    ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf:
    26 Posts 5 Posters 12.4k Views 5 Watching
      sdetweil @ereborinkorppi
      @ereborinkorppi also show the output of npm start
      • E Offline
        ereborinkorppi @sdetweil
        peili@raspberrypi:~/MagicMirror $ node -v
        npm -v
        lsb_release -a
        v20.8.0
        10.1.0
        No LSB modules are available.
        Distributor ID: Debian
        Description: Debian GNU/Linux 12 (bookworm)
        Release: 12
        Codename: bookworm
          @ereborinkorppi also output of
          uname -a
          file /usr/bin/bash
          • E Offline
            peili@raspberrypi:~/MagicMirror $ uname -a
            Linux raspberrypi 6.1.0-rpi7-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
            peili@raspberrypi:~/MagicMirror $ file /usr/bin/bash
            /usr/bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
              @ereborinkorppi ok, both in 64 bit mode
              we disable GPU in 2.26 by default now…
              so none of those messages should be happening…
              • E Offline
                @sdetweil I accidentally removed the post for npm start output and have been waiting for it to be re-posted, but it is still in the post queue. I have no idea what to do next? Should I re-install 32 OS instead and try to run the MagicMirror install script again or install an older MagicMirror version that used to work?
                  @ereborinkorppi I was waiting for you to respond… and u did… so I just rejected the post that was marked as spam. like my message should have said
                    @ereborinkorppi it would be interesting to see the 32 bit results…
                    • E Offline
                      @sdetweil I will give it a go if no easier solutions available, but will take some time before I can test it. Thank you so far, will report later what happened.
                        @ereborinkorppi i just don’t know… we are not using GPU, that error is related to GPU.
                        says happening in chromium, but we are not using chromium… so… at a loss.
                        I see it on my pi3 in 32 bit mode, but it doesn’t stop mm…
                        • 2 / 3
