    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
      matt216 @sdetweil
      @sdetweil yikes, 14000 lines of calendar entries included in this one!
      Any steer on what I’m looking for? Loads of personal info, so I won’t send over if that’s ok (no offence)
      Matt
      S 2 Replies Last reply
        sdetweil @matt216
        @matt216 well … just let you know… I don’t LOOK at any of that info… only the cal entry dates and processing… I only match by title… and I NEVER share…
        (we just added the cal url to output as some were confused about which calendar was sending what entries… more debug info )
        start of the content
        [04.01.2024 11:14.45.590] [DEBUG] There are 5 calendar entries.
        [04.01.2024 11:14.45.591] [DEBUG] Processing entry...
        [04.01.2024 11:14.45.594] [DEBUG] Event:
        then thru the next Event: is all one event, with its recurring events if any
        I’m interested in the events that you says don’t show up…
        one thing you can do is use the configured url to get the ics file
        to make sure the calendar provider is providing the entry
        if its in the ics , but not in the output, then this is a new parser problem… and I want to see the ics entry to test. all can be sent thru mail or private chat (altho chat posts are limited in size)
        curl -sL thaturl >someicsfile.txt
        ics file is just text
        can u find that entry
        can u find it in the debug output
        M 1 Reply Last reply
          sdetweil @matt216
          @matt216 also, could you check
          ip addr
          and disable the IP v6 if present.
          in desktop, menu , preferences, pi config , network settings. may have to reboot
            sdetweil @matt216
            @matt216 also another user having trouble… his url is a shared cal , the other person owns it, but has given the secret url to the spouse for MM cal usage
            are any of the cals shared like this?
              matt216 @sdetweil
              @sdetweil Hi Sam.
              A newly created event is showing up in the debug logs, but not on the mirror display:
              [05.01.2024 13:22.18.330] [DEBUG] Event:
              {"type":"VEVENT","params":[],"created":"2024-01-05T13:20:05.000Z","end":"2024-01-06T10:00:00.000Z","dtstamp":"2024-01-05T13:20:06.000Z","start":"2024-01-06T09:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-05T13:20:05.000Z","sequence":"0","summary":"test1234567","transparency":"OPAQUE","uid":"60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
              [05.01.2024 13:22.18.330] [DEBUG] start: Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.331] [DEBUG] end:: Sat Jan 06 2024 10:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.331] [DEBUG] duration: 3600000
              [05.01.2024 13:22.18.331] [DEBUG] title: test1234567
              [05.01.2024 13:22.18.331] [DEBUG] initial tz=Europe/London
              [05.01.2024 13:22.18.332] [DEBUG] corrected tz=Europe/London
              [05.01.2024 13:22.18.332] [DEBUG] start date/time=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.332] [DEBUG] start offset=0
              [05.01.2024 13:22.18.333] [DEBUG] start date/time w tz =Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.333] [DEBUG] event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.333] [DEBUG] event offset=0 hour=9 event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
              [05.01.2024 13:22.18.333] [DEBUG] adjustHours=0
              [05.01.2024 13:22.18.334] [DEBUG] Processing entry...
                matt216 @sdetweil
                @sdetweil done
                  matt216 @sdetweil
                  @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
                    sdetweil @matt216
                    @matt216 ok… looking at the code
                      @matt216 can u show me that event from the ICS file?
                      does the rest of the debug output say
                      Calendar-Fetcher: Broadcasting xxx events
                      where xxx is not 0
                        matt216 @sdetweil
                        @sdetweil from ics file:
                        BEGIN:VEVENT
                        CREATED:20240105T132005Z
                        DTEND;TZID=Europe/London:20240106T100000
                        DTSTAMP:20240105T132006Z
                        DTSTART;TZID=Europe/London:20240106T090000
                        LAST-MODIFIED:20240105T132005Z
                        SEQUENCE:0
                        SUMMARY:test1234567
                        TRANSP:OPAQUE
                        UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
                        URL;VALUE=URI:
                        X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                        X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                        END:VEVENT
                        Broadcasting 1000+ events, yes.
                          sdetweil @matt216
                          @matt216 and it works perfectly here…
                          could you try in config before the calendars list
                          broadcastPastEvents: false
                            matt216 @sdetweil
                            @sdetweil config now:
                                                    header: "calendar",
                                                            fetchInterval: 120000,
                                                            timeFormat: 'absolute',
                                                            maximumEntries: 5,
                                                            broadcastPastEvents: false,
        url: 'https://my.cal.url',
        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                            No change. Still not displaying newly created events. :(
                              sdetweil @matt216
                              @matt216 ok, i don’t know… lets get you back to running on the prior release
                              stop mm, shouldn’t be running as its not helpful
                              git tag -l
                              to see the list of tagged commits,
                              then
                              git checkout temp_branch -b tags/v???????
                              where ??? is the number 2.25.0 or whatever u want to go back to
                              then
                              rm -rf node_modules
                              npm install
                              please advise(we can get back to the current v2.26.0 branch too, very easily
                                sdetweil @matt216
                                @matt216 just one last thing, if you comment out
                                 maximumEntries: 5,
                                what happens?
                                  matt216 @sdetweil
                                  @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                                  Getting a git error (novice here, sorry):
                                  fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                                  Although this issue existed before I upgraded to 2.26.0…
                                    matt216
                                    I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                                    Thanks for the help still.
                                    Matt
                                      sdetweil @matt216
                                      @matt216 also try
                                      npm install electron@28.1.1
                                      supposedly it has the fix for ipv6 vs 4
                                        matt216 @sdetweil
                                        @sdetweil Thanks. Done. No change :(
                                        Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
                                          sdetweil @matt216
                                          @matt216 I have not had others with no updates, but others w missing events
                                          • N
                                            nechry
                                            I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
                                            • 3 / 5
