    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 11.6k Views 2 Watching
      davismorehead
      Just upgraded to version 2.26.0, now MM will not start getting error
      magicmirror@2.26.0
      startDISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGILL
      Assume some thing was upgraded and i need to upgrade. any ideas.
        sdetweil @davismorehead
        @davismorehead
        lets start at the beginning… how did you install, and how did you upgrade?
        manual or with my scripts?
        tell me output of
        node -v
        npm -v
        lsb_release -a
        uname -a
        do you use pm2 to autostart?
        if so do
        pm2 stop all
        cd ~/MagicMirror
        npm start
          davismorehead
          pi@raspberrypi:~ $ node -v
          v19.3.0
          pi@raspberrypi:~ $ npm -v
          9.2.0
          pi@raspberrypi:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description: Raspbian GNU/Linux 10 (buster)
          Release: 10
          Codename: buster
          pi@raspberrypi:~ $ uname -a
          Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
          pi@raspberrypi:~ $
          I updated manually. Later I tried to run your script but I am running remotely so can’t do your script. would need to hook up keyboard to pi.
          am using pm2. Saw a different post where you did the npm start, so did that already. Same error
            @davismorehead I need the actual messages from npm start.
            if you can ssh or VNC or RDP into your machine you can run my scripts, it’s a cut and paste of the comnands
              davismorehead
              pi@raspberrypi:~ $ pm2 stop all
              [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
              [PM2] mm ✓
              │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
              │ 0 │ mm │ fork │ 95 │ stopped │ 0% │ 0b │
              pi@raspberrypi:~ $ cd ~/MagicMirror/
              magicmirror@2.26.0 start
              Also can you point me to instructions to run your script.
                davismorehead
                here is the command i found for your script
                pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
                $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
                $$$$$$ $$ | _
                $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
                $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
                $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
                _
                | _
                | _
                | _
                $$ |_| _
                |_| _|_|_| __| _
                / _| _______|
                _
                ____/
                install log being saved to /home/pi/install.log
                cat: /etc/systemd/system/default.target: No such file or directory
                system running in command line mode, need graphical desktop, see raspi-config
                  @davismorehead see
                  did you run npm install, or npm run install-mm
                    davismorehead
                    i did
                    git pull && npm run install-mm
                    Some of my replies take a long time to be approved. Is there a secret to get them approved faster.
                      @davismorehead if you have already installed, then you don’t run install again…
                      so, are you running headless? (no screen?)
                      so you would not do npm start, you would do npm run server
                        @davismorehead said in MM doesnt work after update to version 2.26:
                        I review every post for every user with reputation below 2.
                        this keeps out all the spam…
                        i DO do other things…
                        • 1 / 3
