    Calendar not updating
    95 Posts 4 Posters 88.6k Views 6 Watching
      sdetweil @matt216
      @matt216 not an error… says ’ we created a fecther() at the start’… and we found it and are reusing it… just informational
      now… lets turn on more debug
      in the config.js
      change
          logLevel: [
            "INFO",
            "LOG",
            "WARN",
            "ERROR",
         //   "DEBUG"
      loglevel like that (just hit enter after the commas and before the ]
      then add the // debug line
      then remove the leading //
      just makes it easier later to turn off debug by adding the // (comment it out)
      then in MagicMirror folder again do
      npm start >somefile.txt 2>&1
      wait til you think it should have updated...
      then ctrl-q
      and then look at the somefile.txt or send it to me
      same user id at gmail
      (I added most of the debug output to work on calendar problems)
      then u can comment out "DEBUG" again
      we did change the calendar parser version this release, to fix a couple bugs I added code for, and a big change on the repeating rule handler...
        matt216 @sdetweil
        @sdetweil yikes, 14000 lines of calendar entries included in this one!
        Any steer on what I’m looking for? Loads of personal info, so I won’t send over if that’s ok (no offence)
        Matt
          sdetweil @matt216
          @matt216 well … just let you know… I don’t LOOK at any of that info… only the cal entry dates and processing… I only match by title… and I NEVER share…
          (we just added the cal url to output as some were confused about which calendar was sending what entries… more debug info )
          start of the content
          [04.01.2024 11:14.45.590] [DEBUG] There are 5 calendar entries.
          [04.01.2024 11:14.45.591] [DEBUG] Processing entry...
          [04.01.2024 11:14.45.594] [DEBUG] Event:
          then thru the next Event: is all one event, with its recurring events if any
          I’m interested in the events that you says don’t show up…
          one thing you can do is use the configured url to get the ics file
          to make sure the calendar provider is providing the entry
          if its in the ics , but not in the output, then this is a new parser problem… and I want to see the ics entry to test. all can be sent thru mail or private chat (altho chat posts are limited in size)
          curl -sL thaturl >someicsfile.txt
          ics file is just text
          can u find that entry
          can u find it in the debug output
            sdetweil @matt216
            @matt216 also, could you check
            ip addr
            and disable the IP v6 if present.
            in desktop, menu , preferences, pi config , network settings. may have to reboot
              sdetweil @matt216
              @matt216 also another user having trouble… his url is a shared cal , the other person owns it, but has given the secret url to the spouse for MM cal usage
              are any of the cals shared like this?
                matt216 @sdetweil
                @sdetweil Hi Sam.
                A newly created event is showing up in the debug logs, but not on the mirror display:
                [05.01.2024 13:22.18.330] [DEBUG] Event:
                {"type":"VEVENT","params":[],"created":"2024-01-05T13:20:05.000Z","end":"2024-01-06T10:00:00.000Z","dtstamp":"2024-01-05T13:20:06.000Z","start":"2024-01-06T09:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-05T13:20:05.000Z","sequence":"0","summary":"test1234567","transparency":"OPAQUE","uid":"60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                [05.01.2024 13:22.18.330] [DEBUG] start: Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.331] [DEBUG] end:: Sat Jan 06 2024 10:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.331] [DEBUG] duration: 3600000
                [05.01.2024 13:22.18.331] [DEBUG] title: test1234567
                [05.01.2024 13:22.18.331] [DEBUG] initial tz=Europe/London
                [05.01.2024 13:22.18.332] [DEBUG] corrected tz=Europe/London
                [05.01.2024 13:22.18.332] [DEBUG] start date/time=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.332] [DEBUG] start offset=0
                [05.01.2024 13:22.18.333] [DEBUG] start date/time w tz =Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.333] [DEBUG] event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.333] [DEBUG] event offset=0 hour=9 event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                [05.01.2024 13:22.18.333] [DEBUG] adjustHours=0
                [05.01.2024 13:22.18.334] [DEBUG] Processing entry...
                  matt216 @sdetweil
                  @sdetweil done
                    matt216 @sdetweil
                    @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
                      sdetweil @matt216
                      @matt216 ok… looking at the code
                        @matt216 can u show me that event from the ICS file?
                        does the rest of the debug output say
                        Calendar-Fetcher: Broadcasting xxx events
                        where xxx is not 0
                          matt216 @sdetweil
                          @sdetweil from ics file:
                          BEGIN:VEVENT
                          CREATED:20240105T132005Z
                          DTEND;TZID=Europe/London:20240106T100000
                          DTSTAMP:20240105T132006Z
                          DTSTART;TZID=Europe/London:20240106T090000
                          LAST-MODIFIED:20240105T132005Z
                          SEQUENCE:0
                          SUMMARY:test1234567
                          TRANSP:OPAQUE
                          UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
                          URL;VALUE=URI:
                          X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                          X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                          END:VEVENT
                          Broadcasting 1000+ events, yes.
                            sdetweil @matt216
                            @matt216 and it works perfectly here…
                            could you try in config before the calendars list
                            broadcastPastEvents: false
                              matt216 @sdetweil
                              @sdetweil config now:
                                                      header: "calendar",
                                                              fetchInterval: 120000,
                                                              timeFormat: 'absolute',
                                                              maximumEntries: 5,
                                                              broadcastPastEvents: false,
        url: 'https://my.cal.url',
        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                              No change. Still not displaying newly created events. :(
                                sdetweil @matt216
                                @matt216 ok, i don’t know… lets get you back to running on the prior release
                                stop mm, shouldn’t be running as its not helpful
                                git tag -l
                                to see the list of tagged commits,
                                then
                                git checkout temp_branch -b tags/v???????
                                where ??? is the number 2.25.0 or whatever u want to go back to
                                then
                                rm -rf node_modules
                                npm install
                                please advise(we can get back to the current v2.26.0 branch too, very easily
                                  sdetweil @matt216
                                  @matt216 just one last thing, if you comment out
                                   maximumEntries: 5,
                                  what happens?
                                    matt216 @sdetweil
                                    @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                                    Getting a git error (novice here, sorry):
                                    fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                                    Although this issue existed before I upgraded to 2.26.0…
                                      matt216
                                      I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                                      Thanks for the help still.
                                      Matt
                                        sdetweil @matt216
                                        @matt216 also try
                                        npm install electron@28.1.1
                                        supposedly it has the fix for ipv6 vs 4
                                          matt216 @sdetweil
                                          @sdetweil Thanks. Done. No change :(
                                          Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
                                            sdetweil @matt216
                                            @matt216 I have not had others with no updates, but others w missing events
                                            • 3 / 5
