    v2.26.0 - default calendar rrule / event.recurrences issue
    4 Posts 3 Posters 1.3k Views 4 Watching
    • evroomE
      evroom
      This event:
      BEGIN:VEVENT
      DTSTART;TZID=Europe/Berlin:20240104T180000
      DTEND;TZID=Europe/Berlin:20240104T200000
      RRULE:FREQ=WEEKLY;WKST=MO;COUNT=10;BYDAY=TH
      DTSTAMP:20240102T212443Z
      UID:63c23cpe0h356vgjl0o4tsnjbi@google.com
      CREATED:20240102T212139Z
      LAST-MODIFIED:20240102T212139Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:#:SingleEventRepeating
      TRANSP:OPAQUE
      END:VEVENT
      Leads to this:
      0|MagicMirror  | [02.01.2024 22:22.25.197] [DEBUG] Title: #:SingleEventRepeating, with dates: ["2024-01-04T17:00:00.000Z","2024-01-11T17:00:00.000Z",null,null,"2024-02-01T17:00:00.000Z","2024-02-08T17:00:00.000Z",null,null,null,"2024-03-07T17:00:00.000Z"]
      0|MagicMirror  | [02.01.2024 22:22.25.197] [DEBUG] event.recurrences: undefined
      So:
          null,
          null,
          null,
          null,
          null,
      Resulting in MM showing only 5 of the 10 events.
      I would like to know where to look for the RRULE processing; cannot find anything in the calendar code.
      As there are some other issues that I found, I could perhaps learn something from it.
      Otherwise I will open an issue for it.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom we don’t do the RRULE processing ourselves,… we call the RRULE library function between
          rrule.between(now and 1 year from now)
        calendarfetcherutils.js
        Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
        					let dates = rule.between(pastLocal, futureLocal, true, limitFunction);
        					Log.debug(`Title: ${event.summary}, with dates: ${JSON.stringify(dates)}`);
        					dates = dates.filter((d) => {
        						if (JSON.stringify(d) === "null") return false;
        						else return true;
        the we process the dates returned… note the filter I added this release, cause the null values returned killed the calendar
        • K
          kitlaan
          FYI: I think this is related to the latest rrule release (2.7.0), which was updated when node-ical was upgraded to 0.17.1 (from 0.16.1). It looks like rrule removed luxon with its own self-built replacement… and the behavior changed.
          If you sift through issues filed in node-ical and rrule, there seems to be folks also seeing new recurrence behavior. As to why, /shrug…
          On my install, I rolled-back to the older version (npm install node-ical@0.16.1) and it seems now to be behaving.
            sdetweil @kitlaan
            @kitlaan yes it’s the new rrule.
            the old one is broken too…
            but, thanks for the feedback
