limitDays > 0) {
      			let newEvents = [];
      			let lastDate = today.clone().subtract(1, "days").format("YYYYMMDD");
      			let days = 0;
      			for (const ev of events) {
      				let eventDate = moment(ev.startDate, "x").format("YYYYMMDD");
      				// if date of event is later than lastdate
      				// check if we already are showing max unique days
      				if (eventDate > lastDate) {
      					// if the only entry in the first day is a full day event that day is not counted as unique
      					if (!this.config.limitDaysNeverSkip && newEvents.length === 1 && days === 1 && newEvents[0].fullDayEvent) {
      						days--;
      					days++;
      					if (days > this.config.limitDays) {
      						continue;
      					} else {
      						lastDate = eventDate;
      				newEvents.push(ev);
      			events = newEvents;
      		return events.slice(0, this.config.maximumEntries);
        matt216 @sdetweil
        			header: "--- Calendar testing ---",
        				fetchInterval: 120000,
        				timeFormat: 'absolute',
        				maximumEntries: 5,
        				broadcastPastEvents: false,
        						url: 'https://my.cal.url/dav.php/calendars/family/default?export',
        						auth: 	{
        							user: 'family',
        							pass: 'pass',
        							method: 'basic'
        With the maximumEntries I currently have events showing several days in the future. When I am adding events to test this, I add the event to start just a few hours in the future so that it should show within the 5 events.
          sdetweil @matt216
          @matt216 lets make that maximumEvents: 20
          for this test
            matt216 @sdetweil
            @sdetweil Updated to 20. This now shows calendar entries all the way to early May but the test event that starts at 20:00 this evening does not show. There are actually lots of events over the next few days that are not showing.
              sdetweil @matt216
              @matt216 ok, lets add some debugging , then we can see what is received in the UI module and what is processed for display (after filtering)
              ~/MagicMirror/modules/default/calendar/calendar.js
              about line 219
              		const events = this.createEventList(true);
              		Log.log("events to process="+JSON.stringify(events))  // add this line
              		const wrapper = document.createElement("table");
              and around line 582
              		for (const calendarUrl in this.calendarData) {
              			const calendar = this.calendarData[calendarUrl];
              			Log.log("before filter events="+JSON.stringify(calendar))  // add this line
              			let remainingEntries = this.maximumEntriesForUrl(calendarUrl);
              then in the browser developers window (ctrl-shift-i to open) select the console tab,
              add cal to the filter field
              you will see these two blocks
              before filter events=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706366400000","endDate":"1706368800000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706971200000","endDate":"1706973600000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at
              and then
              events to process=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.ICS","today":false,"dayBeforeYesterday":false,"yesterday":false,"tomorrow":true,"dayAfterTomorrow":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.IC
                @matt216 the before filter is what was sent from the parser
                the events to process is what will be shown, limited to maximumEntries in length
                  matt216 @sdetweil
                  @sdetweil Thanks Sam. Will have a go and report back.
                    sdetweil @matt216
                    @matt216 you can also use this web site
                    https://codebeautify.org/jsonvalidator?/jsonvalidate
                    to paste in the data (from [ to ]) and then push the format button (in pink) to make it more readable, ctrl-f will allow you to search for the entry you are looking for
                      matt216 @sdetweil
                      @sdetweil good tip, thanks.
                      Little update - I put maximumEntries back to 5 and all my events showed up! But then I added another event, pm2 restart and they disappeared again :weary_face:
                      We’re getting closer! I think you’re on to something with the maximumEntries effect. And also handling between back and front end.
                      I’ll have a go with editing calendar.js this weekend and report back.
                        matt216 @sdetweil
                        @sdetweil Hi Sam.
                        The before filter section is not showing the events that are missing. So not sent from the parser…?
                        The events to process section reflects what is seen in the before filter section.
                        Over the weekend the calendar looked good, but come Monday morning lots of events are missing. The mirror is currently showing events 10 days in the future even though there are plenty of events before then.
                        I have had a play with module config maximumEntries and limitDays to see if anything improves, but with no luck.
                        Thanks again,
                        Matt
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 8 / 10
