    Calendar not updating
    95 Posts 4 Posters 92.3k Views 6 Watching
      sdetweil @matt216
      @matt216 ok… looking at the code
        @matt216 can u show me that event from the ICS file?
        does the rest of the debug output say
        Calendar-Fetcher: Broadcasting xxx events
        where xxx is not 0
          matt216 @sdetweil
          @sdetweil from ics file:
          BEGIN:VEVENT
          CREATED:20240105T132005Z
          DTEND;TZID=Europe/London:20240106T100000
          DTSTAMP:20240105T132006Z
          DTSTART;TZID=Europe/London:20240106T090000
          LAST-MODIFIED:20240105T132005Z
          SEQUENCE:0
          SUMMARY:test1234567
          TRANSP:OPAQUE
          UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
          URL;VALUE=URI:
          X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
          X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
          END:VEVENT
          Broadcasting 1000+ events, yes.
            sdetweil @matt216
            @matt216 and it works perfectly here…
            could you try in config before the calendars list
            broadcastPastEvents: false
              matt216 @sdetweil
              @sdetweil config now:
                                      header: "calendar",
                                              fetchInterval: 120000,
                                              timeFormat: 'absolute',
                                              maximumEntries: 5,
                                              broadcastPastEvents: false,
                                                              url: 'https://my.cal.url',
                                                              auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
              No change. Still not displaying newly created events. :(
                sdetweil @matt216
                @matt216 ok, i don’t know… lets get you back to running on the prior release
                stop mm, shouldn’t be running as its not helpful
                cd ~/MagicMirror
                git tag -l
                to see the list of tagged commits,
                then
                git checkout temp_branch -b tags/v???????
                where ??? is the number 2.25.0 or whatever u want to go back to
                then
                rm -rf node_modules
                npm install
                please advise(we can get back to the current v2.26.0 branch too, very easily
                  sdetweil @matt216
                  @matt216 just one last thing, if you comment out
                   maximumEntries: 5,
                  what happens?
                    matt216 @sdetweil
                    @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                    Getting a git error (novice here, sorry):
                    fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                    Although this issue existed before I upgraded to 2.26.0…
                      matt216
                      I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                      Thanks for the help still.
                      Matt
                        sdetweil @matt216
                        @matt216 also try
                        cd ~/MagicMirror
                        npm install electron@28.1.1
                        supposedly it has the fix for ipv6 vs 4
                          matt216 @sdetweil
                          @sdetweil Thanks. Done. No change :(
                          Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
                            sdetweil @matt216
                            @matt216 I have not had others with no updates, but others w missing events
                            • N Offline
                              nechry
                              I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
                                sdetweil @nechry
                                @nechry thanks for the feedback
                                  mspk
                                  @sdetweil said in Calendar not updating:
                                  Hi, I’m pretty new here, so sorry if I mess something up. I think I have the same problem. Installed MM yesterday (so pretty vanilla setup), the only module I added is the MMM-CalendarExt3.
                                  I configured everything as it should be (I hope at least), but for some reason, my calendars are not beeing updated and one is not beeing show at all… I don’t know what to do anymore, maybe you guys have an idea.
                                  Here is my error: ```
                                  0|MagicMirror | [09.01.2024 12:28.43.248] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/[MyCalendarNameHere]/basic.ics
                                  TypeError: fetch failed
                                  0|MagicMirror | at Object.fetch (node:internal/deps/undici/undici:11576:11) {
                                  0|MagicMirror | cause: Error: write EPIPE
                                  0|MagicMirror | at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
                                  0|MagicMirror | at handleWriteReq (node:internal/stream_base_commons:58:21)
                                  0|MagicMirror | at writeGeneric (node:internal/stream_base_commons:149:15)
                                  0|MagicMirror | at TLSSocket._writeGeneric (node:net:931:11)
                                  0|MagicMirror | at TLSSocket._write (node:net:943:8)
                                  0|MagicMirror | at writeOrBuffer (node:internal/streams/writable:392:12)
                                  0|MagicMirror | at _write (node:internal/streams/writable:333:10)
                                  0|MagicMirror | at TLSSocket.write (node:internal/streams/writable:337:10)
                                  0|MagicMirror | at write (node:internal/deps/undici/undici:10124:18)
                                  0|MagicMirror | at _resume (node:internal/deps/undici/undici:10037:33)
                                  0|MagicMirror | at resume (node:internal/deps/undici/undici:9938:7)
                                  0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:9286:11)
                                  0|MagicMirror | at Client.Intercept (node:internal/deps/undici/undici:9017:20)
                                  0|MagicMirror | at Client.dispatch (node:internal/deps/undici/undici:7772:44)
                                  0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:7991:32)
                                  0|MagicMirror | at Pool.dispatch (node:internal/deps/undici/undici:7772:44) {
                                  0|MagicMirror | errno: -32,
                                  0|MagicMirror | code: ‘EPIPE’,
                                  0|MagicMirror | syscall: ‘write’
                                  0|MagicMirror | }
                                  0|MagicMirror | }
                                  Thanks!
                                    sdetweil @mspk
                                    @mspk I think you have the wrong calendar url , you need the ical format url, not the embed url
                                    mine is like
                                    https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-fhkjsadfhsdflk'sdfk/basic.ics
                                    M M 2 Replies Last reply Reply Quote 0
                                      mspk @sdetweil
                                      mine is like
                                      You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
                                        matt216 @sdetweil
                                        @sdetweil I think you are potentially right. For baikal I have followed such advice as here: https://forum.magicmirror.builders/topic/434/caldav/4?_=1704811423495 where it was advised just adding ?export to the end of the cal URL to generate the ics file, but it is not an actual ics link.
                                        I shall work along those lines…
                                          sdetweil @matt216
                                          @matt216 i test others problems by building an ics FILE and using the url
                                          http://localhost:mirror_port/modules/default/calendar/????.ics
                                          so it doesn’t have to be ON a ‘server’… just has to be an ICS format file.
                                          linking to google, the url returns that data when the calendar does a get request
                                          same as for the local file. BUT we depend on the data changing…
                                          the cal module does not know that ‘this’ fetch was or was not different than the last fetch.
                                          we don’t keep a diff… we just get the current data and present it.
                                          if it didn’t change then nothing changes
                                            matt216 @sdetweil
                                            @sdetweil Trying this.
                                            Steps:
                                            1. add new test event scheduled tomorrow
                                            2. verify event on another device, proving calendar server sync
                                            3. curl .ics file from server, find test event
                                            4. set calendar module as described in your post above
                                            Result:
                                            calendar loads successfully, but still does not show new event.
                                            Event as shown in ics file:
                                            BEGIN:VEVENT
                                            CREATED:20240109T161646Z
                                            DTEND;TZID=Europe/London:20240110T170000
                                            DTSTAMP:20240109T161647Z
                                            DTSTART;TZID=Europe/London:20240110T160000
                                            LAST-MODIFIED:20240109T161646Z
                                            SEQUENCE:0
                                            SUMMARY:test54321
                                            TRANSP:OPAQUE
                                            UID:156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF
                                            URL;VALUE=URI:
                                            END:VEVENT
                                            I think MagicMirror does not like the baikal server - no events created since I migrated from iCloud to self-hosted baikal are showing. Can you see anything unusual in the ics event above @sdetweil ?
                                            M S 2 Replies Last reply Reply Quote 0
                                            • 3 / 5
