    MMM Hue Lights is not updated
    39 Posts 3 Posters 20.2k Views 3 Watching
      JoeFranz @sdetweil
      @sdetweil After “npm start mm” nothing from the hue-lights module is shown. Do I have to enter something else?
        sdetweil @JoeFranz
        @JoeFranz it’s not npm start mm
        it’s npm start
        if you were trying to use pm2 to start
        the
        pm2 start mm
        show the config entry for hue module, xx out any key…
          JoeFranz @sdetweil
              			module: 'mmm-hue-lights',
              			position: 'top_right', // pick whichever position you want
                  			bridgeIp: '192.168.178.68',
                  			user: 'xxxxxxxxxxx',
          				displayType: 'grid',
          				displayMode: 'groups',
          				minimalGrid: true,
          				minimalList: true,
          				alignment: 'center',
                  			// ... and whatever else configuration options you want to use
            sdetweil @JoeFranz
            @JoeFranz seems like you should get some message
            we put in new messages this release if we couldn’t find the folder or js file that matches the module name. so that’s not it
              @JoeFranz I always seem to have to push the button on my hue bridge whenever i add a new app to talk to those lights
                JoeFranz @sdetweil
                @sdetweil Ok, I don’t really understand. Does that mean the module no longer works with the new MM version?
                It’s the mmm-hue-lights module, not Mitch’s MMM-Hue.
                Then I’ll try that :-)
                S mumblebajM 2 Replies Last reply Reply Quote 0
                  sdetweil @JoeFranz
                  @JoeFranz I don’t know. never tried it.
                  • mumblebajM Offline
                    mumblebaj Module Developer @JoeFranz
                    @JoeFranz Does your bridge have the same IP address? It could be that the IP for the bridge has changed. I added a fixed IP for my bridge to the router so that it never changes.
                      JoeFranz @mumblebaj
                      @mumblebaj
                      Yes, the bridge still has the same address. It works for about 1-2 hours after starting, but then the display no longer updates :-(
                        @JoeFranz You could try my MMM-PhilipsHue module.
                        Unfortunately I am not sure what the issue is with the one you are using. Are you seeing any errors for the module popup anywhere?
                        J 2 Replies Last reply Reply Quote 0
                        • 4 / 4
