    MMM Hue Lights is not updated
    39 Posts 3 Posters 21.1k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @JoeFranz
      @JoeFranz Apologies, I cannot assist with that. Have no idea how his module works.
        JoeFranz @mumblebaj
        @mumblebaj Ok, I installed it and am trying it out. However, I would like to exclude several groups in the line “hideGroupsWithString”. How do I enter multiple groups in the line?
          @JoeFranz That feature does not work on my module currently. I need to make time to implement.
            @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
             hideSpecificGroups: true,
             hideGroupsWithString: "Room"
            Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
              JoeFranz @mumblebaj
              @mumblebaj This is displayed when your module is installed, no lights… :-(
              IP and userid are correct.
              mumblebajM 3 Replies Last reply Reply Quote 0
                @JoeFranz Show me your config please.
                  @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
                  Below is my config and it works fine. It will only display lights that are on.
                                      module: 'MMM-PhilipsHue',
                                      disabled: false,
                                      position: 'bottom_left',
                                      config:{
                                          bridgeip: "bridgeip",
                                          userid: "userid",
                                          refreshTime: 10000 * 5,
                                          lightsOrGroups: "groups",
                                          animationSpeed: 2 * 1000,
                                          showOnlyOn: true,
                                          showLabel: true,
                                          colour: true,
                                          hideGroupsWithString: ["Kitchen", "Den"]
                  The fix should be ready in the next hour. Just busy testing it.
                    @JoeFranz Fix has been deployed, You can now exclude multiple Groups
                      JoeFranz @mumblebaj
                      @mumblebaj said in MMM Hue Lights is not updated:
                      		    position: 'top_right',
                      			bridgeip: "192.168.178.xx",
                      			userid: "xxxxxxxx",
                      			colour: true
                      S mumblebajM 2 Replies Last reply Reply Quote 0
                        sdetweil @JoeFranz
                        @JoeFranz PLEASE, ALWAYS code block around config info …
                          @JoeFranz Please match your config with mine and it should work
                            JoeFranz @mumblebaj
                            @mumblebajI
                            did it and it works :-)
                            Now let’s see how long the display takes to update.
                            Thank you
                              @JoeFranz From my config it checks the status of the lights every 5 minutes.
                              You can change that at anytime in the config and restart your mirror for the change to take effect.
                                JoeFranz @mumblebaj
                                @mumblebaj
                                Is that correct in your config 5x10000?
                                On your module page it says 60x10000
                                  @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                                    JoeFranz @mumblebaj
                                    @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                                    But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                                    This is part of the current config, after 10 minutes the lights will be updated.
                                                            refreshTime: 60 * 1000,
                                    			showOnlyOn: false,
                                      @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                                        JoeFranz @mumblebaj
                                        @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
                                          @JoeFranz No worries
