    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 11.9k Views 2 Watching
      davismorehead
      I will look at your script later.
      So in the future I should run npm update not npm install?
        davismorehead
        cd MagicMirror/
        pi@raspberrypi:~/MagicMirror $ npm update
        added 495 packages, and changed 6 packages in 3m
        195 packages are looking for funding
        run npm fund for details
        That worked
          sdetweil @davismorehead
          @davismorehead i don’t understand
          when we release a new version, we have dependency changes additions, removals
          so to handle all that you do
          npm run install-mm
          install-mm is a script tag in the package.json
          it just turns off as much of the noise as we can…
          my script does the same thing…
          I don’t know what npm update does. we don’t use it
            davismorehead @sdetweil
            @sdetweil said in MM doesnt work after update to version 2.26:
            ad you could try upgrade, with force instead of apply.
            so based on this post i Tried npm update. Not sure what you meant me to do. So sounds like we solved it but don’t know why.
                @davismorehead what I meant was to use my upgrade script
                its a two step process…
                test
                do
                on the ‘do’
                its the same command as test, but with the parm ‘apply’ on the end
                I check if you have already upgraded, and won’t let you do it again, accidentally
                SO, as you HAVE already downloaded the new code, I would just end
                but if you change apply to force
                then upgrade will happen again …
                my objective is to NOT screw up your wonderful mirror system .
                  davismorehead
                  oh. I have to figure that out since I cannot get it to run because of the default.target file not existing on my pi.
                  Again thanks for your help.
                    @davismorehead that check is only on install, not upgrade
                    different scripts
                      davismorehead
                      oh i see. Ran the upgrade script and everything worked. I didn’t apply since nothing changed. I will run it next time i need to update. Thanks again for you help. You can close this now.
                        @davismorehead I updated the installer (raspberry.sh) to use the
                        systemctl get-default
                        command instead of looking at the file…
                        thanks for the info
