    Calendar not updating
    95 Posts 4 Posters 92.5k Views 6 Watching
      matt216 @sdetweil
      @sdetweil done
        matt216 @sdetweil
        @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
          sdetweil @matt216
          @matt216 ok… looking at the code
            @matt216 can u show me that event from the ICS file?
            does the rest of the debug output say
            Calendar-Fetcher: Broadcasting xxx events
            where xxx is not 0
              matt216 @sdetweil
              @sdetweil from ics file:
              BEGIN:VEVENT
              CREATED:20240105T132005Z
              DTEND;TZID=Europe/London:20240106T100000
              DTSTAMP:20240105T132006Z
              DTSTART;TZID=Europe/London:20240106T090000
              LAST-MODIFIED:20240105T132005Z
              SEQUENCE:0
              SUMMARY:test1234567
              TRANSP:OPAQUE
              UID:60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF
              URL;VALUE=URI:
              X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
              X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
              END:VEVENT
              Broadcasting 1000+ events, yes.
                sdetweil @matt216
                @matt216 and it works perfectly here…
                could you try in config before the calendars list
                broadcastPastEvents: false
                  matt216 @sdetweil
                  @sdetweil config now:
                                          header: "calendar",
                                                  fetchInterval: 120000,
                                                  timeFormat: 'absolute',
                                                  maximumEntries: 5,
                                                  broadcastPastEvents: false,
        url: 'https://my.cal.url',
        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                  No change. Still not displaying newly created events. :(
                    sdetweil @matt216
                    @matt216 ok, i don’t know… lets get you back to running on the prior release
                    stop mm, shouldn’t be running as its not helpful
                    git tag -l
                    to see the list of tagged commits,
                    then
                    git checkout temp_branch -b tags/v???????
                    where ??? is the number 2.25.0 or whatever u want to go back to
                    then
                    rm -rf node_modules
                    npm install
                    please advise(we can get back to the current v2.26.0 branch too, very easily
                      sdetweil @matt216
                      @matt216 just one last thing, if you comment out
                       maximumEntries: 5,
                      what happens?
                        matt216 @sdetweil
                        @sdetweil commenting maximumEntries just shows the default 10 entries, but still does not include recently created events that should show within those 10.
                        Getting a git error (novice here, sorry):
                        fatal: 'temp_branch' is not a commit and a branch 'tags/v2.24.0' cannot be created from it
                        Although this issue existed before I upgraded to 2.26.0…
                          matt216
                          I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
                          Thanks for the help still.
                          Matt
                            sdetweil @matt216
                            @matt216 also try
                            npm install electron@28.1.1
                            supposedly it has the fix for ipv6 vs 4
                              matt216 @sdetweil
                              @sdetweil Thanks. Done. No change :(
                              Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
                                sdetweil @matt216
                                @matt216 I have not had others with no updates, but others w missing events
                                • N
                                  nechry
                                  I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
                                    sdetweil @nechry
                                    @nechry thanks for the feedback
                                      mspk
                                      @sdetweil said in Calendar not updating:
                                      Hi, I’m pretty new here, so sorry if I mess something up. I think I have the same problem. Installed MM yesterday (so pretty vanilla setup), the only module I added is the MMM-CalendarExt3.
                                      I configured everything as it should be (I hope at least), but for some reason, my calendars are not beeing updated and one is not beeing show at all… I don’t know what to do anymore, maybe you guys have an idea.
                                      Here is my error: ```
                                      0|MagicMirror | [09.01.2024 12:28.43.248] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/[MyCalendarNameHere]/basic.ics
                                      TypeError: fetch failed
                                      0|MagicMirror | at Object.fetch (node:internal/deps/undici/undici:11576:11) {
                                      0|MagicMirror | cause: Error: write EPIPE
                                      0|MagicMirror | at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
                                      0|MagicMirror | at handleWriteReq (node:internal/stream_base_commons:58:21)
                                      0|MagicMirror | at writeGeneric (node:internal/stream_base_commons:149:15)
                                      0|MagicMirror | at TLSSocket._writeGeneric (node:net:931:11)
                                      0|MagicMirror | at TLSSocket._write (node:net:943:8)
                                      0|MagicMirror | at writeOrBuffer (node:internal/streams/writable:392:12)
                                      0|MagicMirror | at _write (node:internal/streams/writable:333:10)
                                      0|MagicMirror | at TLSSocket.write (node:internal/streams/writable:337:10)
                                      0|MagicMirror | at write (node:internal/deps/undici/undici:10124:18)
                                      0|MagicMirror | at _resume (node:internal/deps/undici/undici:10037:33)
                                      0|MagicMirror | at resume (node:internal/deps/undici/undici:9938:7)
                                      0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:9286:11)
                                      0|MagicMirror | at Client.Intercept (node:internal/deps/undici/undici:9017:20)
                                      0|MagicMirror | at Client.dispatch (node:internal/deps/undici/undici:7772:44)
                                      0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:7991:32)
                                      0|MagicMirror | at Pool.dispatch (node:internal/deps/undici/undici:7772:44) {
                                      0|MagicMirror | errno: -32,
                                      0|MagicMirror | code: ‘EPIPE’,
                                      0|MagicMirror | syscall: ‘write’
                                      0|MagicMirror | }
                                      0|MagicMirror | }
                                      Thanks!
                                        sdetweil @mspk
                                        @mspk I think you have the wrong calendar url , you need the ical format url, not the embed url
                                        mine is like
                                        https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-fhkjsadfhsdflk'sdfk/basic.ics
                                        M M 2 Replies Last reply Reply Quote 0
                                          mspk @sdetweil
                                          mine is like
                                          You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
                                            matt216 @sdetweil
                                            @sdetweil I think you are potentially right. For baikal I have followed such advice as here: https://forum.magicmirror.builders/topic/434/caldav/4?_=1704811423495 where it was advised just adding ?export to the end of the cal URL to generate the ics file, but it is not an actual ics link.
                                            I shall work along those lines…
                                            • 3 / 5
