    Calendar not updating
    95 Posts 4 Posters 86.2k Views 6 Watching
      matt216 @sdetweil
      @sdetweil Hi Sam.
      A newly created event is showing up in the debug logs, but not on the mirror display:
      [05.01.2024 13:22.18.330] [DEBUG] Event:
      {"type":"VEVENT","params":[],"created":"2024-01-05T13:20:05.000Z","end":"2024-01-06T10:00:00.000Z","dtstamp":"2024-01-05T13:20:06.000Z","start":"2024-01-06T09:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-05T13:20:05.000Z","sequence":"0","summary":"test1234567","transparency":"OPAQUE","uid":"60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
      [05.01.2024 13:22.18.330] [DEBUG] start: Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.331] [DEBUG] end:: Sat Jan 06 2024 10:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.331] [DEBUG] duration: 3600000
      [05.01.2024 13:22.18.331] [DEBUG] title: test1234567
      [05.01.2024 13:22.18.331] [DEBUG] initial tz=Europe/London
      [05.01.2024 13:22.18.332] [DEBUG] corrected tz=Europe/London
      [05.01.2024 13:22.18.332] [DEBUG] start date/time=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.332] [DEBUG] start offset=0
      [05.01.2024 13:22.18.333] [DEBUG] start date/time w tz =Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.333] [DEBUG] event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.333] [DEBUG] event offset=0 hour=9 event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
      [05.01.2024 13:22.18.333] [DEBUG] adjustHours=0
      [05.01.2024 13:22.18.334] [DEBUG] Processing entry...
        matt216 @sdetweil
        @sdetweil done
          matt216 @sdetweil
          @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
            sdetweil @matt216
            @matt216 ok… looking at the code
              @matt216 can u show me that event from the ICS file?
              does the rest of the debug output say
              Calendar-Fetcher: Broadcasting xxx events
              where xxx is not 0
                matt216 @sdetweil
                @sdetweil from ics file:
                BEGIN:VEVENT
                CREATED:20240105T132005Z
                DTEND;TZID=Europe/London:20240106T100000
                DTSTAMP:20240105T132006Z
                DTSTART;TZID=Europe/London:20240106T090000
                LAST-MODIFIED:20240105T132005Z
                SEQUENCE:0
                SUMMARY:test1234567
                TRANSP:OPAQUE
                UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
                URL;VALUE=URI:
                X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                END:VEVENT
                Broadcasting 1000+ events, yes.
                  sdetweil @matt216
                  @matt216 and it works perfectly here…
                  could you try in config before the calendars list
                  broadcastPastEvents: false
                    matt216 @sdetweil
                    @sdetweil config now:
                                            header: "calendar",
                                                    fetchInterval: 120000,
                                                    timeFormat: 'absolute',
                                                    maximumEntries: 5,
                                                    broadcastPastEvents: false,
        url: 'https://my.cal.url',
        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                    No change. Still not displaying newly created events. :(
                      sdetweil @matt216
                      @matt216 ok, i don’t know… lets get you back to running on the prior release
                      stop mm, shouldn’t be running as its not helpful
                      git tag -l
                      to see the list of tagged commits,
                      then
                      git checkout temp_branch -b tags/v???????
                      where ??? is the number 2.25.0 or whatever u want to go back to
                      then
                      rm -rf node_modules
                      npm install
                      please advise(we can get back to the current v2.26.0 branch too, very easily
                        sdetweil @matt216
                        @matt216 just one last thing, if you comment out
                         maximumEntries: 5,
                        what happens?
                          matt216 @sdetweil
                          @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                          Getting a git error (novice here, sorry):
                          fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                          Although this issue existed before I upgraded to 2.26.0…
                            matt216
                            I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                            Thanks for the help still.
                            Matt
                              sdetweil @matt216
                              @matt216 also try
                              npm install electron@28.1.1
                              supposedly it has the fix for ipv6 vs 4
                                matt216 @sdetweil
                                @sdetweil Thanks. Done. No change :(
                                Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
                                  sdetweil @matt216
                                  @matt216 I have not had others with no updates, but others w missing events
                                  • N Offline
                                    nechry
                                    I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
                                      sdetweil @nechry
                                      @nechry thanks for the feedback
                                        mspk
                                        @sdetweil said in Calendar not updating:
                                        Hi, I’m pretty new here, so sorry if I mess something up. I think I have the same problem. Installed MM yesterday (so pretty vanilla setup), the only module I added is the MMM-CalendarExt3.
                                        I configured everything as it should be (I hope at least), but for some reason, my calendars are not beeing updated and one is not beeing show at all… I don’t know what to do anymore, maybe you guys have an idea.
                                        Here is my error: ```
                                        0|MagicMirror | [09.01.2024 12:28.43.248] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/[MyCalendarNameHere]/basic.ics
                                        TypeError: fetch failed
                                        0|MagicMirror | at Object.fetch (node:internal/deps/undici/undici:11576:11) {
                                        0|MagicMirror | cause: Error: write EPIPE
                                        0|MagicMirror | at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
                                        0|MagicMirror | at handleWriteReq (node:internal/stream_base_commons:58:21)
                                        0|MagicMirror | at writeGeneric (node:internal/stream_base_commons:149:15)
                                        0|MagicMirror | at TLSSocket._writeGeneric (node:net:931:11)
                                        0|MagicMirror | at TLSSocket._write (node:net:943:8)
                                        0|MagicMirror | at writeOrBuffer (node:internal/streams/writable:392:12)
                                        0|MagicMirror | at _write (node:internal/streams/writable:333:10)
                                        0|MagicMirror | at TLSSocket.write (node:internal/streams/writable:337:10)
                                        0|MagicMirror | at write (node:internal/deps/undici/undici:10124:18)
                                        0|MagicMirror | at _resume (node:internal/deps/undici/undici:10037:33)
                                        0|MagicMirror | at resume (node:internal/deps/undici/undici:9938:7)
                                        0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:9286:11)
                                        0|MagicMirror | at Client.Intercept (node:internal/deps/undici/undici:9017:20)
                                        0|MagicMirror | at Client.dispatch (node:internal/deps/undici/undici:7772:44)
                                        0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:7991:32)
                                        0|MagicMirror | at Pool.dispatch (node:internal/deps/undici/undici:7772:44) {
                                        0|MagicMirror | errno: -32,
                                        0|MagicMirror | code: ‘EPIPE’,
                                        0|MagicMirror | syscall: ‘write’
                                        0|MagicMirror | }
                                        0|MagicMirror | }
                                        Thanks!
                                          sdetweil @mspk
                                          @mspk I think you have the wrong calendar url , you need the ical format url, not the embed url
                                          mine is like
                                          https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-fhkjsadfhsdflk'sdfk/basic.ics
                                          M M 2 Replies Last reply Reply Quote 0
                                            mspk @sdetweil
                                            mine is like
                                            You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
                                            • 3 / 5
